Question about Just Wireless Bluetooth Headset Wireless Headset
I used the bluetooth headset in rainy season and I don't the reason, but since then I am not able to use it . If any part is got off , which part it could be ?
  • 4 Answers
Place it a warm dry spot, for several hours, or try the lowest setting of a blow dryer from a foot or so away. Moisture can get inside and it needs time to dry. Warm air helps, this make take a day or so.. With air current, less time, then try to charge it again. This just may help !! RDPONY.
Posted on Mar 15, 2011
Plantronics Voyager 500a bluetooth system. was using the lifter, but don't want to anymore, just want to be able to switch phone to headset mode and use the bluetooth. When I hook it up and hit the...
The beeps mean it needs to be repaired or resubscribed.
http://www.headsetsdirect.com/pdf/Voyager%20510S%20Bluetooth%20Headset%20System%20pairing.pdf
If you are using a Cisco phone you could probably plug the headset base into the phone. If it is not you will still need your lifter.
Good luck from Headsets Direct - 800-914-7996.
Aug 18, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Tip
How to protect your Computer in rainy reasons
If your computer(s) is/are not in an AC room - it (not only computer any sophisticated electronics goods) may be damaged in rainy seasons due to moisture. Please put (2-3 Kg) Solid Lime beside your computer for 3-4 days and close your windows and doors most of the time. The chance of damaging the computer will really be reduced.
on Jun 11, 2010 | Computers & Internet
Cannot 'pair' the HPBLU H1 to my Blackberry..? Not 'finding' it... need a users Guide... where can I get one...?
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Feb 23, 2011 | Cellular Innovations HFBLUH1 Bluetooth...
I AM NOT ABLE TO PAIR JABRA BT135 WITH MY BLACKBERRY 9700. WHAT SHALL I DO?
Hi,Instructions on how to pair blue tooth device with black berry.
Tips & Warnings
Have a nice day .
Feb 16, 2011 | Jabra BT125 Headset
I cant talk to anyone and how do you talk to them
Check to make sure that the bluetooth headset is compatible of connecting to the mobile device. If it is, then you will need to pair the devices using the Mobile Device. Make sure the Bluetooth Headset is switched on when the Mobile Device is trying to search for the Bluetooth Headset. It should work but if it doesn't, check the Manufacture's Website for any support.
Oct 21, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
GE Bluetooth connectivity
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Explorer 3XX device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya
Chris (ziraffa)
Dec 26, 2008 | GE Bluetooth In-ear Headset Wireless...
Bluetooth won't connect
follow the steps below:
5) Select the Motorola device and click add
Hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
Dec 24, 2008 | Motorola Mobility H550 - Bluetooth Headset...
Plantronics explorer 220
The Pass Number is usually 0000 (four zeroes)
Here's a link to the PDF file:
http://safemanuals.com/annexe_PAIRING%20INSTRUCTIONS_PLANTRONICS_EXPLORER%20220-_E.htm
Hope this helps
Seasons Greetings from Fixya
Chris (ziraffa)
Dec 13, 2008 | Plantronics Explorer 220 Bluetooth Headset...
Discoverable mode
Hope this helps
Chris (ziraffa)
Dec 03, 2008 | Plantronics Explorer 220 Bluetooth Headset...
Motorola bluetooth headset HS850
There are several possible reasons for this problem.
Try the following steps:
- Shut off the headset.
- Shut off bluetooth on your mobile phone and restart it.
- Now bring your headset in pairing mode. How to do this should be explained in the manual.
- go to something like "add new bluetooth device" on your phone. Something like that should be in the bluetooth menu.
- the phone should find the headset now. Pair the devices using pincode 0000. That's normally the code for headsets.
you can use the headset now.
If one of the steps gives problems, just ask. Then I will try and give some more specific help.
Please give some reaction also if this was helpful...
Ruud
Oct 31, 2008 | Motorola Mobility Universal Wireless...
Just Wireless Bluetooth Headset Wireless Headset Logo
21 people viewed this question
Top Just Wireless Radio Communications Experts
Rocketmanusa
Level 1 Expert
Michael Vincent Cruz
rdjagger
Are you a Just Wireless Radio Communication Expert? Answer questions, earn points and help others
