Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
Turn on wont ignite if does smokes take top coveroff works fine
    President:
  • 1,654 Answers
Must be starving for air then, check and make sure it is clean and unobstructed and air can get in around the finns to the flame. Is the blower fan running? I assume so if it lights.
Posted on Mar 15, 2011
Truck wont turn over but might after several tries
Sounds like the solenoid is not engaging. I would pull the starter and change the solenoid on the top of the starter. Be sure to disconnect the battery cable before working to remove the starter. Hope this helps.
Mar 05, 2014 | 1995-1997 Chevy 1500 Truck Ignition...
2002 grand cherokee engine tapping loudly
My first guess would be a failing valve lifter. They can become weak with age and not able to hold oil pressure.
Especially in an engine with that many miles on the clock.
If the noise is constant you may be able to find out which cylinder by running a compression test. maybe.
Apr 08, 2013 | 1997 Jeep Grand Cherokee
No power to ignition or dashboard?
I don't have a wiring diagram for a 96 model, but 99 and newer models have a 40amp and 80amp maxi-fuse that powers the charging and ignition systems including the switch.
You need to make sure those fuses are good by checking both sides with a test light.
Sep 21, 2012 | 1996 Kia Sportage
Gas oven won't turn on, stove top works fine.
check if the igniter is getting a 110 volt power if yes replace the igniter
Sep 05, 2011 | Kitchen Ranges
My 2003 sunfire wont start its getting fire and gas and it turns but wont start why
Please consider following matters:
1. Ignition. Blue color fire is the the best ignition power 2. Gas. Check your fuel filter and injections 3. Compression. Combustion chambers should have enough compression to start the engine. Does your car lost its compression? Is the car has blue smoke on exhaust muffler ? Do you need top up oil regularly? All these things show your car has problem with compression.
Nov 26, 2010 | 2003 Pontiac Sunfire
My 1990 Cadillac Deville wont start or engage starter
Sounds like you blew fuse. Fix fuse and borrow a car starting switch they use at car repair shops. As long as you can turn tumbler to on ,you can start using the starting switch from repair shop..There should be a way to run a start button to start car and your off/on key should be OK
Ron
Feb 17, 2010 | 1991 Cadillac Seville
Engine runs wild with white smoke
If its a 4JX engine then its injectors and seals at fault dont run it any more cos it may blow up - like rods through the side !
The diesel is going straight into the engine without being injected and as the fuel lift pump is mechanical it wont stop on the key .
Should be under isuzu warranty though they are doin that repair on 1998 Troopers over here for free .
Apr 04, 2009 | 2002 Isuzu Trooper
All Pro 170t kerosene heater is throwing raw fuel out the burner
It sounds like it is currently working .. is that right? Or does it only work if you let it sit for an hour, still? The blue smoke probably is from the residual fuel not burnt when it "threw raw fuel out the end" some the fuel probably drained to a low point ..outside of the combustion chamber and then may have ignited after shut down.. to cause the blue smoke out the back... when you turned it off.
If when your starting it up... it doesn't start the first time.. wait 10seconds then try again.. noting what it apparently does.. and doesn't do. does it just 'through fuel for 5 seconds.. does the fan spin .. and push air at the same time when its starting? If yes for both, does the ignitor ignite the fuel/air mixture, briefly then it shuts off.. ?? Hope this line of thinking helps you out
md
Dec 31, 2008 | All-Pro Kerosene Garage Shop Heaters - All...
THE HEATER STARTS THEB BLOWS ALOT OF SMOKE
There are any number possibilities for intermittent running.
1. Bad ground connection at the Ignition Device (transformer, spark box)
2. restricted fuel filter causing fuel starvation
3. crack in the plastic end cover
4. crack in the airline
5. crack in the fuel line
6. crack in the nozzle adapter
7. water in the fuel
8. Others I’m sure I left out
You must be the one to troubleshoot & find the cause.
Follow these troubleshooting tips
Dec 21, 2008 | Reddy Heating & Cooling
Key wont turn to Ignition point
you need to buy a new ignition tumbler
Dec 14, 2008 | 2000 Volvo S40
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
70 people viewed this question
Top All-Pro Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Mack Baxter
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
