Question about Samsung CLP-510 Laser Printer
It stops printing after 4/5 sheets of double sided printing. The message is then "processing" until I turn the machine off. I then have to go through the whole resetting process to use it again
  • 3 more comments
  • timspencer Mar 15, 2011
    Printer driver software reinstalled. same problem. what is and how do I use a chipsetter?
    Tim Spencer
    Having had a brief OK printing session (17 pages single sided 6/7 pages duplex) following reinstallation of driver software my screen now says that printing was not possible because "no pages were selected" despite correct pages being entered by me.
    Having printed 16 single sides and 5 double sides and reinstalled the software I am now told that following my instructions "printing is not possible" because "no pages were entered" .
  • timspencer Mar 16, 2011
    I have uninstalled the software, successfully reinstalled it (according to the messages I have received) and I am still told that printing was not possible as no pages had been requested. They had, both in single page and double sided, but now I'm stuck and can't print anything.
    Dispairing!
    Thanks, particularly for the link and its general message. Current problem is that my request for a print job is met by the news that printing is impossible because no pages have been requested! This not so but I can get no further.
    I have uninstalled and reinstalled the software using the CD but still no good
    Genius:
  • 1,157 Answers
Hi Timspencer,
If system doesn't print anything and stuck at the "processing" it might caused by a corrupted driver or might be a chip issue. There are several ways that you can try to correct this problem, either you reinstall the driver or reset the chips. Here are some steps that you can apply to diagnose if this is a software or hardware issue. Please follow the instructions below:
1. Reinstall the driver of your printer. Please use the driver disc that came with your machine.
2. Try to restart the computer then connect the printer using the USB cable. Please make sure that all connections are properly intact.
3. Now try to run a print self-test.
--> if you're still encountering the same issue, I recommend to reset the chips using a chip resetter.
Hope it helps.
Thank you for using FixYa.
Posted on Mar 15, 2011
  • 1 more comment
  • Reynaldo Labaguis Jr.
    Reynaldo Labaguis Jr. Mar 15, 2011
    Hi Tim,
    If installing the driver does nothing, I recommend now to use a chip resetter to correct the problem. The chips of CLP-510 cartridges has a counter that is updated every time you use it. The only way that you can reset the chip is to use a device that would write data to the chip to place zero into the page counter. Please try to contact the manufacturer if they could provide you a chip resetter. You may also try to search online for the CLP-510 chip resetter, some vendors are selling CLP-510 resetter separately or combined with toner for a very reasonable prize.
    Hope it may help you.
    Reynaldo Labaguis Jr. Mar 16, 2011
    Hi Tim,
    Another thought for this issue:
    If you go into "printers and faxes" in the control panel and right click on the printers do you get the options "use printer offline", "use printer online", "pause printing", "resume printing" or "cancel all documents"?
    I suggest to select the options "cancel all documents", "resume printing" and "use printer online" if they are available, do not select "use printer offline" or "pause printing".
    You may want to check this link for your reference also.
    Hope it helps.
    Tim,
    I'm afraid you need to contact a repair man for further diagnostics and repair for this particular issue. If you do have any question except for this one just let me know. I will try my best to further assist you.
Paper jam
Duplo and Karagatan were early forms of Philippine drama.The Duplo was a poetic debate by trained men and women in the ninth night, which is the last night of the mourning period for the dead. The Karagatan was also a poetic debate like the Duplo, except its participants were amateurs. Both were held in homes and their theme was about a ring that fell into the sea.
Jul 13, 2013 | Brother MFC-J410W Wireless Compact...
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
Error message to "Load Paper"
Push something thicker than a plain sheet of paper through. Cut a side of a manilla folder into a 8.5"x11" and let the printer try to grab it during a copy. After doing it's normal "grab the right side until it's skewed and stop", continue to try to push it through.
Nov 30, 2011 | Canon imageCLASS® MF4150 All-In-One Laser...
Can I print on both sides of the page
Here are the instructions for duplex printing.
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
1. Open the printer driver setup window, and check the Duplex Printing check box on the Page Setup tab.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note
sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper or Photo Paper Plus Double Sided is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
You can download a users manual for your MX310 at
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#BrochuresAndManuals
Please rate this solution. Thanks.
Sep 27, 2011 | Canon PIXMA MX310 All-In-One Printer
Hi...I have a problem with my HP Photosmart C7280...can you help ? the error message "Photo tray problem" keeps coming up, telling me to "lift the output tray, push the photo tray all the...
Photo tray problem
' Lift the output tray up and verify that the photo tray
' is pushed in until it stops, then lower output all the
' way down. Press OK button on the printer to
'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper tray and photo tray
3. Remove output duplexer (on back of printer)
4. Open input sheet feeder (on top of printer)
5. Open cartridge access door. (Basically lift up control panel and scanner section of the printer)
6. Turn on printer (Power button on now raised control panel)
7. Printer may display message "Performing printer alignment - Do not interrupt"
8. Wait for a few minutes until printer stops making all setup noises.
9. Close cartridge access door, close input sheet feeder, replace output duplexer, insert paper trays
10. Do a test print. All should be fine.
Mar 11, 2011 | Office Equipment & Supplies
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
5. Click OK.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
MY test page always prints
I belive that after replacing the INk cartridges, you are experiancing this problem. The Alignment test sheet always prints everytime you turn on the printer, if u haven't completed the Alignment process.
To complete the Alignment process,
>>Once the printer finished printing the Alignmnet test sheet.
>> Place the Test sheet staright on the scanner glass facing down towards right hand corner.
>>Press the scan button(color), the Power ON light will start flashing, wait until it stops flashing.
>>Alignmnet process completed.
Thank You
Feb 09, 2008 | HP PSC 1315 All-In-One InkJet Printer
Cannon MP160 How to Print both sides of the Paper???
Set Duplex Printing (Windows) For details on how to set duplex printing, see below: 1. Select 'Properties' from the Print dialog. Note: Properties may be indicated as Advanced, depending on the application software. 2. Click the Page Setup tab. 3. In the Printing Type section, select 'Normal-size Printing', 'Fit-to-Page Printing', 'Scaled Printing', or 'Page Layout Printing'. 4. Select 'Duplex Printing'. Note: When a media type other than Plain Paper, Photo Paper Plus Double Sided, or Postcard is selected in the Media Type menu, duplex printing cannot be performed. 5. Specify Staple Side. 1. The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. 2. Click the Staple Side drop-down arrow and select the setting. If you want to change the setting, select another value from the list. 3. If necessary, click Specify Margin... and set the Margin width 6. When the setting is completed, click the OK button at the bottom of the window. Note: If a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab: The document will be printed on one side of a sheet of paper when printing starts. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side. If Photo Paper Plus Double Sided is selected for Media Type on the Main tab: The document will be printed front and back alternately for one sheet at a time, when printing starts. Load the paper according to the displayed messages. 7. You will be prompted, while printing, to remove the printed page and reload it in the ASF. 8. Dependent on the number of pages to print, you will need to repeat step 7 until all pages have printed. Back to Top
Sep 10, 2007 | Office Equipment & Supplies
Samsung CLP-510 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
