Question about Fisher and Paykel DD605I Dishwasher
RE; nautilius 920  RE: Error message U1 I
  • 17 Answers
SOURCE: Fisher paykel dd603
Pull the bottom drawer out !!!!! To do this on the left and right sides of the bottom drawer you need to pull the pins (Plastic) then pull it out it has hoses still connected pull out and turn on side look in the back left corner (with Pwr off) there is a board there and it has a water (Flood sensor) on it make sure it is dry this is what the Fault code is
Posted on Dec 03, 2007
  • 3247 Answers
SOURCE: F & P DD603 starts to wash then beeps &
Have you checked whether you are getting the water supply to the dishwasher. Check if there is no kink in the water hose.
If no problem with water supply then check the water pressure rating is OK for the dishwasher.
Posted on Dec 15, 2009
  • 1382 Answers
SOURCE: U1 Error and Washer Stops Working
"U1 error code" means the unit has failed to prime with water within 3 minutes. Its taking longer than expected to fill with water. Check the fill valve,it might be due to water supply problem, or the spray arm might not be in the exact position place.Check the above to fix this error code.
Thank you !!
Posted on Jun 22, 2010
Hi Im Max
SOURCE: code u1 fisher& paykel model 920
hi, this tells you everything you need to know about a
fisher& paykel model DW820 and DW920 modelsi was also looking for the u1 error, and im sure my problem is being a male i use to much detergent (powder) that creates extra foam :o) oops lol but theres a list of things u1 error could be, i also found a few things out i wanted to know but googled before and found nothing. basically its better than the manual with everything you need to know. have fun.
http://www.fisherpaykel.com.au/admin/pdfs/pdf_usecares/521766I_DW920_ugm_NZw.pdf
if your computer doesnt read pdf files like mine didnt :( when you download and open it, it will ask to check internet for a program to download that reads it, in the list that shows i chose adobe reader 8, works well, anyway this will help im sure from max
Posted on Nov 15, 2010
  • 3247 Answers
SOURCE: I am having the a problem with the bottom drawer
The good thing is that you have a double drawer which means you have somethnng to continue cleaning dishes while you are fixing the other drawer and if necessary, you have a set of spares to try out as part of fault finding. That is the positive side but now let us get to the negative side.
Once the fork got dropped it is likely it has locked the wash arm and put strain on the rotor that runs the arm during wash cycle. The same rotor runs the drain pump. Not sure which "sensor" the technician was talking about. Yes there is a hall sensor in the motor assembly in the base of the drawer but that is there to check if the rotor is running at the right speed. However, I am a bit unclear why F1 error showed up when the arm stopped. The lid seal should have prevented any water from getting in. I have feeling the inlet hose or drain hose might be leaking as well.
Are you game enough to remove the rotor from the top drawer and replace the bottom one and try the dishwasher? U1 error is linked to water not getting through the inlet valve. Nothing to do with drain. I hope you did not have the inlet tap turned off that time.
Always make sure you have the mains power to dishwasher turned off when working in it.
Posted on Feb 11, 2011
How do you fix Error code U1
U1 is displayed on the LCD as a "no tap" symbol. (time out on fill is after 175 seconds)
Possible causes:
• Water turned off
• Insufficient water supply pressure
• Blocked water softener filter (if fitted)
• Spilt rinse aid causing over foam in tub
• Incorrect detergent being used
• Motor rotor
• The machine is siphoning
• Inlet valve has failed
• Controller
Jul 08, 2014 | Fisher and Paykel 23 in. DD603H SS...
E9 E2 ERROR
Message = E2
Error = OVERFLOW ERROR
Cause & Solution =
The water is supplied continuously due to an defective inlet valve. Change the valve inlet.
The valve inlet is normal, but the water level sensor Change the water level sensor
(sensor pressure) is low. (sensor pressure).
The drain motor does not work - Test and if faulty change the drain pump
Message = E9
Error = SENSOR PRESSURE ERROR
Cause & Solution = The water level sensor is faulty. Change the water level sensor. (remove pressure tube and blow through it to make sure it is clear first)
Mar 10, 2012 | Daewoo Washing Machines
LG WM1814CW washer - doesn't fill with water. Hear a hum when it should be filling with water, but no water and no error codes. I am guessing Valves (F160 and F170). Any thoughts?
Hi
If the washer won't fill you'll need to check for the water inlet hose, the water inlet valve and the pressure/water level switch assembly. Inspect the inlet hose coming to the washer for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the pressure/water level switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 08, 2011 | LG WM1814CW Front Load Washer
Washer starts and runs for about 10 minutes. Then stops and gives error message HF
Hello & Welcome to FixYa
FH error code is displayed when the control detects no water entering the machine. To clear this error press and hold the PAUSE/CANCEL button twice. You can then check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
Kevin
Mar 07, 2011 | Kenmore HE3T Washer
Thank you !!
Jun 22, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
Bottom draw displaying U1 error message
There is no water coming to the drawer.
This could be due to several reasons. The tap must be on as I presume the top drawer is working.
Could be one or more issues like Inlet solenoid,controller problem, impeller arm not rotating or rotor not sitting properly.
Dec 27, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
ERROR MESSAGE U1
if the message is U1 01 the prob is fax battery abnormality try to check the battery voltage is about 2.5v above and also check the battery circuit
Jul 02, 2008 | Office Equipment & Supplies
Fisher and paykel dish drawer
U1= Machine has failed to prime with water within
approx. 3 minutes
 The water supply is not turned on
 The machine is syphoning
 The spray arm is not in place
 Excessive foaming
 The Inlet Valve has failed
 The electronic controller has failed
 Rotor not fitted correctly
Jun 26, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel DD605I Dishwasher Logo
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
