Question about Refrigerators
Where do you find the model and serial number on a built in KitchenAid Superba 42 side by side fridge? I looked everywhere even opened the top where the sealed system is and can't find it!
    President:
  • 1,961 Answers
Check the picture below for possible model number tag locations
Sometimes, the sticker bearing the model numbers tag can also be found on the compressor of the unit.
Let me know if I can help you further.
Please accept my solution if this help you right away.
Thank you for using Fixya.
Posted on Mar 15, 2011
Kitchenaid superba refrigerator
What is the model number? Do you see ice buildup on the freezer walls?
Dec 28, 2013 | Refrigerators
Kitchenaid superba making noise
Check the fan on the back and blow air through it to clear any dust accumulation.
May 04, 2017 | KitchenAid Superba KSRG25FK Side by Side...
Can you please tell me where the timer is located on the kitchenaid superba side by side refrigerator
there isn't a timer in your machine,you have a computer board or an adaptive defrost board,open the fridge door,on top where the controls are the board is in there,also look on the right hand wall on the fridge side up near the ceiling and you'll see a tag with the full model number,25 different machines showed up with the number you sent,go here and look at part number 6 this is your board new part number W10351625 this is the newest number and fits all kitchenaids.also check the defrost thermostat located on top of the evap coil,if it has a white plastic ring around the top of it and it's lifted up then this is your problem,when you have a defrost problem it's not a bad idea to change out the t-stat too,if you remove the front bottom kickpanel there should be a tech sheet on the panel or taped on the wall,this will tell you how to manually put the machine into defrost,you'll know if it goes into defrost when the evap fan in the freezer stops and the compressor shuts down,with the back inside freezer wall removed see if the heater comes on,if it doesn't,unplug the machine,cut the two wires going to the t-stat and connect them bypassing the t-stat,put it back into defrost,if the heater comes on the t-stat is bad part 2321799 ,or if you have a meter you can read out the heater and t-stat,you have a calrod heater in your model and they hardly ever go,if you bypass the t-stat and the heater doesn't come on change out the t-stat and the computer board.if it was a bad t-stat leave the heater on and with a hair dryer melt out all the ice,the heater will help you.good luck
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Refrigerator-Parts/Model-KSRG25FKWH18/0593/0165000/W0607116/00010?blt=06&prst=&shdMod=
Jul 07, 2012 | KitchenAid Superba KSRG25FK Side by Side...
Freezer fan is noisey and can t find serial number
The number you will need is the model number. On side by side models there are a few places to look. 1- inside fridge on right or left wall. 2- Open fridge door and look up near the top front lip. 3- Open both doors and look on body of fridge under the doors. 4- Fridge door sometimes there is a sticker right when you open. Mostly you are looking for a silver sticker or silver plate. It gives you a model number and serial number. If you need further assistance please mail me back.
May 26, 2011 | Kenmore Side by Side Refrigerator
Unable to sufficiently cool freezer as of couple days ago; temp higher than freezing point. The metal frame running between fridge and freezer is burning HOT to the touch; so hot that the rubber door...
check the coil to see if it needs to be cleaned and pull out the machine,if it's getting that hot the condenser fan motor could be dead.pull it out and remove the bottom panel in the back and make sure the fan is blowing and clean the condenser coil.the fan motr part number is W10124096 and it's around 85 to 90 dollars.if the fan isn't running you can stick any fan back there to cool down the compressor and get the fan motor as soon as possible,i've found mice stuck in the fan going for water in the pan or papers,if something is jammed in the blade hopefully when you pull it out it will still run but i think this is your problem,good luck.one more thing the model number you sent isn't the full number,you're missing a number on the end the model i looked up ended in 1 but the fan should be the same,you can open the fridge door,look up near the ceiling on the right hand wall and you should see the model number,if it's not there,look down near the bottom hindge on the fridge door,you might have to remove the bottom kickplate to see it,give the number to your parts store and they will sell you the correct part.
Apr 11, 2011 | KitchenAid Superba Architect KSCS25INSS...
I have KitchenAid Superba 2001 42 in side by side Refrigerator.. It has no model number because the previous home owner who bought the refrigerator apparently bought it as second hand or scratch and...
Open the refrigerator door and look for a LABEL . they have never made one that did not have it someplace .without a model ,NO ONE can assist you except perhaps a repairman that comes to your home
Sep 08, 2017 | KitchenAid Refrigerators
Need to find model # for ge monogram 42" side-by-side (1992?)
on the 42" Monograms the Model & serial nomenclature are usually located behind the top panel in the center section to the right of the compressor panel. Hope this helps....Bill
May 18, 2009 | GE Monogram Side by Side Refrigerator
Need ref charge in ozs suct press at temp for superba 42
Refrigeration charge in grams will be found on the label with the model number and serial number. The type of refrigerant is also on this label and the type of refrigerant which is more than likely 134a. You can weight the gas in or you can charge to 10psi, then run unit and adjust up or down as required.
Mar 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
How do i defrost a fridge?
To defrost a fridge, you simply move all of the food to somewhere it can stay cold and unplug the fridge. That's it!
The purpose of defrosting a fridge/freezer is to melt the ice that has accumulated around the condenser to restore it to maximum efficiency. Once it has melted (using a hairdryer can speed it up) you can plug it back in and put food back.
Mar 26, 2008 | KitchenAid Superba Architect KSCS25INSS...
Model Number
Open the drawer or bottom cover panel and look on the facing where the door closes to
Dec 04, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
70 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
