What is the comressure pressure in 2ton **** ac
    Guru:
  • 1,524 Answers
That depends on the refrigerant used. R-22 or R-410A. You must be EPA Certified to use either.
Posted on Mar 15, 2011
My mitsu bushi ac 2ton indoor green led blinking for three times again and again what is error.
power supply problem contact to the expert you can not repair at home for more info please visit this link Phonetolls
May 20, 2015 | Heating & Cooling
Where will I find the oil pressure sensor on my 1988 chevy c1500, 1/2ton, 2wd, 6 cylinder, 4.3ltr?
It should be on top of the block, behind the intake, near the firewall.
Or above the oil filter on the side of the block.
The sensor is replaced, not repaired.
Feb 19, 2015 | Cars & Trucks
How i calculate 2ton window ac gas filling in kg
Please check the manual in which the total kg to be charged mentioned there.
The list and calculation differs to gas to gas and also depends on temp and PSI. Thanks.
Feb 04, 2011 | Heating & Cooling
Where is the oil pressure sending unit located
For 1989 Chevrolet Truck K1500 1/2ton P/U 4WD 4.3L TBI 6cyl the Oil Pressure Switch is located under hood, center, upper engine area, above transmission bellhousing flange, mounted in block.
Good luck (remember rated this post).
Apr 25, 2010 | 1989 Chevrolet K1500
Wiring diagrams
I suggest visit autozone.com (free register).
Good luck, and remember rated this help.
Mar 07, 2010 | 1992 Chevrolet C1500
What is the seer rating and tonnage of a bryant model fb4anf030
The Tonnage appears to be 2 1/2 ton,
024=24,000 BTU=2ton
030=30,000 BTU=2 1/2ton
036=36,000 BTU= 3ton
I dont think you have the correct Model Number, Look
on the outdoor unit, the model number might start with a 38. Hint Carrier and Bryant Products are the Same, just different nametag
Feb 17, 2010 | Heating & Cooling
I need to know the seer number for an air handler. I'd
On the air handler take the top panel off, look to the left on the inside, this will give you general information on the unit on a stampede plate. This will
give you the date of manufactuer as well.
On the outdoor unit, there is a stamped plate on the
condensing unit. Should have year of manufactuer, it
should also say how many pounds of freon should be
in it. The Model number is what you need to know
to find out how big it is.
024=24,000 BTU= 2ton unit
036=36,000 BTU=3ton
040=40,000BTU= 3 1/2ton
and so on.
My guess is that it is an older unit and since I have
been installling units since 1995 I have only known
any older units to be at least a 10 SEER and no more.
Feb 16, 2010 | Heating & Cooling
DURING DAYTIME WHEN HOT OUTSIDE 35-40 DEGREES C, AC TRIPs off
units are not able to work properly above 90, 1.0 T not go for more than 1 room. is outside of unit clean? if not turn off power to unit then spray 409 or simple green or something along those lines of cleaners on the coil part (soak it real good) it should cover entire coil as much as possible. let cleaner sit on it for about 10 minutes then use water hose to rinse as good as you can. wait about 10 minutes then try unit - so work better.
Jun 15, 2009 | Heating & Cooling
Heating & Cooling Logo
126 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
