Korg X5d Logo
Posted on Mar 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, my korg X5D have malfunctioned pitch bend and modulation wheels. They dont respond in any way, not even when i try to calibrate them.... What should i do ? Also, this is absurd question maybe, but on the downside of my X5D, little sticker says model : X5, and when i start the keybord, in the welcome message also says X5. But the whole case (plastic) is X5D case. Is there a chance that seller tricked me or this is standard on all X5D ??
Mosh
Level 1:
New Friend:
  • Contributor 41 Answers
  • Posted on Jun 12, 2011
Mosh
Contributor
Level 1:
New Friend:
Answers
41
Questions
0
Helped
18493
Points
63
The pitch and modulation wheels are on a separate circuit board, if they both stopped working at the same time, it's likely the connecting cable has dislodged.
Opening an X5(D) is relatively simple and you should be able to simply plug the cable back in. If you're not comfortable doing that, take it to a shop.
Fred Yearian
Level 3:
  • Korg Master 5,603 Answers
  • Posted on Mar 16, 2011
Fred Yearian
Korg Master
Level 3:
Answers
5603
Questions
Helped
2250463
Points
16163
You can't always believe the display in regard to the model... Try finding the revision level display that will tell you what you have... It is NOT likely a seller would strip a X5D case to try to fool you.
Find what the difference is in the model and test your unit for that feature.
When i star or on my korg x5d the display are just like cherismas light it does not finishe inistalation and logo of korg x5d then it will be empity lignht scren
How to Initialize (reset), and preload on the Korg X5/X5D/DR Initialization: Hold Page + and Page - while turning it on.
Preload: Global Screen 5A, then select "OK".
ROM Check: Hold Edit and Global/Multi while turning it on.
Apr 17, 2016 • Korg Music
1helpful
How to save x5d sounds in laptop
if you do not already use a midi sequencing software try "Bome's SendFX". After installing, go to X5D menu 04A MIDI DUMP, choose data you want do dump (e.g. "all"). Make sure, that no SYSEX FIlter is active while working with a sequencing software.
After transmission, you can save the "yoursounds.mid" file and send it back to the X5D later.
Apr 19, 2014 • Korg X5d
The pitch of my korg x5d is D#, how can i get it back to its original set up
Press:
1- GLOBAL
2- PAGE+ or PAGE- ,untill the display show "TRANSPOSE".
Set the value to "0" using YES / NO or VALUE slider.
Apr 11, 2013 • Korg X5d
Hello my Korg X5D on switching on shows 00:Initcombi0 on top display and "battery low" blinks on lower display, Keys from 33-40 are malfunctioning ( giving odd sound) other keys are working...
There's a watch type battery (flat disc) on one of the boards inside the X5D. This maintains the settings while the keyboard is switched off and could be the whole problem.
The keys are on two different circuit boards connected with a multi-pin cable. If the cable were dislodged I would expect it to simply cut off half the keys but it's probably worth checking.
Oct 30, 2011 • Korg X5d
1helpful
How to turn on en off the moulation of a korg x5d
For Combi/Multi patches you can disable control changes for each sound under EDIT 6D but this also switches off other control change instructions (pan, expression, pedal etc.).
Somewhere under GLOBAL settings you should be able to find the modulation wheel Depth setting and set it to 0 which should stop your mod wheel from working but you could achieve the same effect by just keeping the mod wheel pulled all the way down.
Jul 28, 2011 • Korg X5d
Hi. My Korg X5d shows a sequence of small squares in the display panel and will not boot. Can you help?
You need a reprogramming done from the Maker . Contact Authorized Korg Service center . Be away from frauds.
Nov 18, 2010 • Korg X5d
When I play the sound come out distorted, like it untunes. any idea what is causing the problem? this is a for a Korg X50 and is only 2 yrs old. not korg Ma30
The manual is at:http://www.korguksupport.co.uk/upload/X50_OpGuide_E1.pdf if you don't have one. Try saving everything you want to save first if you know how to do that. Then initialize the keyboard. Follow the instructions on page 111 carefully. It sounds like you created an undesirable effect and accidently assigned the Pitch Bend Lock function to the effect. This parameter is explained on page 41 under Pitch Wheel Mod Wheel. Hope this helps.
Aug 19, 2009 • Korg Ma30
Top Korg Music Experts
john h
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Korg Music Expert? Answer questions, earn points and help others
