I want to setup port forwarding on my Siemens Gigaset 572 router to allow FTP. How do I do this?
    Problem Solver:
  • 5 Answers
You shouldn't need to forward any ports to use FTP. It's like forewarding ports for HTTP or e-mail you dont do it...
Posted on Mar 15, 2011
How can i configure siemens gigaset 504 agu for bsnl broadband connection
Connect the ISP modem to main uplink port. Then connect pc to any other port. Done!
Search siemens gigaset 504
They have very easy setup instructions
http://etisalatsupport.blogspot.com/2012/07/siemens-gigaset-504-router.html
Save file for next time.
http://www.etisalat.ae/eportal/en/images/docs/userguides/modem&drivers/Setup-ADSL-Siemens504AGU.pdf
Oct 25, 2012 | Computers & Internet
How do i reset my siemens gigaset se 572 router
I have only been able to find info for the 555, not the 572. Bit it MAY apply.
See if there is a reset button in the back of the unit. Press and release to reset the router.
Press and hold for 5 seconds and it will reset with everything for the factory defaults.
As I said, this actually pertains to the 555, but it may also work for the 572.
Feb 21, 2011 | Computers & Internet
Im trying to connect a siemens gigaset se 572 router to my sky broadband
do you have a connection in your modem?
cause if you do you need to set up the router in bridge with it means it has to be on DHCP (the configuration)
Apr 15, 2010 | Computers & Internet
Telus Router - Siemens SE567 Gigaset
login to the router using the ip address 192.168.1.254 default password is telus
Jul 26, 2009 | Computers & Internet
Unable to ftp from outside of the network. Went through all of the port forwarding setup. Still can't connect.
You need to setup a Port Forwarding / Virtual Server (FTP) in the router to forward port 21 (FTP default) to your FTP server's FTP port. You may need to setup a reserved IP address for the FTP server first in the router before the option comes up.
May 27, 2009 | D-Link DIR-625 (790069292637) Wireless...
How to setup port forwarding on gigaset se587 router
Hi - You can get an online guide on the link below:
Gigaset se587
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 04, 2008 | Siemens Computers & Internet
Port Forwarding
Port forwarding is a method that allows you to run a server behind the router. Port Forwarding opens a specific port to a computer behind the router, allowing all Incoming Traffic on that port to be sent directly to that server. It should be used to setup servers behind the router, typically Port Triggering (Answer ID 344) is a better choice for non server applications (Such as instant messengers and game servers). Below is an example of how to setup Port Forwarding. For our example we will be setting an FTP Server and a Mail Server that uses SMTP and POP3. FTP uses ports: 20 and 21 SMTP uses port: 25 POP3 uses port: 110 Getting Started 1. You must set a static IP address on the server. If you're unsure of how to do this please go to Answer ID 534 for information on setting a static IP address in Windows. 2. Once the static IP address has been assigned please go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP) 3. Once "Internet Explorer" opens, please type http://192.168.1.1into the "Address Bar" and click GO 4. The "Enter Network Password" window will appear. Skip user name and type admin (admin is the default password) as the password, and click OK 5. This will bring up the routers "Setup" section. Look under "Domain Name" and check what version of the firmware you're using. 6. You will need to click on the Advanced tab to the very right. Once the "Advanced" tab comes up please go to the Forwarding tab. Firmware prior to 1.32 This will not work with firmware prior to 1.32
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Port Forwarding
Port forwarding is a method that allows you to run a server behind the router. Port Forwarding opens a specific port to a computer behind the router, allowing all Incoming Traffic on that port to be sent directly to that server. It should be used to setup servers behind the router, typically Port Triggering (Answer ID 344) is a better choice for non server applications (Such as instant messengers and game servers). Below is an example of how to setup Port Forwarding. For our example we will be setting an FTP Server and a Mail Server that uses SMTP and POP3. FTP uses ports: 20 and 21 SMTP uses port: 25 POP3 uses port: 110 Getting Started 1. You must set a static IP address on the server. If you're unsure of how to do this please go to Answer ID 534 for information on setting a static IP address in Windows. 2. Once the static IP address has been assigned please go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP) 3. Once "Internet Explorer" opens, please type http://192.168.1.1into the "Address Bar" and click GO 4. The "Enter Network Password" window will appear. Skip user name and type admin (admin is the default password) as the password, and click OK 5. This will bring up the routers "Setup" section. Look under "Domain Name" and check what version of the firmware you're using. 6. You will need to click on the Advanced tab to the very right. Once the "Advanced" tab comes up please go to the Forwarding tab. Firmware prior to 1.32 This will not work with firmware prior to 1.32 Firmware between 1.32 and 1.36 Service Port Range 20 ~ 21 25 ~ 25 110 ~ 110 IP Address 192.168.1.3 192.168.1.3 192.168.1.3 Firmware after 1.36 up to 1.40m Service Port Range 20 ~ 21 25 ~ 25 110 ~ 110 Protocol Both Both Both IP Address 192.168.1.3 192.168.1.3 192.168.1.3 Firmware after 1.40m Customized Application FTP SMTP POP3 Service Port Range 20 ~ 21 25 ~ 25 110 ~ 110 Protocol Both Both TCP IP Address 192.168.1.3 192.168.1.3 192.168.1.3 Finishing up Click Apply, then Continue Restart your computer
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
