Question about Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard Drive
My HDDR500E03A 500 GB is only showing 3.98 GB on total memory, what happened to the rest?
    President:
  • 2,080 Answers
The 3.98 GB you are seeing is probably your total RAM memory and not the storage capacity of the hard drive. RAM memory is completely unrelated to the hard drive capacities.
Double click on the MY COMPUTER icon.
You should then see all the disks and drives that are currently connected to your computer. Your USB hard drive should be one of the drives listed there.
Right click on each of them and select PROPERTIES from the menu shown. This will show you the storage capacity of each drive including how much space is used and how much is free (empty).
Good luck.
Posted on Mar 15, 2011
The hard drive don't running
Check connections. If that doesn't work, try putting it in a different computer. If that doesn't work it's probably broken.
Feb 11, 2012 | Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard...
I plugged my Hard drive in to the USB port on my laptop computer and nothing happened. The hard drive is a 500 GB Go and the laptop is a Toshiba Satellite A665-S5170. Thank you for assistance.
contact the dealer or manufacturer.
This is a frequent problem for portable harddisks.
Its a hardware problem,there's nothing much u can do.
u wont be charged if u are within the warranty period.
Jul 20, 2011 | Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard...
My USB showing all files as shortcut and i can not view my files, what to do
Your files is not totally corrupted or deleted
Just follow these simple but useful steps to recover all your files: 1. Download USB Show, here's the link.. http://www.softpedia.com/dyn-postdownload.php?p=137169&t=4&i=1 2. Extract the downloaded file, then open USBShow.exe 3. Click English to translate it to English language. 4. Click Recovery the hide files 5. Browse your Hard drive (Toshiba 500Gb), when you found it, click OK. It will automatically Recover all the hidden files in your hard drive..
Enjoy!
May 26, 2011 | Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard...
Why can't my Toshiba ext hdd accept files more than 4GB? those files are .mkv formats. thanks!
The Toshiba is formatted with the 'FAT32' file-system, which is limited to 4GB per file.
Your 'C:' disk-drive is formatted with the 'NTFS' file-system, which has a much-larger limit.
So, use the 'DISKPART' command-line utility to "convert" the Toshiba from FAT32 to NTFS.
DISKPART is easy to use, but be careful to use it correctly.
Apr 23, 2011 | Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard...
Hello ! I am using benq r 58 model and OS is Vista the BIIOS Set up shows 250 GB is the total memory but in the OS Vista is shows D: , C: and E: Drives using 150 GB and the rest 100 GB lying idle as...
Hi Manish go in Managed and from there you can add this remaining free space in any drive. If don't know how to do that let me know. I will Tell you. Thanks.
Feb 02, 2011 | Dell Computers & Internet
Message memory gets full though the capacity is 500.
yes... i am also getting same problem.
total SMS memory is 500 ie 200 for inbox , 200 for sentbox, 50 outbox and 50 for drafts. your my folder SMS's are still considering in inbox. that should not be more than 200.
thanks
kuldeep chanchal
Nov 19, 2009 | Samsung Star GT-S5233 Cell Phone
Mixing Memory
You can't install two RAMs with different MHz on a single motherboard. Sometimes it works but, usually one of the RAM gets busted. This is based on my experience though.
Sep 24, 2009 | Computers & Internet
Samsung 500gb hdd windows only shows it as a 127gb hdd where is the rest of it
the rest of the memory might be remain unpartitioned...right click my computer->manage->disk management.There you will see the details about the partitioned and unpartitioned disks...check it out...
Jul 05, 2009 | Samsung 500GB, 7200RPM, Internal, 16MB,...
Trekstor 500 gb. external hard drive keeps asking me to insert disk?
CHECK OUT THE RAM, IT WONT SUPPORT IF THAT IS BELOW 1 GB, ITS MOST LIKELY UR PC WILL HANG AND WILL NOT SUPPORT THE 500 GB EXTERNAL DRIVE.
Apr 05, 2008 | Computers & Internet
Open Questions:
I used the HDDScan tool and it gave me these 3 errors. HELP "Reallocated Sector Count" Num Attribute Name Value Worst Raw(hex) Threshold 001 Raw Read Error Rate 100 100 0000000000-0000 050 002 Throughput performance 100 100 0000000000-0000 050 003 Spin Up Time 100 100 0000000000-01E9 001 004 Start/Stop Count 100 100 0000000000-0038 000 005 Reallocation Sector Count 100 100 0000000000-0740 050 007 Seek Error Rate 100 100 0000000000-0000 050 008 Seek time Perfomance 100 100 0000000000-0000 050 009 Power-On Hours Count 100 100 0000000000-0015 000 010 Spin Retry Count 101 100 0000000000-0000 030 012 Device Power Cycle Count 100 100 0000000000-002D 000 191 G-sense Rate/Servo tracking 100 100 0000000000-0002 000 192 Emergency Retract Count 100 100 0000000000-001A 000 193 Load/unload Cycle Count 100 100 0000000000-0079 000 194 HDA Temperature 100 100 38 C 000 194 HDA Temperature Maximum 100 100 43 C 000 194 HDA Temperature Minimum 100 100 19 C 000 196 Reallocation Event Count 100 100 0000000000-003E 000 197 Current Pending Errors Count 100 100 0000000000-0048 000 198 Uncorrectable Errors Count 100 100 0000000000-0000 000 199 UltraDMA CRC Errors 200 200 0000000000-0000 000 220 Disk Shift 100 100 0000000000-0045 000 222 Loaded Hours 100 100 0000000000-0009 000 223 Load Retry Count 100 100 0000000000-0000 000 224 Load Friction 100 100 0000000000-0000 000 226 Load-in Time 100 100 0000000000-0137 000 240 Heads Flying Hours 100 100 0000000000-0000 001
Nov 22, 2011 | Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard...
Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard Drive Logo
106 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
