Question about Ovens
Can I use a 240v .06A fuse in MW insted of 5kv .06a?
    Problem Solver:
  • 8 Answers
6 amps is 6 amps regardless of voltage. the 5kv is a higher quality fuse but when down grading the rating will offer same fault current protection. this does not work in the reverse scenario as the lower rating fuse can suffer a flash over after it has blown in higher voltage circumstances.
Posted on Mar 15, 2011
RBD245PD fuse?
No I think the power surge has destroyed the main control board.
Oct 10, 2016 | Ovens
Lights come on but no heat from eyes or oven?
Hello, I really need the make/model number to help you accurately but with the info you've described, I can tell you what to check first. 1st, some oven operating know-how--they operate on 240v AC. That means there are *2 hot wires, each with 120v*, a "neutral" wire, and a ground wire. To power up the control panel, the makers usually just run a wire up from one of the incoming AC supply wires, known as L1 and L2. Importance: it is possible to have the control panel work perfectly, lights and all, and have the problem you're describing--quite possibly THE OTHER 120v supply wire has become disconnected, either at the back of the oven where the terminal block is located, or at the 240v outlet on the wall. Also, the heavy cord with the plug on the end might have corroded/broken/burned up, so check it, too. Also, check that 240v is *getting* to the 240v outlet--this will tell you if the problem is at the panel box or at the oven-end of things. An old outlet might hold one blade of the plug tightly and the other will be too loose to make a good connection. BE CAREFUL WHEN CHECKING ELECTRICALLY HOT CONNECTIONS--240V WILL KILL YOU, DEAD. Make your movements deliberate, be focused, take your time. If you are hesitant about any of this, call for service! I hope I helped you!
Sep 02, 2015 | Ovens
How many amps does a 4.25 Kw oven draw
you state what voltage
38.63 at 110v
17.70 at 240v
Mar 13, 2015 | General Electric Ovens
Where is the breaker to the oven is it a certain breaker that controls the oven or s it the breaker controls the house like the lights and the TV and the main things that controls the house
The breaker for the over is normally in the main house fuse panel. Be very careful when working on any electrical feed for your oven, that is normally a 240v outlet.
Dec 24, 2014 | Frigidaire Ovens
What size cable and fuse do I need to run a Neff oven 3.68kw. and induction hob 7.2kw together ?
Divide the total load by the volts available ie. 11kw by 240v or 110v, the result is current in amps. You need a cable of a suitable cross section to transmit that amperage. There is also a distance calculation to be considered as this affects the available load. Get a sparkie to guide you as to correct sizing.
Nov 04, 2014 | Neff Ovens
I have an alaska micro wave oven series MW 1000 GC and I need the users guide of this appliance.
i need alaskar mw 1000g electrical diagrame and how find out to trouble shooting... thanks very much..
Feb 01, 2011 | Ovens
I need to know the circuit breaker fuse size for a flavel milano ML6CDS electric cooker and the cable rating
If your power suply is 240V and the power rating of the ovenis 9.9kw then the expected current consumption is 9900w/240v = 41.25A. Therefore this needs a 8mmsq cable or if not available in your area then use 10mmsq cable. And for the fuse or circuit breaker use 50A
Jun 14, 2010 | Ovens
The element has been replaced but when the previous one was removed, the mains electric was left on and fused the main oven light and fan
who in hades left the mains on?! do they have any brain cells between their ears!!? if it's 220-240 (if you're in Europe, prob. 220-240) a wonder you don't have a smoking corpse in your kitchen! us yanks use 220-240v for dryers and stoves, but have 2 120-110v breakers, usually, to shut off 220-240v appliances. sometimes 2 110-120v breakers locked together, so they are both shut off at the same time! seems as if something was connected incorrectly- and fried your fan and light! may need to replace fan & light, and, possibly wiring! unplug the dam thing first!!
good luck!!
Oct 19, 2009 | Neff U1863 Double circotherm super...
DIAGRAM FOR A ELECTROLUX EOG600BN
240v mains powered soloniod for the oven is probably burnt the only other possibilities are the cooling fan on top or even the reignition unit on the top
Aug 21, 2009 | Electrolux Ovens
Ovens Logo
261 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
