Question about Weiser Lock POWERBOLT ELEC DEADBOLT
I think the batteries are dead because when I enter my pin it gives me a continuous beep and will not open. The problem is that the keys for the lock are inside, behind the locked door. HELP!!!
  • 963 Answers
Troubleshooting instructions for the Weiser Powerbolt can be found here:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Posted on Apr 18, 2011
Only has keypad to access safe. batteries are dead
Leave it for a week. The batteries might have regenerated just enough to open the door once more.
Otherwise there may be a keyhole beneath the front plate.
If all else fails, you'll have to cut the back out of the safe.
Mar 10, 2015 | Home Security
Locked key fob in 2014 grand Cherokee
Easy, just retrieve spare from your hide a key box (sorry, couldn't resist). Best answer is hire a "lock-out" specialist to open door with minimum damage.
Jul 07, 2014 | 2002 Jeep Grand Cherokee
Beep does not sounds when locking
Very possible. Each lock has to fully complete it's movement in order to send an "all lock" signal to transceiver. If not, you may wake to a dead battery as the alarm retries the last command to lock repeatedly.
Dec 25, 2013 | 2002 Toyota Sequoia
I have a safewell safe. Batteries are dead and I have lost my keys. The reference is EX2006029121. ANY IDEAS PLEASE.
I read this elsewhere. it's worth a try...
"I had the same problem, batteries dead and i could not find the keys. I read on the internet that if you get a hairdryer, and heat up the front of the safe where the keypad is and where the spare key goes in this will work, i thought anything is worth a try. So i held the hairdryer there for a bout 15 mins and what happens is the heat slowly boosts the battery life, enabling you to open the safe. You will notice that you start to get a beep noise from the key pad. even though i was getting a beep from the pad it didnt open straight away but after about 10 mins i retried the code and it worked. Make sure you replace the batteries immediately before closing the safe again "
Jan 25, 2012 | Locks & Locksmithing
I think my key remote is dead and my key won't open the door. what can i do?
put a new battery in remote,try key in other door," are you sure the car battery is not dead," !!!! If it is then remote wont work, if you are locked out of car call wrecker or lock smith and they can slim jim the door to get you inside. then unlock doors USING THE POWER LOCK button PROVIDING CAR BATTERY IS NOT DEAD!!!!
Jan 14, 2011 | 1999 Lincoln Continental
Just put new batterys in safe . but safe will not stop bleeping what is the problem
Please follow these steps
Programming a user code
There are two ways to program a user code.
A 1. Press the Program key.
2. Enter the Factory Code. The green LED remains ON
while you enter the 5-digit user code of your choice.
After 5 digits are entered the green LED turns OFF.
(To enter a new User Code, repeat these steps.)
B 1. Press the red button inside the safe. The lock will
beep and the green LED will come on.
2. Enter a 5-digit user code.
Keep your new user code secure.
For your records, please copy it here:
____ ____ ____ ____ ____
Programming a password
2. Press it a second time.
3. Enter your 5-digit User Code. The green LED remains ON.
4. Enter the 5-digit Password of your choice (any combination
except 00000.) After 5 digits are entered, the green LED
turns OFF.
(To enter a new Password, repeat these steps. To erase the
Password, press Program twice, enter your User Code and then
enter 00000.)
Battery replacement
Below When old batteries are removed for replacement, your Password will be voided; only Factory and User Codes will work. To
reestablish your Password, follow the directions above under
Programming a Password.
Key override
If your electronic lock fails or you do not have any codes
available, you may use a key override to access this unit.
1. Remove the battery cover, disconnect and remove the
battery holder.
2. Insert the skeleton key (second set of keys provided)
into the key hole inside the opening for the battery.
3. Turn the key to the right.
4. Turn the four bit key to the right.
5. Open the door.
Signals
Your electronic-lock safe communicates by means of several
audio/visual signals.
Red (Error) LED + three beeps indicates
one of the following:
1. You have pressed Program key out of sequence
2. You have entered an invalid code or password.
3. You have let 5 seconds or more elapse between key entries.
Green (Proceed) LED + single beep occurs
1. After entering each digit of Factory or User Code, or
Password
2. After pressing Clear key
3. After pressing Program key
Green LED only
1. Comes on after you enter a valid code/password and
remains lit during the 4-second period in which the safe
can be opened.
2. Comes ON in the Program User Code mode after you enter
the Factory Code and remains lit until you have finished
entering a 5-digit User Code.
3. Comes ON in the Program Password mode after you have
entered your User Code and remains ON until you have
entered a 5-digit password.
Yellow LED
Indicates low battery and will typically not turn ON until
battery has been in use approximately two years or longer.
Your electronic lock automatically performs a low battery test
during each lock use.
If a �low battery� condition is detected the Yellow LED will
come ON and remain ON during each subsequent lock
operation. (The lock will continue to function in a Low Battery
state, until battery failure.) The Yellow LED will turn OFF only
after three consecutive Good Battery readings or after the low
batteries are replaced. (Note: If the new batteries are installed
in less than 60 seconds the Yellow LED may come ON and stay
ON during the first lock operation before it returns to OFF.)
NOTE: It is recommended you replace the batteries after two
years, or when the yellow LED remains on.
Jan 09, 2011 | Safe International Electronic Digital Safe...
Bought a electronic deadbolt at Rona (Rona Collection). Installed it and i can open/close it with the remote control or a key. Can't open it by entering a code. I thought the factory code was 1234, but...
Rona Electronic Deadbolt Lock Instructions:
Default Master Code:123
Resetting Master PIN:
  • Remove batteries and put them back. You will hear a long beep and a short beep.
  • Press and hold the 0 button until you hear 3 long beeps and the LED flashes red for 3 seconds. You are now in program mode.
  • Within 10 seconds, key in a new master PIN (up to 12 digits) and press the UNLOCK button.
  • Key in the master PIN again and press the UNLOCK button. The LED will flash green for 1 second and the resetting is complete.
Adding a PIN:
  • Key in master PIN and press UNLOCK button
  • Press and hold 0 button until you hear 2 short beeps and the LED flashes for 3 seconds.
  • Release 0 button and you are in the Add PIN mode
  • Within 10 seconds, enter a new PIN and press the UNLOCK button. You will hear one beep.
  • Key in the new PIN again and press the UNLOCK button twice. When the LED stops flashing the PIN has been added.
Sep 23, 2010 | Deadbolt Locks & Locksmithing
Lost key and i cannot remember my pin, i enter it and it just beeps at me
get hold of a locksmith. no person will give you any hints on opening a safe personal or not. locksmiths are bound by a work code NOT to divulge any secrets for opening a lock.
Oct 21, 2009 | Safe International Digital Electronic Safe...
I have lost my pin and backup keys + battery dead!
i got the same problem i lost my key and cant open now
any idea what to do
May 28, 2009 | Safe International Digital Electronic Safe...
Kwikset smart code touchpad electronic deadbolt
I have the same problem, electronic locking system went dead but still beeps, stuck using keys now...according to the kwikset website though it says "Warranties cover the original residential user of Kwikset Products against defects in material and workmanship as long as the original user occupies the residential premises upon which the product was originally installed." so hopefully they will fix the problem
Oct 12, 2008 | Deadbolt PFK Touchpad Electronic Lockset
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
300 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
