Question about Microsoft Xbox 360 Console
Hi guys Please I need your help as I'm desperate and I can't find any solution for my problem. Three months ago I put to play the new "Need for speed Hot persuit" (not the original one) and I was been asked if I want to do update.Unfortunately I press yes and from then it has been stuck and it says "CAN'T READ UPDATE FROM DISC" and appears on the screen the following numbers 22FB-3080-2200-0700-C000-0034 I can't even enter to main menu screen.(dashboard) I can;t do nothing . I have never used xbox online pls,psl help me someone.
  • 8 Answers
1. Anote second hex data 22FB-3080-2200-0700-C000-0034 and go to http://easycalculation.com/hex-converter.php
2.
Convert it to decimal and get the update number:
Hex:
3080 - Decimal: 12416 Update
3. Go to http://dl.console.se/index.php?dir=Xbox360/uppdateringar/ and seek the correct update. Download it.
if not try to locate it on google)
4. Extract $Systemupdate and put it into root of a pendrive formatted in fat32 or a CD
5. Turn off the console and plug the pendrive or insert the CD
6. Turn on the console and wait
7. Enjoy!
Posted on Aug 23, 2011
  • 3 Answers
Its a problem with your disc drive. It always starts with only 1 or 2 problematic games before eventually all stop working. Sometimes when you put the disc in it will say "Play DVD" or "disc not recognized". Unfortunately this problem only gets worse until everything is unplayable.
Posted on Mar 15, 2011
3 Suggested Answers
SOURCE: I GET A MESSAGE STATUS
Holding the sync button on the console as per other forums didnt work initially, so did it loads of times:
Had the disc loaded that caused problem, held sync button on the console and powered off and on still holding the button on. Powered off each time the error screen came back up while all the time holding the sync button on the sixth attempt it went past error screen and up to dashboard.
I went to load disc again and it asked me for update again so chanced it, this time it extracted update ok and then rebooted to dashboard ok.
Console now running fine, oh and Assassins Creed was the game that caused the initial update error, and Assassins Creed was the disc that I used in the multiple reboots which eventually cleared update fault.
Hope this helps as no other info on web that I could find.
Posted on Feb 19, 2011
ccarmac1
  • 199 Answers
SOURCE: Hi a have a problem
Hola,
Su xbox esta modificado, tienes que actualizar su modificacion y despues actualizar su consola
Gracias
www.1RepairStop.com
Posted on Sep 20, 2011
Hi. I have had this player for less than 3 months. The player is now not reading dvd's - old, new, or homemade. It says it is "loading" then "cannot play disc." It still plays...
If you have had it for 3 months it is more than likely still under warranty. In many instances it may need a replacement optical pickup or optical assembly.
Depending on where you bought it from, as well, you may be able to take it in and get a replacement.
Sep 06, 2011 | Televison & Video
I have Nokia E71 mobile phone. Since, about two months ago, I have problem with message "Insert SIM card". I need solution for this problem. I have last SW version. I tried hard reset and I take...
Inserting some folded paper behind sim to hold the sim tight to the slot does seem to have worked. Try it.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
Aug 18, 2011 | Nokia E71 Smartphone
I Bought a Bravo series 300 Washer and Dryer 18 months ago. They came with a 1 yr. manufacture warranty The first month I had problems with the dryer which was covered under warranty.. It was inconvenient...
hi,
usually most areas have a USED appliance store. usually these guys will have a bunch of old fridges and stoves around outside the store. Our town has three or four of them. you may have to ask around but these guys usually have parts for cheap. and they will sometimes make house calls. try googling used appliances in your area. they may also set you up with a cheaper washer with a METAL tub.
good luck
jm
Nov 15, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
96 Chrysler LHS heating up w/new thermo,fans,pump
check that it is not up side downmight need new radiator
Oct 31, 2009 | 1996 Chrysler LHS
Playing Call of Duty 4 Online - PS3
if you are using a wireless connection the signal may be to weak. if not you can try deleting your game and save data. you will lose any single player saves you will also have to re download any map packs you purchased. the game should also do an update when you load again after deleting the game and save.
May 08, 2009 | Activision Call of Duty 4 Modern Warfare...
Trying to cut out
replace the fuel filter again...... ive seen them colapse new and cloging the line. have autozone scan for free good luck
Sep 20, 2008 | 1999 Ford Explorer
DVD freezing up
It very well could be a lens problem.
When the laser is in a desperate search for more data, it can max out the whole unit trying to find it. Same thing will happen with a PC's dvd drive if you put a dvd in and it is scratched or damaged.
The lens in your unit may not be dirty, but it may need to be calibrated again. Knocks in transport, dust, bugs, general use etc etc can all have an effect on the laser.
The fact it's doing it in a cycle could also be heat related. Again this goes back to the calibration. If the laser is working far harder then it should, it will heat up and begin to fail.
Since it is only a few months old though, I would call in on the warranty to have it looked at without causing you further grief.
Apr 30, 2008 | Sony DAV-IS10 System
Microsoft Xbox 360 Console Logo
226 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
