New batteries, but won't work. Just noticed some rust on one of the terminals. Could this be the cause?
  • 27 Answers
Yes clean the rust on the terminals with Rubbing Alochol and cotton swabs. Make sure to throughly wash your hands after or use latex gloves.
Posted on Mar 15, 2011
  • 2,098 Answers
Hi Scottiessm,
Yes, rusted parts affect the contact from the battery. You can use a smooth sandpaper or a blade to scratch the rusted parts. Then test it using the digicam to confirm if functioning http://www.youtube.com/watch?v=tlTIrVQjaY8.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
My parking brake won't release
cold weather cause metal to shrink more likely brake drums rusted causing brake drum lockup up.rust acts like sand paper making brake drum surface rough have brake drums turned or use 120 grit sand paper just sand out rust sand direction drum rotate.
Jan 15, 2013 | 2010 Ford Fusion 2.5
Won't turnover occasional click
suspect battery problems. THe positive terminal developes a hard black coating inside the lead terminal and around the battery post Remove this using rough sand papaer to a shiny finish on both units . Repeat the operation on the negative terminal. Try the starter again. If still nothing turn on the head lights try again noticing if the head lights go dim. IF they do check if the battery is charged OK then you have a problem in the starter motor IF it works some times and not at others you probably have a dead bar on the communator which means a replacement s-motor
Jan 06, 2013 | Cars & Trucks
IXUS 80 IS is not getting powered ON after recharging its battery fully.
There are 2 things that can cause this to happen. First of all, the battery may not be making a very good contact with the terminal points with which it comes in contact with. This might be due to a shift in the terminals or rusting or even tiny dust particles that could be piling up around the terminals of both the device and the battery. The easiest way to go about this is by using a soft piece of cloth to clean the battery and device terminals properly. Do not use an liquid on the battery terminals but you can use rust removers on the device's terminals. Also try using a fan or blower to remove any dust particle.
On the other hand, if you have been using this battery for a long period of time, it might have expended its life span and as such requires a replacement. If it was replaced, it might not be the correct replacement that was made. Ensure you are using the correct battery by going through your manual carefully.
Thank you for using FixYa.
Jun 06, 2011 | Canon IXUS 80 IS Digital Camera
My remote will not work the tv anymore
there are three possible causes for this problem;
1. Batteries may be dead inside the remote.
2. Remote might be defctive.
3. TV remote sensor/infrared might be defective.
Battries; Simply insert new batteries into the remote and try again. If changing batterises doesn't help, problem as to be from the Remote or TV's infrared.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Yours sincerely
Elect_Comp.
May 12, 2011 | Televison & Video
I recently just bought a '99 Mercury Cougar. 134,000 miles. Every time I am going faster than 35 mph, push the clutch in and brake, the gauges in the dash reset itself. The lights that are by the sun...
Your problem lies in the fuse box that is rusted. this needs to be thoroughly cleaned. (Wire brush) Any rust or corossion between terminals will cause continuity and short out or give power where it is not supposed to be.
May 09, 2011 | 1999 Mercury Cougar
My control remote doesn't work
Hi, first if remote doesn't work, try new batteries......
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
May 08, 2011 | LG 32LC7D Television
The remote doesn't work at all
First, if remote doesn't work, try new batteries......
Regards.
Apr 25, 2011 | LG 32LG30 32 in. LCD HDTV
Sharp EL-9900 wont start after replacing batteries.
when you said it suddenly died, do you means after putting in new batteries,it did not turn on at all? If yes, below are some reasons for this problem;
Check the batter seat. I mean the position where the battery stays, look if you will find any rust of the battery terminal (metal). Rust can prevent the battery from contacting the unit, preventing it from receiving power. Get a flat screw driver, scratch the rust off, fix the battery back in and try again.
If there is no rust, then there is probably some disconnection inside the unit. This can be between the battery terminal and the board. Get a screw driver and remove all the screw. Take the unit apart and check for any lose contact between the battery terminal and the board.
I hope the above makes sense to you.......
Regards.
Apr 11, 2011 | Sharp EL9900 Graphic Calculator
Where is battery on Daelim NS 125
40
<CLEANING BATTERY TERMINALS>
??If you remove two screws from battery
box cover after putting floor panel met
forward, you will find battery assembled.
??If the battery terminal is polluted, or in
rust, separate battery and clean it.
??Battery terminal in rust with white
powder should be cleaned with warm
water.
??In case of serious rust of battery terminal,
disassemble the battery cord and
grind it with wirebrush or sandpaper.
<REPLENISHING BATTERY WATER>
??This vehicle doesn’t need either
replenishing or checking battery water
because of the equipment of enclosed
MF battery.
??In case battery needs a checking, it
should be cared of by service center.
BATTERY INSPECTION
CAUTION
??Turn the ignition switch OFF
before disconnecting the terminal
from the battery. Remove the
negative pole ?? side cord first and
the positive pole ?? side cord next.
Make sure, at this time, that ??
side cord is connected first,
followed by ?? side cord.
??When handling the battery stay
away from flammable materials.
??Make sure that terminals do not
contact with other adjacent parts
when handling ??/?? terminal.
Contact with other parts may cause
spark resulting in electrical equipment
malfunction, fire and electric
shock.
??Frequent cell starting can shorten
the battery lifetime. Please use a
kick to start the engine after the
long period storage and in case of
the initial starting and the cold
starting to improve starting
performance and extend the battery
lifetime.
CAUTION
??Be careful not to disassemble injection
part of enclosed battery.
??When not using vehicle during a
long time, take off the battery from
the vehicle to keep from selfdischarge
and electric discharge.
Put the battery in a well ventilated
place after charging fully. In case it
isn’t available to take battery off
from the vehicle, disconnect “-”
Apr 17, 2010 | 2006 Daelim NS 125 III
Televison & Video Logo
508 people viewed this question
Top Televison & Video Experts
Electro Med Services...
