Question about Jenn-Air JMC8130DDS Microwave Oven
This microwave is attached to (on top of) a convection oven (one unit). We ran the cleaning cycle on the oven yesterday and afterwards, the microwave did not work. The microwave control panel is completely black and no portion of the microwave works.
    Problem Solver:
  • 30 Answers
The microwave got too hot. I think everyting inside melted. I'm sorry
Posted on Mar 15, 2011
7 yr old unit emitting burning smell. Everything still works. Is it worth trying to get repaired or just buy a new one.
is the burning smell just when you use the convection oven or when you use the microwave , reason I ask is that if its only coming from the convection oven then chances are you have something melted on the heat elements , this can be cleaned off with a dry brillo pad
Nov 20, 2015 | GE JVM1790 Convection / Microwave Oven
How do I remove a dometic convection oven from my CRV
If you will begin to gently take apart the compartment where the Convection oven is, you will see that it is fastened in mostly by the wood/plastic framework around it.
Usually the cord is a regular one and is plugged in behind the unit. Keep in mind how you will re-attach the framework which holds it in place when you are finished.
God bless your efforts.
Sep 29, 2015 | Dometic DOTRC17B RV Microwave/Convection...
My GE model JVM1790SK Microwave randomly died yesterday. I had just finished cooking something, started it again, and while the timer started counting, the over did not start. Any idea what this cou
Had you noticed that it was getting weaker? Taking longer to heat a cup of water/coffee? If so then the magnatron was getting weak and gave up the ghost. They are expensive, probably cheaper to get another oven. the other likely failure component is the capacitor. Careful they contain power even when unplugged. Caps are not that $$. good luck
Jan 03, 2015 | GE JVM1790SK Convection/Microwave Oven
I have a panasonic convection/microwave. Last night, after I cleaned it, using oven cleaner on a sponge, it made a loud humming noise after running on microwave for about 10 sec. It does not make the noise...
Since the unit makes the noise on Microwave but not convection it is a problem it he Microwave Circuit. Probably in either the rectifier of bad mag, one of them shorted. Just looked at the date you posted this, Im sure you have fixed or replaced this by now
May 31, 2017 | Panasonic NN-C980 Convection/Microwave...
Wife ran for 14 min w/out anything in it changed fuse no luck
You need to change the cavity thermostat. The unit got too hot and blew the cavity thermostat. If this is a vent-a-hood model, it will be up under the vent housing at the top (must drop microwave to change) and if built-in, it will be on the left side under the outer cover. Just remove the screws from the back and sides and right along the edge along the bottom sides. Will have 2 wires going to it from each side. Just replace thermostat and reattach molex plugs. Then retest. Should be fine after that.
Jul 12, 2010 | LG LMV1630 Convection/Microwave Oven
How do I replace a lightbulb in my Kitchenaid microwave?
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KEMS307DBS&siteCd=KAD#parts_list HEY ANDYCOOL,GO TO THIS LINK IT'LL SHOW YOU ANYTHING YOUR HEART DESIRES ABOUT THIS UNIT(DRAWINGS,USER MANUAL,PARTS LIST,INSTALLATION GUIDE,ECT.)SORRY BUT FROM THE LOOKS OF IT YOUR GONNA HAVE TO PULL THAT PUPPY.BUT YOU BE THE JUDGE OF THAT.GOOD LUCK,HOPE THIS HELPS!!!!
Nov 08, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
No Power to Jenn-Air Microwave JMC8130DDS
I just had the same problem. Our unit is about 5 years old. I was running the self-cleaning mode, and put something to heat in the microwave. It heated at first, then all power to microwave went out. I read the above description and we pulled the entire unit out, and there was a reset switch on top of the oven. Pushed it and the microwave was back in business. I would have been very upset if I had called a service man and he spent 5 minutes, just as we did, to pull it out and reset the circuit. We turned all power off prior to pulling out the unit. It seems JennAir should admit this is an innate design flaw and offer some sort of compensation or come up with a repair kit to fix this issue....
Dec 27, 2007 | Frigidaire GLMB209D Microwave Oven
Unit Electrical Problem
If it blows the fuse as soon as you hit the START button, it's almost certainly a shorted high-voltage capacitor.
If it blows a few seconds after you hit the START button, it's probably the high-voltage transformer. You'll possibly also smell a faint electrical burning smell from the rear vent after you shut if off.
Microwave can be very dangerous so it is best to have it looked by a professional
Would appreciate a solved rating for expert advise.
Oct 16, 2007 | GE JE1590 Convection / Microwave Oven
Jenn-Air JMC8130DDS Microwave Oven Logo
117 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
