Question about Gateway CX2724 Notebook
I need to change the SATA on the BIOS of my gateway CX2724, but when I go into the System Setup (F2), I cannot go down to the SATA section. What can I do to change this? Right now, this PC is trashed, as it started the restore, then stopped.
  • 33 Answers
Do you have a new drive installed in the system right now. If not you need to change the drive and it should detect it automatically. If you have it install and it is still not detecting it you need to go into the bios and select auto detect or auto for it to find the drive on its own. The reason that you may not be able to access this setting is that auto detect is already activated. Hope this helps with your issue.
Posted on Mar 15, 2011
Gatewat CX2724 original HD died (Hitachi 100GB @5400RPM) I just installed a brand new WD 250GB @7200RPM. Since I didn't have the original recovery disk I'm trying to install a full version Windows XP...
if you have a new hard drive you will have to install the windows operating system from an external source such as a cd drive
go to bios --boot settings and change from 1st boot hard drive to 1st boot cd
install the win os and then you can install the rest
when finished go back to bios and -boot and change back to 1st boot hard drive
Apr 24, 2017 | Gateway CX2724 Notebook
I installed a Western Diginal SATA 1.5TB in my Gateway GM5084 PC and now it's in a loop at boot and won't boot Windows. I go into BIOS and disable SATA and all is fine. Any ideas?
From what you wrote, it sounds like Windows is trying to boot from this new drive instead of your old drive (which has the Windows operating system on it). If this is true, then you need to go into BIOS SETUP and change the boot device priority so that Windows will look at your old drive before it looks at the new one. When you first power on your computer, start tapping the DEL key (on some PC's it's the F1, F2, or F10 key) until you get into Bios Setup. Then use the arrow keys to navigate to your boot menu and reset the boot device priority. (Normally your CD drive is set as the first boot device and the hard drive with your operating system is set as the second device.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
Jan 22, 2011 | Gateway GM5084 PC Desktop
The screen color is off on a gateway cx2724
It's probably hard ware related but we should try updating the video adapter driver to double check.
You can get them HERE.
Download, install, reboot. If the problem persists or if it occurs in the boot up bios screen it is for sure hardware related. In most cases the lcd needs to be swapped.
May 22, 2010 | Gateway CX2724 Notebook
I can not setup windows xp in my dell latitude e6400 laptop.I set BIOS (F12), select "System Configuration", "SATA Operation" and i change it from "IRRT" to "ATA. But no work.When i start windows xp setup...
Try this hints:
1.Press F2 to enter BIOS on start up
2. Expand Drive section
3. Go to SATA Operation
4. Check and change from Raid Auto/ AHCI to Raid Auto/ATA
Good Luck
Apr 11, 2010 | Dell Latitude E6400 Laptop
Hi, I have formatted the SATA hard drive in my Gateway GT 5408 with Intel motherboard D945GCFG1. I want to load XP pro instead of the original Vista which was on it. Do I need to change the Bios or install...
No, you do not need to install a new driver as long as that is the same sata hard disk tha used to work in your Gateway computer. Just boot into your windows xp installation cd and let the setup continue.
Should you need further assistance, please let me know.
Mar 08, 2010 | Gateway GT5220 PC Desktop
My Gateway CX2724 will not install a fresh copy of XP on new Harddrive. HDD is a newly formatted, and the BIOS is set to recognize CDROM, HDD, and so on. The SETUP is still stating that it can not see the...
You need to go into the BIOS and change the SATA type to IDE and not AHCI. I had this same problem on my laptop. Once I switched it to IDE it installed XP no problem. I don't know if Vista or 7 work with it set to IDE mode.
Nov 28, 2009 | Gateway CX2724 Notebook
I have installed a new hard drive in my laptop gateway cx2724 and put in the os xp . it tell me i have no hard drive installed.
the BIOS needs to recognize the new drive. Check with gateway web site under support for note on upgrading the HD.
Sep 13, 2009 | Gateway CX2724 Notebook
0x0000007b (0xf78d2524, 0xc0000034, 0x00000000
Try resetting the BIOS to default. or
1. On start up, press the F2 or 'Delete' key to enter the BIOS menu.
2. Expand the "Drives" section
3. Go to "SATA Operation"
4. Change this from "RAID Auto/AHCI" to "RAID Auto/ATA".
Jul 17, 2009 | Gateway Computers & Internet
A new hard drive
The sata connector was probably disabled in the BIOS to prevent you from getting a missing drive error on startup before this was installed. Press F2 at the Dell Splash screen to enter BIOS setup, come down to Drives and change the setting for the sata connector to ON. When you reboot go back into the BIOS setup and it should report the Drive ID and capacity.
Dec 28, 2008 | Dell XPS™ 600 PC Desktop
Gateway CX2724 PC Notebook Problem
operating system of your pc is damaged so reinstall the os again or recover from the recovery CD
Jun 17, 2008 | Gateway CX2724 Notebook
Gateway CX2724 Notebook Logo
96 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
