Question about Buffalo Technology Buffalo LinkStation Pro Duo 2TB NAS (LS-W2.0TGL/R1) Network Storage Server
My hardisk doesn't recognize in my computer but appear on device manager and disk managemnt
  • 1,381 Answers
Hello raissateddy
Go to the Control panel and select " Folder Options \View " and check " show hidden files , folders and drives " .
Best regards ,
fanaudi .,
Posted on Mar 15, 2011
Doesn't work, cable problem, don't recognize
Get another lead
Some external storage devices work poorly or not at all when connected to a hub; try connecting the drive directly to a port on the computer. Also check if it's detected in "Disk Management". Here you can verify if the partition and format are correct for the Operating System. Check the Drive's status in Device manager. This will verify if the external drive has a drive letter designation. Check Partition and Format. Log in as Administrator account in windows or any other account with administrative privileges Insert your removable disk into the USB port. Click Start, right click on computer and select manage. Now, click Disk Management. Check whether drive letter for the device is present. Check the lower window to find whether the device is detected (such as Disk 1, Disk 2, etc). If the device is detected with a drive letter, verify that no other device is using that drive letter. If it is, change it to unused drive letter. Hope this helps.
Jan 09, 2013 | Toshiba Canvio E05A050CAU3XW 500 GB...
My external wd elements not reading and the light in the hardisk is on but not blinking
Could have picked up a virus from your friends computer, or the device is just on the fritz. It also could have been corrupted. When removing an external hard drive you should always go to the bottom right click on the little green arrow icon and select "safely remove <your device>" otherwise you risk corrupting the files on it. Plug in the hard drive to your computer. Right click on Computer/My Computer and select Manage. Click on Disk Management on the left side. If your device shows up then the drive most likely has corrupted files or the file table. Right click on your device and initialize it if it isn't and then format the device and it will work again. You will lose all your data in the process. You can download Recurva from piriform.com to try and recover your files if you like. If the device doesn't show at all in disk management then I'd say its toast.
Dec 01, 2012 | Western Digital Computers & Internet
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
The device is simply plugged into a USB port on your computer as you would connect a flash drive.
Unlike a flash drive, however, a USB hard drive can store a much larger amount of data.
If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely.
Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7).
The USB device should be listed as "removable disk" once it is plugged into the computer.
If it is not listed among the available drives on your computer, proceed to the next step.
Ensure that the data cable is working properly.
Try another USB cable if you have one available.
Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive.
Reboot the computer if the USB hard drive is still not recognized.
Plug the USB cable into another USB port and check to see if the device is detected.
If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port.
If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem.
Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager."
For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter."
Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives."
If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears.
The external hard drive may have been detected but the device is not working properly.
If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Hope this helps
Nov 07, 2012 | Computers & Internet
I have 2gb verbatim flash drive.It worked fine when i first used but next time my computer recognizes it as a removable disk. After some hours i tried again and for some reason it worked. While i was...
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
click start click on my computer you should see your drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your drive select format
hope this helps
Jul 03, 2011 | Verbatim CORPORATION 94933 USB 2.1GB...
Windows XP SP3 does not recognize the screen size of 1440x900, or any resolution other than 1024x768/800x600 It's a Westinghouse L1975NW, running off an Intel 945 Express Chipset
Problem might be with your graphics drivers
Confirm by following process
Right click on my computer and then click on Manage.
then Choose device manager from left panel of the window
then list of hardware will appear.
if there is exclamatory mark over your graphics drivers then right click on it and then click on update device software
if it doesn't work then install it from your drivers disk, you got it with your motherboard.
May 17, 2011 | Westinghouse L1975NW Monitor
CD driver do not read any file
Does it recognize any cd you put in the drive or is it only one cd it doesn't recognize?
Please check if the cd drive is recognized by your computer:
Click Start go to My Computer (XP) / Computer (Vista/Win 7)
and check if you can see the drive. (if it's not there you may have to reseat the drive to make sure that the cables connecting it to motherboard are tight)
check the status in the Device Manager:
On your Keyboard press and hold the Windows Key then press the letter R
once the Run box comes up type in devmgmt.msc and the device manager should appear.
On the device manager look for the cd / dvd drive see wether it has an exclamation point a red x mark or a down arrow or it looks normal.
if it has a yellow exclamation point press and hold the windows logo then the letter R again and type regedit:
On regedit go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} and the delete the upper and lower filters. Close Regedit and restart the computer.
if it has a red x mark right click on the cd drive in the drive in the device manager and the choose uninstall and restart the computer.
If it has a down arrow right click on the drive and click Enable.
If the above steps doesn't work or if it doesn't recognize all types of media you put in it, that might mean that your cd drive is busted and it needs to be replaced.
Hope you find this helpful!
Apr 30, 2011 | LG CRN 8245B (CRN-8245B) Internal 24x...
Hard Disk drive do not appear in Disk Management & Device Manager
to fix the problem you must open your laptop check the hardware inside of your laptop hardisk thats the problem try to unplug cables of hardisk to plug again or replace new hardware hardisk if not solve the problem
Jun 18, 2010 | Lenovo 3000 Y410 Notebook
No bootable devices
go to BIOS MENU by pressing Del or F2 while booting...then check the boot priority and first boot device..change it to hard disk...if then same problem occur then your hard disk might have some problem...
Jan 23, 2009 | Dell Inspiron 2200 Notebook
USN external harddisk
You shouldnt need drivers unless its a Windows 98 PC. Right click my computer and select manage, when the box pops up select disk management. You should be able to see the drive and format it for use.
Dec 30, 2008 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Buffalo Technology Buffalo LinkStation Pro Duo 2TB NAS (LS-W2.0TGL/R1) Network Storage Server Logo
394 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
