Question about Fuji Photography
Do you have black and white film and paper processing chemicals?
How can I print only black and white
If you're printing the photos yourself and it's film then you have to use black and white film, chemicals and paper. Otherwise, shoot black and white film and send it to a photo lab. If you're talking digital then you're in the wrong catagory here. This is film cameras only.
Jan 29, 2014 | Photography
Can you still use a sd card for a film camera
No. The film must be processed chemically in order to make the pictures visible. Once processed, the film can be scanned and the digital images can be treated the same as any digital photo.
Nov 30, 2013 | Minolta Maxxum 700si 35mm SLR Camera
When using a film camera can you use a sd card to store the pictures that are taken
Are the same chemicals used to develop color pictures as black and whites?
They are very similar but the black and white process uses developer, stop bath, fixer and water while the color process uses developer, bleach, fixer and stabilizer.process for black and white process for color
Aug 19, 2013 | Photography
How can i know how a photo is made ?
a photo is made by a radiant energy on a sensitive surface to be technical. but it regular term it is light(radiant energy) on film, photopaper, or a digital sensor(sensitive surface). after one interacts with the other it is either processed with chemicals for the paper and film or 1's and 0's for the sensor... at this point the paper is a photograph and the film can be printed as well as the digital image my be viewed on a device or printed as well.
Nov 06, 2012 | Cameras
When people say I need film or photo paper for the polaroid, is the film the same as the photo paper?
The polaroid One Step uses what is called pack film. It is layers of paper with chemicals sandwiched between, After exposure, the fild is pulled out between rollers that spread the chemicals over the photo paper. When seperating the photo from the paper covering, the chemicals are taken away with the discard.
Oct 26, 2010 | Polaroid OneStep AutoFocus Instant Camera
My canon IR 2018 copier is giving me system error 007
hi;
its a fixing film problem, your fixing film is not spining properly maybe its paper jammed inside try to clean paper jam carefully else you order new fixing film from canon
good luck
Oct 20, 2010 | Canon iR 2016i Black and White Copier
I don't know how to buy film for this camera. is it just 35mm 400 film
Yes, you can get 35mm in color negative or black and white. Although the black and white film may be in 2 varieties: traditional process black and white(not all labs can process this) and C-41 process black and white (and one hour lab can process this). If you are looking for color film choose the C-41 color negative film like Kodak gold 400 or Fujicolor 400.
Mar 28, 2010 | Nikon N65 35mm SLR Camera
Pictures
It's quite complicated to explain in detail, and there are a number of different processes, but I can start by saying how the essential chemistry of B&W processing works.
A film emulsion contains tiny crystals of a silver halide (Silver chloride, bromide etc.) contained in a layer of gelatin, coated on a plastic backing. Silver halides are sensitive to light.
There are other layers such as an anti-reflection layer behind the light sensitive layer to prevent light being scattered back to produce a 'halo' around bright areas, (Anti-halation layer) and a scratch resistant layer on the front.
Additionally dye chemicals are added which enhance the halides sensitivity to red light, to which otherwise it would be insensitive. These are known as dye sensitisers.
Only imprefections in the crystals are actually sensitive, as these contain silver ions which are not fully bound to the halogen. When a photon interacts with the crystal near the sensitve site an electron is released which can reduce the ion to a single atom of silver.
These single atoms ar enot enough to produce a visible image, but comprise a latent image within the emulsion. In order to make the latent image visible we must amplify the latent image in some way. This is done chemically by a process known as development.
There are a number of chemicals formulations which can be used as developers (including urine!), but all are chemical reducing agents. (Opposite of oxidising agents.) These convert the silver halide to metallic silver.
It so happens that for many reducing agents metallic silver acts as a catalyst, so where there is silver the reaction proceeds faster than where there is not. Of course as more silver is produced the greater the catalytic action, so the develoment process accellerated as it progesses.
This forms clumps of silver around the original silver atoms. These clumps consist of very small grains of silver, finer than any powder and these appear black. These form a negative image. (Black where light fell on the film.)
(These tiny grains are not what photgraphers refer to as 'grain'. In fact the 'grain' in a photograph is more to do with the distribution of development sites, and the random nature of the arrival of individual photons.)
Most developers are realtively benign chemicals but some are toxic and carcinogenic. These are not used much these days but are still availble.
Unfortunatley this is quite a slow process, and there is a tendency to also reduce unexposed halides somewhat. This produces an overall 'fog' to the immage. To minimise this and speed the process up an accellerator is usally added.
Accellerators are alkalis. Some formulas use quite strong alkalis like sodium hydroxide, but others use rather innoccuos substances like borax.
Development continues until the developing chemical is removed or the chemicals are exhausted. If the film is developed too much than the silver clumps begin to overlap and you get a completly black area. Further development does not make those areas any blacker even if more silver is produced!
This process is of course conducted entirely in darkness.
Most formulations use both developer and acellerator together, but sometimes these are used separatley to give better controll of the negative density. Here the emulsion is soaked in the developer, and transferred to the accellerator bath. This limits the amount of developer in the negative so heavily exposed areas do not develop as much. This allow a scene with a wider range of brightness to be recorded.
(Note that the film itself can record a much wider range in the latent image, than can be developed.)
Normally development is stopped by immersing the film in an acidic bath, which reacts with the accellerator as well as washing away developer.
The anti-halation layer dyes are usually washed out during develpment.
Of course this still leaves undeveloped silver halides in the emulsion. These are removed by fixing the image.
This is necesary for two reasons. First in a film the halide crystals have a whilte milky appearance. You need light to shine through a film duing enlargement, so that's no good. Alxo the halide will eventually turn black on exposure to light.
Fixing the image usually is a matter of washing the negative in a soultion of sodium thiosuphate. (Comonly called 'hypo'.) Silver halides are only very poorly soluble in water, but sodium thiosulhpates affinity for soft metal ions overcomes this reaction with the silver, to produce sodium halide. If this is silver chloride you get salt!)
To get a print, you expose paper treated on one surface with an emulsion, to a projected image of the enlarger and develop that in a similar way.
So there you have it. Color is a bit more complicated involving layer with different sesitivity to colored light, and dyes which are produced by the action of delvelopers.
For more details start with http://en.wikipedia.org/wiki/Photography
Jan 13, 2009 | Fuji Endeavor 200ix Zoom APS Point and...
Maxxum camera no color
I think your camera had a microchip in it that changes modes. I could be wrong, I can't remember exactly what model it was. Take the chip out or reset it in the menu. How old is the film you are using? There is some film that is color film but a black and white emulsion. That can be developed in color processing.
Jan 04, 2009 | Minolta Maxxum 300si 35mm SLR Camera
Photography Logo
113 people viewed this question
Top Fuji Photography Experts
TC CAMERA REPAIR.Com...
David Payne
David Payne
Are you a Fuji Photography Expert? Answer questions, earn points and help others
