Question about Toshiba 57H82 57" Rear Projection Television
Please help The TV has a distorted picture for about the first 10 minutes. It also is loosing sounds on some of the channels. It is not the cable connection, I checked that.
  • cwordwoman Aug 03, 2008
    When set is first turned on the picture is scrambled. After about 10 minutes the picture is wavy and jumps continiously. Cable connection and electrical outlet check out okay.
  • 4 Answers
I had the same problem and I have just finished replacing the caps and tv works like new! :-)
It was my first time at soldering and it was very tricky. I actually was surprised that the thing didn't blow up when I turned it on! lol!
Cost of repair: $7.50 for the caps including shipping from Digi-Key.com and about $40 of soldering toys from radio shack
Posted on Aug 02, 2008
    Genius:
  • 1,030 Answers
The chances are you may have what is called a bad hypermodule. it is a signal board that controls signal processing. does the picture apear"wavy" then clears up. The way to repair this is to repair this board is to replace 11 microcaps. NOT EASY technicians have truble with this repair... twezzers and manifying glasses. ideally the best thing to do is to replace this board... but they are very rare and difficult to find. so if you can find a good tech that can solder microcaps or if you can find the board those will be the options
Posted on Aug 01, 2008
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
We have a LG42lx6500. when you turn it on after being off for a few hours the picture colour is distorted for a couple of minutes before correcting. At times you can see the individual pixels. Sometimes...
Hello
Make sure TV is on the correct channel or input. Check the cables for correct routing from TV to any other devices. Check cables to ensure they are tight and secure.
An analog signal converted to high defintion resolution will cause lines, blurriness or fuzziness in the picture. Change the resolution to a lower or native setting using the media device (cable box, DVD,). This may be an issue that requires a service call to cable provider.
A problem on one channel may just be a error on that channel. If using an antenna, it might need to be adjusted in order to ensure good signal strength. For digtal channels, go into TV Menu. Check the DTV signal. Weak signal can cause picture distortion.
If another device is being used such as a cable box, DVD player or VCR switch between devices and test picture. Check routing of cables that are used to control the image. This should be a series of red, white and yellow cables.
If a VCR with a cable box, make sure the VCR and TV are set to the correct channels for video signal to pass through. If problem is still occuring, try another set of cables. bad cables can cause picture distortion.
Bad cables can cause picture distortion as well. Try another set of cables. If picture is better than when using the cables replaced, this was the issue. If cables are not an issue TV may require service.
Apr 26, 2011 | LG Televison & Video
50' philips plasma tv has sound but picture is distorted
I sugest you to change the video resolution settings on the PS-3 to see if TV sets to any one resolution...if you have any other video out (analog from PS3)...connect the out to TV and check video at different resolutions. If PS3 has Deep Color settings turn it OFF.
Apr 10, 2010 | Philips 50PFP5332D 50 in. Plasma...
Sound not picture
A few questions:
Are you using this TV directly on a cable line of do you have a cable box or satellite receiver connected?
Do you have sound and no picture on the AV inputs as well, or only on TV channels?
Is there anything on the screen or is it completely black? Has the picture collapsed to a single line across the screen? Is there a picture but it's distorted?
Does the on-screen menu and channel number display properly?
With a little more information I might be able to help you with this.
Feb 11, 2010 | Toshiba 32A33 32" TV
Picture goes black but sound is good after tv is on for 10 minutes, please help
Please check if exchancing powercord helps and preferably to other power connection.
Do check your signal generating device
Antenna - RF ?
Set top box (Cable or satelite)
DVD or VCR for broken connection.
They could be the cause also and not the TV.
A broken soldering on a euroscart connectort is treaseurous on a VCR or so. I open those up and check scart connectort on board solderings or check cable for loose connections.
If nothing there or you not technical enough call in a handy guy from the block before cleaned out.
Pls do not open your TV set, that gets ugly.
You like my advice, rate me, i am doing my best
May 06, 2009 | RCA HD52W59 HDTV Projection Television
Sound
I do not have a Zenith B25A02Z TV. What I do have is a 1988 Zenith Color TV SE2517P. I called a local tv repairman and discussed the problem over the phone. He can take a look at it if we bring it in (service call to the home cost $100 just to show up). He said it was worth fixing since he thought it was only the sound. We have a great picture. He charges $20 to look at it but we have to leave it. He lives 20 minutes away one way. We think it is worth the trip if we can get it loaded into our minivan. We live in western NY where the weather can get pretty ugly many days. I will post the solution later when I know. FYI
Dec 30, 2008 | Zenith B25A02Z TV
SONY BRAVIA HIGH DEF KDL-26M3000
This TV is almost 8-10 yeas old, in that time the HDMI specification is not firmly set, the problem in most of the case is compatible problem. You may log in SONY website, try to up date the firmware; in other possibility that the main board may be bad.
Oct 27, 2017 | Sony KDL-26M3000 26 in. LCD Television
TV blinks intermittingly
No you didnt answer the most important questions> When the tv"blinks" does the sound go on and off with the picture? Or does the picture go out to a black screen or a grey screen? or does the whole set seem like its shutting off and on again? or does ir seem like the tvs trying to tune in a channel but keeps going past the right frquency? Answer these questions and we can get somewhere.
Jun 17, 2006 | RCA F27645 27" TV
Toshiba 57H82 57" Rear Projection Television Logo
57 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
