Question about Gigabyte GA-VM900M Motherboard
No video signal - Gigabyte GA-VM900M Motherboard
  • 961 Answers
Http://www.gigabyte.com/products/product-page.aspx?pid=2581#ov
This is Gigabytes link toy your board, and, a very handy one I might add. It gives you your specs, downloads, etc. An all in one link. I'm not sure what you mean by no video signal, if ou have no video, it could be due to outdated drivers or because your device is not "enabled". You can check this by opening your "control panel", find device manager icon and right click on it. In the window that comes up click on box on the right side of "display adaptors", you should see your device. Right click on that and a window will comeup with "enable" or " disable", if it sysenable, click on that and you should be set. If this doesn't work for you let me know in "add comment" at end of solution.
Posted on Mar 15, 2011
My dell w3201c tv displays "no video signal" when i power it on
Coaxial cable does not carry video signals but rather rf-signals
To use coax you will have to tune like you are searching for a signal from your aerial..
If you prefer to use video then you will have to use a video cable either rca or hdmi. you can then choose video or hdmi from the remote
Len
Sep 12, 2014 | Dell 221-9703 W3201C 32 INCH LCD TV...
Does the coaxial output equivalent to a standard yellow cord video cord? Trying to transmit Direct TV signal to another TV via a RF Link.
Typically the coax is an rf signal. The "yellow cord " is a video signal and never the twain shall meet without an rf modulator. rf contains all video, audio, and sync signal. Video contains just video, no audio. If you use the yellow, and the white and the red you will have video and both audio channels.
Oct 16, 2009 | Olevia LT27HVX 27 in. LCD Television
On our Durabrand DVD/Vcr Combo, I get picture, but no sound..I'm using a S video as conectors!
S video connector is used only for video, you need to connect the audio separately via the RCA audio connectors or via digital coaxial or optical connector.
You can read more on S video standard here:
http://en.wikipedia.org/wiki/S-Video
Also see the related topics on audio, maybe you should consult the user manuals for your dvd unit and the amplifier that you use to get more info, but normally the sound can be connected via these connectors on the rear panel of dvd units:
- main left and right analog signal out RCA connectors (2 channel stereo signal - amplifier set to analog signal)
- main left and right, sub, center, surround left and right analog signal out connectors (multichannel surround signal - amplifier set to analog signal)
- coaxial digital signal out RCA connector (a single cable that takes the stereo or surround signal to the amplifier in a coded digital form - you need to set the amplifier to the digital signal mode to enable this kind of signal)
- optical digital signal out connector (same as the coaxial digital output, the difference is that the signal is in the form of light pulses instead of electrical pulses - the amplifier should be set to the digital signal mode as well)
Hope this helps somehow - if it doesn't, post me some feedback, perhaps a brief description of the units that you want to interconnect...
regards
Triarcuate
Sep 26, 2009 | Televison & Video
Have audio signal but no video signal
at standby hold down the on/off button for 5 seconds or untill multiple bleeps then release
Aug 10, 2009 | Sony Playstation 3 (PS3) Console
VIZIO LCD VX20L, intermittant video/audio with Blue screen message "No Signal"
If the tuner is bad, changing the mainboard should fix the problem.
May 18, 2009 | Vizio VX20L 20 in. LCD TV
Conver the signal of old CRT to VGA signal.
we use the old CRT monitor made by motorola with TTL video signal and different vertical &horizontal frequency signals than monitor with vga signal.at now we can not replace crt with lcd .is there any interface to convert this crt signal to vga monitor signal for replacing the crt with lcd or vga monitor ,beacause this crt is discontinued and the quality of video is weak.if you needs the crt specification i will post it for you.thanks.
Jan 30, 2009 | Computers & Internet
I cant see video from ipod
No in the ipod settings have u turned on the NSTF signal for the TV?
May 25, 2008 | Audiovox VM9512 Car DVD Player
Hooking up vcr and wii game with out disconnecting one or other
depending on your vcr (really need a description of its input and outputs) you may be able to connect the game to the VCR's inputs and just run the signal through it.
An 'S-video' cable stands for Separate video, abbreviated S-Video and also known as Y/C (or erroneously, S-VHS and "super video") is an analogue video signal that carries the video data as two separate signals (brightness and colour), unlike composite video which carries the video signals mixed in one line. S-Video, as most commonly implemented, carries 480i or 576i resolution video, i.e. standard definition video. S-Video does not carry audio on the same cable.
Jan 03, 2008 | Televison & Video
Video signal into VCR
you have to select to switch from comopsit to s-vhs for the video input in your sony slv -n55 to get the video reached to it regards please don't forget to rate ,thx
Oct 15, 2006 | Sony SLV-N55 VHS VCR
Gigabyte GA-VM900M Motherboard Logo
54 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
