SOURCE: orange cartridge light error keeps on blinking!
it sound like a bad carriage assembly: part # C4713-60039
it lists for around $147.
Hope this helps
SOURCE: PS2 SLIM NEW .NO VIDEO OUTPUT
try changing the av channel or if you are using a scart lead try taking out the three leads red yellow and white and put them in the front or side of the tv if you have this access.
SOURCE: hp designjet 430
This usually is solved by removing and reinstalling the ink cartridges...make sure the electrical contacts are clean (use a dry paper towel) on both the print cartridge and the carriage.
If the error still happens then the carriage or trailing cable are bad and will need replaced.
SOURCE: LED Head Missing, Color:Magenta
Take out the magenta cartridge to the right upper indside wall of the printer you should be able to see a small rectangular window, give it a blow of wipe with a cloth, do the same to the corresponding part of the m toner, put the drum and toner back, shut the lid and everything should be ok. If not contact oki for a replacement drum/cart.
SOURCE: 42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
