Question about Brother IntelliFAX 560 Plain Paper Fax
On a brother fax how do you set it to not go to fax mode on incoming calls
Can you temporarily just let the phone ring until answering and not auto into fax mode? thanks
    Sergeant:
  • 329 Answers
Depending on the model of fax some have switchs on the key board and some have switch in the set up menu. There are usually 3 or 4 answer modes. One for FAX or automatic receive, MANUAL to allow you to answer the phone and many have an ANSWER MACHINE mode to allow you to hook to ansering machine...What kind of fax do you have.
Posted on Aug 01, 2008
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
My Lexmark X5650 (Model number: 4437-001) will not auto answer faxes. It can be manually be answered, and the settings are for auto answer. I can also send faxes too with no hassle at all.
bbargains,
Here is the correct procedure to receive a fax automatically;
Make sure the printer is on and is connected to a working phone line.
Make sure that Auto Answer is on.
To check if Auto Answer is on:
From the printer control panel press the wrench sign.
Press the arrow buttons until Fax Setup appears, .
Press the arrow buttons until Ringing and Answering appears, and then press
OK to save the setting.
Press OK again.
Check to see if Auto Answer is set to On.
If Auto Answer is not set to on, press the arrow buttons until On appears, and then
press to save the setting.
Set the number of times the telephone rings before the printer automatically
receives faxes:
Press the arrow buttons until Pick-up On appears, and then press OK .
Press the arrow buttons until the setting that you want appears, and then press to
save the setting.
When the number of rings you set is detected, the printer automatically receives
the incoming fax.
This should solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
May 23, 2011 | Lexmark X5650 All-in-One InkJet Printer
HP L7650 will not auto answer incoming faxes
To set the answer mode to manual or automatic via the control panel
? Press Auto Answer to turn the light on or off, as appropriate for your setup.
When the Auto Answer light is on, the device answers calls automatically. When
the light is off, the it does not answer calls.
To set the answer mode to manual or automatic via the embedded Web server
1. Open the embedded Web server, click the Settings tab, click Fax in the left pane,
and then click the Basic sub-tab.
2. Select On or Off in the Auto Answer drop-down menu in the Other Basic Fax
Settings section.
Set the number of rings before answering
If you turn on the Auto Answer setting, you can specify how many rings occur before
incoming calls are automatically answered.
The Rings to Answer setting is important if you have an answering machine on the
same phone line as the device, because you want the answering machine to answer
the phone before the device does. The number of rings to answer for the device
should be greater than the number of rings to answer for the answering machine.
For example, set your answering machine to a low number of rings and the device to
answer in the maximum number of rings. (The maximum number of rings varies by
country/region.) In this setup, the answering machine answers the call and the device
monitors the line. If the device detects fax tones, it receives the fax. If the call is a
voice call, the answering machine records the incoming message.
To set the number of rings before answering via the control panel
1. Press Setup.
2. Press Basic Fax Setup, and then press Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press the left or right
arrow button to change the number of rings.
4. Press OK to accept the setting.
To set the number of rings before answering via the embedded Web server
2. Select a number in the Rings-to-answer drop-down menu in the Other Basic Fax
Settings
section.
Dec 02, 2010 | HP Officejet Pro L7650 Printer
What is answer mode?
The answer mode determines whether the HP Fax answers incoming calls or not.
Different answer modes are :
* Fax
The HP Fax will automatically answer all incoming calls using the Rings to Answer setting. This is the default setting.
* FaxTel (unit with handset model only)
The HP Fax automatically answers all incoming calls using the Rings to Answer setting. If the call is a fax call, the HP Fax will receive the fax. If the call is a voice call, the HP Fax will create a special ring to indicate it is a voice call. The incoming voice call will need to be answered using the attached handset.
NOTE: If the HP Fax determines the call is a voice call, only the HP Fax will ring with the special ring tone. The other phones on the same phone line will not ring at all. You will not be able to pick up the voice call using the other phones.
* Tel
The HP Fax will not automatically answer calls. Faxes will need to be received manually.
* AnswerMachine
The HP Fax will monitor the line when an incoming call is answered by a person or by the answering machine. If the HP Fax detects fax tones on the line, it will receive the fax.
Jun 07, 2010 | HP Officejet 4315v All-In-One InkJet...
My machine (1020) will not except incoming fax's Why? Do I have to set up machine differently?
Some machines have a three answering modes.
1-manual-you have to pick up the fax headset and then press send when someone calls you with a fax.
2- auto-The machines answers the phone line when it rings and receives the fax automatically.
3-answer- the machines acts like a voice answering machine only.
Check your display or user settings to see that it in in AUTO RX or receive mode. .
Hope that helps.
Jan 17, 2010 | Brother FAX-1020 PLUS Plain Paper
How do i set up fax to automaticely receive faxes after several rings
For a phone line dedicated only to the fax machine, the process is as follows:
  1. Press Menu/Set, 0, 1.
  2. You will see the Fax Receive window
  3. Use UP and DOWN arrows to change the setting to FAX ONLY
  4. Press Menu/Set.
  5. Press STOP/EXIT
Your fax machine will now answer every incoming call.
If the fax machine is sharing the phone line with a telephone, repeat the above steps and change from FAX ONLY to FAX/TEL This option will allow you to share the line with a phone only, not an answering machine. Once in FAX/TEL mode, the fax machine will still grab every incoming FAX call, and give a special ring (slightly different than a regular telephone ring) when it's a regular incoming phone call signaling you to answer the phone. I hope this helps with your problem. Best of luck!
Greg
Nov 11, 2009 | Brother IntelliFax-2820 Laser Fax
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
How do I set up my X7170 to receive a FAX?
Link
Receiving a fax You can choose to receive a fax automatically, manually, or through an answering machine.
Note: For your All-In-One to receive a color fax, the machine from which you are receiving must also support color faxes.
Automatically Recommended for a dedicated fax line
Your All-In-One automatically accepts incoming faxes using the automatic answering mode. When the Auto Answer light is on, the All-In-One receives a fax after the specified number of rings set in the Options menu.
To set a number of rings for the automatic answering mode:
  1. On the control panel, press Mode repeatedly until Fax is selected.
  2. Press Options until ANSWER FAX WHEN appears.
  3. Press + to choose After 1 ring, After 2 rings, After 3 rings (default), or After 5 rings.
  4. Press Select.
  5. Make sure the Auto Answer light on the All-In-One is on.
When the number of rings that you set is detected, the All-In-One automatically receives your fax.
Manually Recommended for a shared fax and telephone line
You can choose which incoming faxes to accept by setting your All-In-One to manual answering mode.
  1. Make sure the All-In-One Auto Answer light is off.
  2. Press *9* on the telephone after you answer the telephone and hear fax tones.
  3. Hang up the telephone.
The All-In-One receives your fax.
Answering machine Recommended for a shared fax and telephone line
To receive a fax with an answering machine connected to your All-In-One, set the answering machine to answer incoming calls before the All-In-One does. For example, if you set the answering machine to answer calls after 3 rings, set the All-In-One to answer calls after 5 rings.
  3. Press + until After 5 rings appears.
  4. Press Select.
When a ring is detected, the answering machine picks up the call.
  • If a fax is detected, the All-In-One receives the fax and disconnects the answering machine.
  • If not, the answering machine completes the call.
Note: You must set up the equipment as shown in connecting to an answering machine.
May 21, 2008 | Lexmark X7170 All-In-One InkJet Printer
Setting the voicmail
Voicemail or telephone answering device (TAD). There is a BIG difference. Voicemail is product of your telephone service provider. If you have voicemail, most providers have a solution to this that you must arrange through them. If you have an answering machine, you can set your Brother to TAD mode. In TAD mode, if your answering machine picks up, (you must set your answering machine to answer in less rings than your fax), your fax will "eavesdrop" to listen for the fax tones from the sending machine. If it hears these tones, it will disconnect your answering machine and accept the incoming fax. If it does not hear the tones, it allows the answering machine to record the incoming message. If you are home. If you answer the call and hear a tone every 2.5 to 3 seconds, that signals an incoming fax. Simply touch *51 on the keypad of the phone you picked up on. You will hear some shrill tones. That is your fax machine attempting to receive the incoming fax. Hang up the phone you are on and it will receive the fax. In any case, make sure that the receive mode is NOT set to AUTO. Set the receive mode to TAD or MANUAL. If these instructions were not clear enough, let me know and I will send you DETAILED instructions. You can find the manual here: http://www.brother-usa.com/Data/Documentation/Fax/User/UM_FAX2820_FAX2920_MFC7220_MFC7225N.pdf If you need additional assistance, please let me know before you rate this solution. Ed
Jun 29, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 560 Plain Paper Fax Logo
54 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
