Question about Nintendo Wii Console
When I press A on remote i hear a beep but then get a blank screen. What can I do to get the menu to pop up?
  • jleon1 Mar 15, 2011
    I did everything you said but the menu still will not come up
  • 2,574 Answers
Double check to make sure that the video plug from the wii is in the right video plug on your TV. Change the channels to and aux channel (if you have one.) If you have a DVD player or surround sound system, they may also be conflicting with it. For me, I had to plug the wii into my DVD player, then change it to the auxiliary channel to get it to appear on my TV screen.
Use the steps that are given below:
  1. All the Nintendo GameCube controllers and Memory Cards are to be removed.
  2. The Wii console has to be closed after that.
  3. The Wii has to be removed after that.
  4. Then, you will have to wait for some while.
  5. After that, the Wii console has to be connected again.
  6. Now, start the Wii using the remote.
  7. Then, try to go to the menu.
  8. If it does not work even after that, then use the reset button and continue from the previous step.
Posted on Mar 15, 2011
It may have become "unsynced" from your Wii console. Make sure it has fresh batteries (the four lights should all come on and blink when you press any button, if it's any less than four, the batteries are not at 100%)
Try this:
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
How to resetdvrpassword
Password Reset Instructions
First make sure that the unit is turned off.
Then press and hold any button on the included infrared remote control.
While holding the button on the remote, power on the unit.
You should hear a single beep followed by a double beep. Once you hear the double beep, press 1 2 3 5 on the remote control. If entered correctly you will hear a double beep and the DVR will begin to boot. (If entered incorrectly, you will hear a sequence of about eight beeps and then a double beep to prompt you to re enter 1 2 3 5.)
Now that the DVR is booted, you will be prompted to enter the password which is now the default "1234". Using either the included infrared remote control or a USB mouse, press Menu, followed by System Setup. (Shown Below)
Then select the User tab, followed by Management. (Shown Below)
In the Management menu, press Edit next to the User ID you wish to change the password for. In most cases it will be the Admin account. (Shown Below)
On the Edit menu, press the Password tab and you will be prompted to enter the current password which is the default "1234". Press OK to continue. (Below)
Now you will be prompted to enter your new desired password. Press OK once complete. The password that you select must have a maximum character count of 8. Your password is now updated.
Dec 11, 2016 | Miscellaneous
My screen has parking brake on it all the time
  1. Make sure your Jenser VM9312 is on, and select AM/FM as your source.
  2. On your remote, press the Setup button, located on the lower right of the remote, you should hear a beep from your VM9312 when you press the button.
  3. Now, making sure you hear a beep after every key press, press, 543210.
  4. If you did this correctly, a new menu screen will pop up.
  5. On the display, press the hammer and screwdriver icon, located on the left hand side of the screen.
  6. Next press the menu line for brake override, a sub menu will appear.
  7. Select ON.
  8. Press the X at the lower left of the screen.
  9. Enjoy, and please drive safely, for a ticket is one thing, but a fatal accident you have to live with is forever.
Aug 19, 2012 | Jensen's VM9312 Car DVD Player
Cordless Extension handset (non-color) screen remains blank and does not connect to Multi Function Printer.
Hi, the handset is not registered with base, to register please follow this process:
1. On handset press Menu/OK.
2. Press cursor up or down to choose "Register HS", then press Menu/OK.
3. Press Menu, 0, 6 on the control panel of base unit (MFP)
4. Press OK on the control panel of MFP.
You should hear one long beep when the handset is registered correctly. If not (three short beeps) repeat steps from 2 to 4.
Aug 02, 2012 | Brother BCL-D10 - Cordless extension...
I unplugged my ps3 to put it into a different room and it worked fine, then i put it back in my room and now it comes up with a blank screen?
Connect your controller into the USB port and press the `P` button.
If still no joy, then hold the power button down at the front of the console until your hear one beep then eventually another. When the PS3 shuts down, let go of the button.
Then press and hold it again until you hear the first beep, 2nd beep then a double-beep.
This will bring up a 6 option menu, select `Restart System`.
This should sort the problem!
Good Luck!
Jul 04, 2010 | Sony Playstation 3 (PS3) Console
Blank screen, not reading dsc
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 26, 2009 | Sony Playstation 3 (PS3) Console
Playstation3
Becoz ur hard disc got corrupted ! But don't worry, U need swith on the PS3 & touch hold both the "Eject" & "Power/Reset" button for 20 secs or until a triple beep sound. It will restart the PS3 with a Message " Press X Button to restore the corrupted data ".. Enjoy.. !! =D
Jun 30, 2009 | Sony Playstation 3 (PS3) Console
Emergency brake wire connection
Here's a Bypass to solve that. Turn your 9312 on and set to radio then Using your remote enter 543210 and make sure you hear a beep each time, a new menu screen will pop up, click the hammer and screwdriver on the upper left side,Next press the menu line for brake override, a sub menu will appear, select ON,Press the X at the lower left of the screen and you're done enjoy and be safe.
Apr 12, 2009 | Jensen's VM9312 Car DVD Player
Computer starts up to a blank screen
2 BEEP MEAN PARITY ERROR OR PARITY CURCIUT FAILURE, HAVE YOU INSTALLED ANYTHING NEW THAT HAS MEMORY ON IT, RAM,AUDIO,VEDIO.
ROD
Feb 12, 2009 | Dell Latitude D630 PC Notebook
Jensen vm 9312 region code
You can get into the master system by using your remote. 1.Make sure your Jenser VM9312 is on, and select AM/FM as your source. 2.On your remote, press the Setup button, located on the lower right of the remote, you should hear a beep from your VM9312 when you press the button. 3.Now, making sure you hear a beep after every key press, press, 543210. NB:If you did this correctly, a new menu screen will pop up. 4.On the display, press the hammer and screwdriver icon, located on the left hand side of the screen.
NB: Here you can bypass the break and regions etc. When done Press the X at the lower left of the screen and enjoy.
Feb 01, 2009 | Jensen's VM9312 Car DVD Player
Programming a vcr
How can t I get the pop up screen when I apply menu. When I press menu nothing appends. I have the illico box for HD and had the videotron tech install it so I can recorded but since the menu does not work I cannot set the time or anything else on it.
Thanks
Gilles T Garceau
Dec 11, 2007 | JVC HR-A592U S-VHS VCR
Nintendo Wii Console Logo
24 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
