Question about Nikon Cameras
MY NIKON D70,WHEN ITOOK OUT THE COMPACT FLAS CARD IT HAS PULLED UP 2 OF THE CONNECTORS,GOLD COLOURED WIRES,I DIDNT NOTICE STRAIGHT AWAY UNTIL I PUT CARD IN AGAIN WHICH THEN BENT THEM AND NOW I CANT GET MY CARD IN..THEY WONT STRAIGHTEN IT IS VERY NARROW..IS IT EXPENSIVE TO REPAIR..
  • 667 Answers
In a word, Yes. Parts will add to a labor cost.
Posted on Aug 02, 2008
What does HR in a Nikon D70 mean?
Hi. HR is an error code which is related to the memory card. It doesn't have exact meaning (as far as I know, its not in the manual and website).
There are several possibilities why you are getting this error. It could be corrupted memory card, damaged pin, loose connection between the memory card and camera, dirty contacts, camera is not giving enough power to memory card, etc...
Some fixes that may work:
- Make sure your battery is fully charged.
- Remove memory card and put it back making sure the connection is not loose.
or
- Clean the gold contacts using pencil eraser. Remove eraser dust with cotton buds.
or
- Format the memory card on the camera.
- If all fails, use a different memory card.
Good luck.
Aug 25, 2010 | Nikon D70 Body Only Digital Camera
I have a Compact Flash card of 512mb (CF card) i use this card in my nikon D70, i went to my friend house and tried connection my camera to his comp to download image, but my friend machine was infected by...
Guide to recover deleted photos from Nikon D70?
Connect Nikon with PC
Using a USB cable or putting SD card into an SD card reader to connect Nikon with Computer.
Scan Nikon d70- Running the Nikon Photo Recovery,you can choose Nikon media drive and click "Start Scan" for scanning
Recover deleted photos
After scanning, you will see all recoverable media photos and videos with file type. At last, click "Recover" to recovering deleted Nikon D70 photos.
This Photo Recovery also can recover all photos files from Nikon D3100 like JPEG, BMP, TIFF, GIF, etc. Support all Nikon camera.
For full details please refer to Nikon D70 Manual.- https://guideusermanual.com/product-name-d70-manual&po=4425&lang=English
Mar 28, 2017 | Computers & Internet
Do the Nikon D100 and the D70 share the same in camera Compact Flash unit - not cards - but the hardware to accept and read the CF card? I have a bent pin in the D70 and want to know if I can change out...
I understand what your're looking for.
The D100 is basically an N80 with digital guts. It doesn't share the same chassis as the D70, although it does share the same excellent battery.
Other than that, the D70 was a new design, so it doesn't seem too likely that they would have the same CF sockets.
That being said, unless I had them both stripped apart on the table in front of me, I wouldn't make any bets. It just seems like there would be slight differences in mounting holes and configuration.
Oct 02, 2009 | Nikon D100 Digital Camera
Nikon D70
I have the same problem....after searching some say get new card (I did) some say reformat (I have), some say clean pins (I would try this but don't know how) SO if you get any answers I would appreciate it. The only temporary solution that I have found is to Re-format (thus losing pics) or to simply pull the card out and put back in.
Aug 20, 2008 | Nikon D70s Digital Camera
Nikon D70
Greetings,
It is actually an error message generated by your compact flash and means that the card is no longer readable. A lot of D70 owners have reported this error without being able to find another solution other than reinserting the card or changing the card to a different brand. In my D70s I use Sandisk Extreme III memory and, knock on wood, have not yet had this error. You could also try cleaning out the memory card slot and check to see that all pins are aligned and not bent.
Good Luck,
-WN
May 12, 2008 | Nikon D70s Digital Camera
"for" message on LCD
It means you need to format your compact flash card.  Or...it may be that you've been bitten by the infamous BGLD problem (Blinking Green Light of Death) that caused my D70 to eventually be replaced by Nikon.  Thankfully it was under warranty at the point, which yours will not be.
If you haven't ever formatted your card, this is probably the problem.  To do so, just hold the two buttons that say "for" in red on them down for a second so that the letters "FOR" start to blink, then do it again while seeing that.  Let go and wait a couple of seconds.  The FOR will be replaced by numbers that tell you how many images you have left on the card until it is full.  I format my cards EVERY time I put a card back in the camera.  This prevents bad locations from cropping up on the card and creating bad images (corrupt).
Dec 27, 2007 | Nikon D70 Digital Camera with 18-50mm Lens
My nikon d70 won't turn on and the battery if fully charged
The black spot i suspect was the CCD or processor failing. Checkout Nikon customer support re this.
Aug 05, 2007 | Nikon D70s Digital Camera
D70 digital camera
could be bent pin in the memory card slot
Jan 03, 2006 | Nikon D70 Digital Camera with 18-50mm Lens
Cameras Logo
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
