Question about Philips Digital Voice Tracer 7655
Hi I'm not sure which type of USB 2 mini I need to order for Philips Voicetrader 7650
  • Jean-louis Orban
    Jean-louis Orban Sep 15, 2016
    Good morning .Have you found your USB cable because I'm looking for one as well. This device has a special square USB. Thanks.
May problem is may usb is not recognise in computer? is ma i problem, end i need restore may digital voice
Posted on Mar 15, 2011
What type of USB cable do I need to upload picture to my computer
Hi U need a mini USB cable to STD USB U can buy them on E/BAY COST aprox $2-99 cheers
May 07, 2016 | PANDIGITAL SuperNova
Tip
Bluetooth Connection Guide Part 1
This is a "How To" for Connecting the Nokia Series 60 device (Nokia 7650, 6600, 3650, 3660 etc...) via Bluetooth TM with the Windows Widcomm software used by TDK, Billington, MSI and others Bluetooth USB Vendors. The steps are similar for other Series 60 devices and have been checked with the 3650 and 6600.
1.Pairing the computer and the Series 60 Handset
Pairing is the process of swapping pass keys and setting up a trusted connection between the Bluetooth USB adapter / card connected to the PC and the 7650 handset. Save any files and close any applications you may have been working on.
2. Set up Bluetooth TM on the 7650 by going to the Main Menu, selecting Connect and then Bluetooth.
3. Make sure the Bluetooth option is On and My Phone's Visibility is Shown to all. Remember what is in My Bluetooth Name - or edit it to one of your choice - this is what your 7650 will be seen as by other Bluetooth TM devices.
4. Right Click on the Bluetooth Icon in the system tray, on the menu that appears go to Setup and then click on Security.
5. A window appears and all being well the right hand pane will have your 7650 (titled what ever you have entered into the phone's My Bluetooth Name entry). If nothing appears click Refresh and your phone should then appear. Highlight the 7650 and click Execute Pairing.
6. A window will pop up asking for a PassKey. Enter in a numeric only passkey and click OK.
7. On the 7650 a screen pops up asking you to enter a passkey - key in the same number you just typed into the PC.
8. By default any connections from your PC to the 7650 must be manually accepted on the 7650. You have an option to set up a connection from the PC to your 7650 as authorized, this means when you connect from the PC to the phone it won't ask you if it's ok and will connect automatically.
9. To set it as automatic: On the 7650 in the Bluetooth TM Setting Screen, you joystick right to the Paired Devices screen, highlight the Computer you just paired with and press Options, select Set as Authorized and Yes. You will then see a padlock icon beside the paired device - this device will no longer require manual authorization for connections to the 7650.
Now you should set My phone's visibility to Hidden - so that unknown devices searching won't see your phone. You can still be connected to by any paired devices. Remember to switch it to Visible if you want to pair with a new device or receive a file / business card from someone with an unpaired device.
on Mar 06, 2010 | Cell Phones
Need a connecrtion/cable for downloading photos from phone to computer whats it called and which type do i need
Hi
Depending on your phone you will need either a mini - USB cable or micro USB cable. You can find them on eBay. Most likely Micro USB.
Micro USB:
http://www.ebay.com.au/itm/2M-3M-MICRO-USB-Cable-Data-Charger-For-Samsung-GALAXY-S4-HTC-ONE-M7-M8-/400691057892?pt=AU_MobilePhoneAccessories&var&hash=item5d4b0c54e4&_uhb=1
Mini USB:
http://www.ebay.com.au/itm/New-1m-USB-2-0-Male-A-to-B-Mini-5-Pin-Cable-Lead-XC03-/321443971464?pt=AU_CablesConnectors&hash=item4ad78dc188&_uhb=1
Aug 31, 2014 | Cell Phones
I need free driver download for Philips 7650
Go to www.dictation.philips.com/support/manuals and download the manual. There should be something in there to help you. If not post your problem on their site.
Feb 18, 2010 | Philips DVT 7650 Digital Voice Recorder
Driver of digital voice recorder 7650-X
You can download the drivers for this machine at www.dictation.philips.com in the support section.
Nov 25, 2009 | Philips DVT 7650 Digital Voice Recorder
I lost mi cable
http://www.grabcart.com/product/comp/harddrives/cbbstore7292/USB-Cable-Dual-Power-2-x-Type-A-to-mini-B-USB-2-0-1m
USB Cable Dual Power 2 x Type A to mini B USB 2.0
Jul 26, 2009 | Maxtor OneTouch III Mini Edition 120GB...
My archos wont responed anymore when i plug into my pc
Make sure the usb cable is not damaged you can try to connect to pc by docking the device to DVR station or mini charging dock too there is 2 type of connections available for charging stations. By using another type of Usb cables. Mini usb 5 pins to usb.Same cable used for sony PSP also.
http://www.showmecables.com/viewItem.asp?idproduct=258
May 11, 2009 | Archos Internet Media Tablet MP3 Player
I need to locate a usb adapter that I can upload pictures 2 PC.
Hello Charlotte,
This camera takes a standard USB cable that has a "4 pin mini B" end on it. You can buy this cable at most camera and computer stores. There is another type of "mini" USB connector so make sure you get the 4-pin mini B type. For best results, take the camera with you and make sure the cable fits into the slot on the camera before you purchase the cable - that way there is no way to get the wrong cable. Good luck
Dec 28, 2008 | Fuji FinePix A303 Digital Camera
Philips Digital Voice Tracer 7655 Logo
490 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
