Question about Black & Decker String Trimmer Cordless 12" 18V
Cordless weedeater loses charge after only using 10-15 minutes, can we replace a battery pack or do we need a whole new one?
  • 1 more comment
  • MGHuck Aug 02, 2008
    My unit is now 2 years old, and the battery seems to go down MUCH FASTER than it did when new.
  • Anonymous Aug 05, 2008
    I am having the same problem, the unit was fine after the first charge. Then after each use the time of use has become shorter and shorter. I thought they fixed the memory problem with these batteries.
  • dan23 Aug 05, 2008
    after the first charge, the length of the charge has been getting shorter and shorter. I thought they fixed the memory problem with these batteries?
Battery companies don't want anyone to know this but if you run the terminals over a magnet, the memory will harmlessly be erased. However, a battery may overcharge so keep an eye on it will recharging the next time.
Posted on Sep 01, 2008
The so called memory effect only effects NiCads,
The older B&D trimmers use a Gel Cell battery (they have a recycle symbol with Pb on them, Pb is the chemical sign for lead)
If you run a Gel Cell down all the way, you will quickly DESTROY it.
Gel Cells should only be run down until you notice it slowing down, and then recharged ASAP. These units should be kept on charge whenever they aren't being used, or recharged at least once a month, whether they are used or not. If they aren't on charge all the time, they should be charged before using.
If this doesn't fix it, you've already ruined the battery, go get a new one.
Posted on Sep 07, 2008
Most batteries have a memory. So, if you don't let it completly die bofore you recharge it, the life of the battery will shorten to the charge you give it
Posted on Aug 05, 2008
My Roomba Model 440 runs for about 2 minutes and stops. I can start it up again after which it repeats stopping after not quite 2 minutes. It is perfectly clean and charged. What is the problem?
Most likely your NiCad battery is at the end of it's life and needs replacement. The packs in Roombas are made up of a group of individual cells and what often happens as they age is that a single cell will fail, causing the entire pack to provide less than usable voltage. The Roomba will attempt to operate and then sensing low voltage, it will shut down.
To prevent reduced battery life in the future with your new pack, always keep your Roomba charged as storing a NiCad pack in a discharged state will cause the build up of salts within the pack, damaging the cells.
Replacement is simple and packs are around $40 bucks online, all you need is a small Phillips screwdriver and about 5 minutes.
Oct 02, 2013 | Roomba 440 Cordless Robot Vacuum Cleaner...
My battery will not keep a charge it don't last 10 minutes/ i like the weedeater but it just don't last long enouh
I had one of these a while ago, the batteries are just cheap. Trimmers also use a lot of energy and battery powered ones aren't the best way to go if you want them to run a long time. I highly recommend replacing it with a good gas or plug in model from your local hardware store, they can help you find the right one to fit your budget. If you don't want to get a new trimmer you are going to be fighting dying batteries every year.
Jun 06, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
It does not turn on even if it was charged for 24 hrs
When it charges, does the red light come on on the charger? Some of the CST2000 chargers make bad connections, and they don't actually charge.
Make sure the red light is coming on when you're charging the battery. If the light is coming on and you still can't use the trimmer after charging, you'll need either a new battery or a whole new battery pack (the black handle of the trimmer).
Hope that helps!
Sep 04, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
I've owned this great little Black and Decker CST800 grass trimmer for 6 years and only use it in Montreal summers (5 months long). Just this past week, I brought it in to recharge it and left it for 5...
never charge batteries that long usually only 3to5 hours if ni-cd . most batteries last 3 or 4 years . totally discharge pack and try to charge again . if nothing buy new battery pack
Jun 15, 2010 | Black & Decker 8 Inch 12 Volt Cordless...
Need new battery and I have a NiMH battery replacement. Can I use it on my phone? I have model number 25838GE6-A.
NiMH is a universal replacement battery. It will work in place of nicad and other types of rechargeable batteries, and will work with virtually any charger
Dec 22, 2009 | Uniden Cordless Phone
Logitech MX1000 Laser Cordless Mouse, I replaced the li-ion battery with a NiMh AAA battery pack, soldered in the board that was on the old battery and used it for a week before the battery pack needed...
Li-Ion battery and NiMh battery have completely different charging requirements! Li-Ion battery has much stricter charging requirement and the regulator is normally design to trickle charge at 0.1 Current rating @ 4.2V and then completely shut down.
WARNING: if you use a Ni-Mh charger on a Li-Ion battery, then it will erupt and even explode and catch fire!
Bottom line is that the rescued Li-ion regulator is not designed for your Ni-Mh pack and you will never get a full charge with it and you will need a completely different regulator board: you are better off putting in a suitably sized Li-Ion battery with inbuilt regulator but with higher current rating if possible.
Hope it helps! Let me know how you go.
Nov 14, 2009 | Logitech MX1000 Laser Cordless...
My Portable DVD Player Battery can't hold a charge
Rechargeable batteries can only be recharged so many times. They begin to slowly lose their capacity after about the first 5 charges until ultimately it won't hold a charge anymore. It appears that this is your problem. Look for a model number on the battery & do a Google search for it if you want to try & replace it. You might also find it is cheaper to buy a whole new DVD player than it is to buy a replacement battery.
May 20, 2009 | Protron 7" PORTABLE DVD
Tired old Dewalt dw056 impact driver
It needs a new battery pack. Rechargeable batteries eventually wear out and no longer hold a charge. The tool runs only briefly and the battery is exhausted again. The big home centers and online sources sell replacements. There are also companies that say they can rebuild your battery pack at much lower cost than replacement. I have no experience with them.
Apr 23, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Phone loses connection after few minutes
I looked up the battery specs for your phone. They are 3 X 200mah= 600mah battery packs. They should last 8 hrs talk time with the headsets. This style of battery pack in my experience only last about 1 1/2years and sometimes longer and "sometimes" shorter...much shorter. I bet you never had problems when you first got them. Basicly this "battery design arrangment" goes back many years before newer battery technlogy was developed. But designers still insist on using them even today. They are cheap to make. ****Time to replace them with new ones.**** Make sure you follow the mfgs charging instructions: "After battery installation, place the handsets in their base unit or charger and allow to charge for 16 hours before use. You can keep the battery charged by returning the handsets to their base unit or charger after each use. When the battery is fully depleted, a recharge takes about 12 hours. Average talk time on a fully charged battery is about eight hours depending on environmental conditions, standby time is approximately four days." Good luck
Jul 19, 2007 | AT&T E5640 Phone
Black & Decker String Trimmer Cordless 12" 18V Logo
360 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
