Question about Lenovo IdeaCentre K210 - 53133BU PC Desktop
Goes into hibernation won't come out of it if not active for about an hour or so. running win7 and have set the power settings to never hibernate. i've learned through experimentation that once it's in hibernation, i can sometimes avoid having to kill the sys by holding down the power button (my only choice most of the time) by alt-crtl-dlt-ing moving tow spaces down and pressing enter, which logs me off. the system then wakes in order to allow me to log in again. it's not consistent though.
  • 24 Answers
Try setting your screen saver to none. That might sole the hibernation problem. Sometimes a computer will go into hibernation if the screensaver has been on for a while.
Posted on Mar 15, 2011
VPCSA does not properly go to sleep / hibernate
My advice is to shut down and unplug the Laptop when not in use. Set the Power Options to High Performance, set Sleep and Hibernate to never, adjust your Advanced Power to shut down when lid is closed. A reboot everyday resets the computer and IF there is a Power Surge your Laptop will not get fried. If left plugged in the battery COULD malfunction and become a fire hazard. Not to mention the unnecessary power applied to components and shortening their lifespan.
May 08, 2013 | Computers & Internet
Hp pavilion ze1115 stuck on hibernating..
Open Control Panel, Power, power settings, change power settings to high performance, Disable Hibernation, sleep. When your laptop is not in use shut it down and unplug. It will last longer and a boot everyday will reset the laptop.
Dec 17, 2012 | HP Pavilion ze1115 Notebook
How to active the Hibernate at all PCs?
To make hibernation unavailable, follow these steps:
  1. Click Start, and then type cmd in the Start Search box.
  2. In the search results list, right-click Command Prompt, and then click Run as Administrator.
  3. When you are prompted by User Account Control, click Continue.
  4. At the command prompt, type powercfg.exe /hibernate off, and then press ENTER.
  5. Type exit and then press ENTER to close the Command Prompt window.
To make hibernation available, follow these steps:
  4. At the command prompt, type powercfg.exe /hibernate on, and then press ENTER.
Mar 26, 2011 | Computers & Internet
The hibernate option is not getting activated.what should i do?
In window xp follow this steps to activate hibernate mode
go to start then setting and select control panel, then go to and performance maintenance, select power options, then power options property appear you can see 3 tab is hibernate there from down check enable hibernate, press apply then go to advanced tab on the same window, when i press the power button on my computer select hibernate there then press ok,
now try to press the power button on your laptop to go to hibernate mode
Regards
manish
Mar 24, 2010 | Dell Inspiron 6400 Notebook
My HP's screen goes black
When your computer reboots, go to the control panel > power options > go to the hibernate tab and turn off hibernation. Then go to the power settings and make sure to change the setting for closing the lid to "do nothing" then change the other settings such as when the computer sleeps if inactive to 30 minutes to an hour. Hibernation is causing the most problems I see with random shutdown etc. One other thing it might be also is overheating of the processor, make sure to get some compressed air and blow out the heatsink vents and grills on the base of the laptop. If these are insuccessful, there maybe the possibility that you have a Malware bug. Go here http://www.filehippo.com/download_malwarebytes_anti_malware/
download and run this and perfrom a quick scan, when it is finished, show results and delete anything it finds.
Oct 13, 2009 | HP Pavilion dv4000 Notebook
Question
Hibernation is a power management feature. When you hibernate a laptop, you're essentially turning it off. So, unlike Stand By (Sleep) mode, a hibernated laptop isn't using any battery power at all - that laptop is off!
The secret behind hibernation is that before you turn off the laptop, everything you're doing with the computer is saved. (The contents of memory are saved to the hard disk.) When the computer is turned on again, it recovers from hibernating by reloading all the saved information and restoring your laptop to exactly the same condition it was in before it was hibernated.
Briefly, hibernation works like this:
1. You activate the hibernation feature.
Hibernation is activated differently depending on how it's set up.
2. The laptop hums as everything in memory is saved to disk.
3. The laptop turns itself off.
It's really and truly off: The battery isn't being used, and it's safe to store the laptop or put it away until you need to use it again.
To recover from Hibernation mode, just turn the laptop on. In some cases, the laptop may recover from hibernation when you press a key or touch the mouse pad. hibernated state for as long as you want.
Hibernation mode requires hard drive space. So you should be aware that when hard drive space runs low, it's possible that Hibernation mode won't work.
In Windows XP, you have to activate Hibernation mode before you can use it. Follow these steps to activate Hibernation:
1. Click the Start button.
2. From the Start menu, choose Control Panel.
3. Open the Power Options icon in the Control Panel.
4. In the Power Options Properties dialog box, look for and click on the Hibernation tab.
If you don't see a Hibernation tab, there's your answer: The laptop isn't capable of hibernating. Oh, well.
You might want to check the laptop's Setup program to see whether you can activate Hibernation there.
5. Select the Enable Hibernation option by clicking the check box to place a check mark in the box.
6. Review other options, if they're available.
7. Click OK to confirm the changes and close the Power Options Properties dialog box.
Optionally, close the Control Panel window, as well.
Some laptops may require you to restart Windows for this change to take effect.
Sep 09, 2009 | Computers & Internet
Hiberation mode ,,what do i do/
Hibernate mode is a power saving feature for computers. In hibernate mode, the current state of a computer is saved to the hard disk, and the computer shuts down. A user will have to power on the computer to restore the previous settings. When a computer resumes from hibernate mode, it reads the saved settings from the disk and restores the system state as it was before it entered hibernate mode. By default, hibernate mode is disabled. If a computer is not ACPI-enabled or APM-enabled, users will have to enter hibernate mode manually. Users cannot set the computer to automatically hibernate after a certain time. With ACPI-enabled and APM-enabled computers, users are able to set hibernate mode automatically
How to enable Hibernate:
Please follow this steps below to enable your Hibernate features:
1. Go to Main screen in your windows then right click your mouse to an empty area in your main menu.
2. After clicking the right click please select the properties then go to Screen Saver Tab.
3. Please Click the Button name Power then click the Hibernate Tab.
4. Please check the CheckBox name Enable Hibernation to enabled the hibernation if it is not hibernated.
5. To try test the Hibernate process please follow the steps in How to start using Hibernate below.
How to start Using Hibernate:
Please follow this steps below to active your Hibernate Features:
Make sure all necessary programs are closed prior to shutting down. Hibernating will put all programs to "sleep," but some programs won't start up properly. Experiment after this to figure out which programs perform as intended.
  1. Click Start and Shut Down,
  2. Point the standby button and maintain the shift key pushed,
  3. A new hibernation button appears: click it while still holding the shift key: voila your PC will hibernate.
Thanks
Aug 07, 2009 | Averatec C3500 Tablet PC
Benq mp6100
If this problem happen with a particular laptop then I suggest that you you change the setting of the laptop you are using. Go to Start=>Control Panel=>Performance and Maintenance=>Power OPtion=>Power Option Propreties=(click on Hibernation Tab and uncheck Hibernation box).
While on the Power Option check the time on the SYSTEM HIBERNATION.
Good luck
Dec 25, 2007 | BenQ MP610 Multimedia Projector
Won;t Hibernate
Sony laptops are infamous for these kinds of problems. You very likely have another Sony program running in the system tray which is trying to control all power functions in a "smart" (in other words, defective) manner, and this is conflicting with and resetting your OS's normal power settings. Try to find this program on your laptop and run it and check what it thinks it is doing. You might also have a problem with the actually writing of the hibernation file on your machine due to any number of problems (low disk space, conflicting file names, corrupted administraive priveledges for whatever program thinks it is doing the writing). I'd suggest uninstalling the SONY power management software and then using the stuff the operating system provides. It might not be good, but it at least works kind of, and consistently.
The changing status of the hibernate settings you describe suggest to me that another program is changing them to try to be "efficient".
Last resort - disable hibernate; it doesn't work very well on Sony laptops even at the best of times.
Nov 16, 2007 | Computers & Internet
Lenovo IdeaCentre K210 - 53133BU PC Desktop Logo
250 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
