Question about HP LaserJet P2055d Printer
When i issue a print command it wouldn't print but state that the out put bin is full what are the possible solutions
    Genius:
  • 1,089 Answers
The sensor that monitors the output bin is broke, jammed or missing.
At the top of the printer where the paper exits and lays flat. There should be a plastic rod that goes from one side to the other.
It has rollers on it to pull the paper out. There should also be a black plastic flag that goes up and down as paper comes out of the printer. Use a flash light if you have to. Move the flag with your finger up and down. It should almost float. If it is stuck in the up position it causes the printer to think that the output bin is filled up with paper. If it is stuck push it down gently. Make sure that it lifts and that gravity pushes it down.
Posted on Mar 16, 2011
How to output bin empty ?
  1. The output bin may be full. Empty the output bin. Printing resumes automatically.
  2. Take a close look at the flaps hanging out the exit of the printer. They should move up and down freely. If one of them is stuck up, broken or dislodged, then a bin full error is displayed.
  3. Open rear exit tray and power on the printer. If the printer comes to a Ready state, close rear tray and try printing.
  4. Clean the paper path below the toner area and exit assembly at the back of the printer. Ensure there is no pieces of paper stuck in the paper path of the printer.
Jan 20, 2015 | HP LaserJet 5200 Printer
HP Laserjet 5200 top bin full
Hi, Remove all the papers from out put bin & check if not solved remove both side and top covers absorve right side of the out put bin flag sensor clean it with high pressure air or clean with dry cloth gently. Best of luck...Vinay
Apr 18, 2011 | HP LaserJet 5200 Printer
The output bin is where the paper comes out and stacks up after being printed. It is possible the sensor lever is stuck, or there is physically too much paper in the bin.
Mar 15, 2011 | Toshiba Office Equipment & Supplies
Install this freeware: http://www.fantasticfreeware.com/index.php/applications/stalled-printer-repair/ .This gem will clean your stucked Print Jobs, if any.
Mar 15, 2011 | Office Equipment & Supplies
When issue a print command, instead of print as expected it gives out this note: Output bin is full, Remove all paper from bin. what can I do?
Check out the arm that rides on the paper as it comes out. It may be stuck so that the sensor is covered. Or it may be that the sensor has some dust on it, so that it reports bin full. Check the arm and also as a precaution use some canned air and blow out the area where the sensor is located. Be careful with the air and don't let it move anything out of place.
Feb 26, 2011 | HP LaserJet P2055d Printer
Will only print maybe one page of a 4 page document and sometimes wont print at all
Below are 3 possible solutions.
Unexpected page breaks occur
Cause Solution
Job has timed out.
Set the Print Timeout to a higher value:
Blank pages
Cause Solution
Toner is low.
Remove the toner cartridge from the printer. Shake the cartridge back and forth several times, and then reinstall it.
Install a new toner cartridge.
Toner cartridge is defective or empty.
Replace the toner cartridge.
Jobs do not print
Cause Solution
Printer is not ready to receive data.
Make sure Ready or Power Saver appears on the display before sending a job to print. Press to return the printer to the Ready state.
Specified output (exit) bin is full. Remove the stack of paper from the output (exit) bin, and then press .
Specified tray is empty. Load media in the tray.
Wrong printer software is installed.
Verify you are using the correct printer software with your printer.
If you are using a USB port, make sure you are running Windows 2000, Windows XP, Windows Server 2003, or Windows Vista and using Windows ME, Windows 2000, Windows XP, Windows Server 2003, or Windows Vista compatible printer
software.
Cause Solution
Internal print server is not set up properly or is not connected properly.
Verify that you have properly installed the print server and configured the printer for network printing. For more information about installing a network printer, click View User's Guide and Documentation on the Software and
Documentation CD. Copies of the printer software are also available on the Lexmark Web site at www.lexmark.com.
You are using the wrong USB or Ethernet cable, or the cable is not securely connected.
Make sure you are using a recommended cable.
Make sure the connection is secure.
For some reason Lexmark has not posted information for this model. If you need a manual you might try the C534 manual at: http://support.lexmark.com/index?locale=en&page=product&productCode=LEXMARK_C534&segment=SUPPORT&userlocale=EN_CA&frompage=null#2
Dec 10, 2010 | Lexmark C533DN InkJet Printer
How to reset password of pix 506e
You only need a PC and a serial terminal. First of all you need to know the PIX software version you run. After that you must go to Cisco web page and get from there the utility for the password recovery corresponding to your version of software.
After that you must connect to the PIX console port. Press ESC key after the PIX is booting and a special prompt it will appear (monitor>). Issue the "interface" command to specify which interface to be active. Inside interface it will be the default one. Then use the command "address" to go with the IP address of the above interface. After that, you will need also an TFTP server where you must upload the software utility specified in the beginning of the solution (the one downloaded fron Cisco). After the "address" command, issue an "server" command to put the IP address of the TFTP server. Than, use the command "file example.bin", where the example.bin is the file downloaded from Cisco. Maybe you will need also to specify the gateway of your network. This you can accomplish by using the "gateway" command. Finally, use the "tftp" command to start the download.
The default Telnet password after this process is "cisco."Go into configuration mode and issue the passwd your_password command to change your Telnet password.
Best regards,
T
Apr 24, 2009 | Cisco Computers & Internet
Staples SPL-1506X Shredder Issue
I had the same problem. I have a solution but I do not recommend this unless you have technical experience with repairing electrical appliances. I took the back cover of the main shredder unit to expose the wiring (there are 7 screws in total). The bin full sensor has a blue, green, and red connected to it. I clipped the blue wire to defeat the Bin Full error. You can look through the plastic window to check that the bin is full.
Apr 25, 2008 | Office Depot Ativa DQ60M Shredder
HP LaserJet P2055d Printer Logo
229 people viewed this question
Seeker5211
Seeker5211
