Question about Sharp Office Equipment & Supplies
Sharp sf 7900 copier, after paper jammed and removed the trouble shooting code light H-4 keeps flashing
    Guru:
  • 254 Answers
HELLO
try to remove or unplug the power from the outlet and also same at the back of the printer and wait for 5 minutes and put it back on
just leave comments
thank you
Posted on Mar 15, 2011
Error code h5-01
That error aprears from having the same paper jam over and over. It is possible that you did not get all of the paper out of the machine. Otherwise most likely you have an issue with a sensor in the paper path you could try blowing all the sensors with canned air. Turn off both power butmtons or use sim 14-1 to clear the trouble and have it try starting up again.
Dec 19, 2013 | Sharp SF 2540 Copier
I removed a paper jam. red light is still on (not flashing).
There is probably still paper stuck in the paper path, this is very common. What happens if you load it with paper and press the test button?
Feb 08, 2010 | Samsung ML 2010 Laser Printer
Sharp sf 2014 copier problem
clean the paper feed rollers with soap and water damp cloth take paper tray out use flashlight to locate rollers also clean registration roller under the drum check and see if u have any broken gear teeth on your fusing assemby also if after cleaning it works i recommend u replace feed rollers
Jun 04, 2009 | Sharp Office Equipment & Supplies
MISFED INDICATOR LIGHT FLASHING
There is no code to run.
Did the paper come out as an entire sheet? Or was it torn? There is either a small piece of paper that remains in the machine, or you dislodged a paper switch in removing the jam.
Apr 23, 2009 | Sharp AL 1631 Copier
I own a sharp SF-7900. My pages are coming out black
I'm sure you may find a manual, but your copier is rather old.... When you make a copy do you get a error code? How about when you make a copy, do you see the scanning lamp turn ON? Here is you thing you can try, make sure the Primary Corona unit is pushed in all the way in. It has a grey handel on it and it should be found right above the Drum... Good Luck
Apr 19, 2009 | Sharp Office Equipment & Supplies
Paper Jam light on, but no paper jam
A piece of paper torn from copy paper is caught around registration switch, exit switch or feedshift switch.
so check theme.
Jan 18, 2009 | Sharp AL 1631 Copier
Sharp SF-2014 Copier Jams
1-check and make sure the paper sizes coreresponds : If using Letter it must indicate 8 1/2x 11 or (Letter) not Legal or 8 1/2 x 14.
2- the tires are slipping and trowing the timing off. change tires (cheap)
Aug 20, 2008 | Sharp Office Equipment & Supplies
Sharp SF-1118 copying machine H 4 Error
Open right side door and check for a jam in the fusing unit (the one that is normally hot). Remove jam carefully. Hit P * C * and enter 14. Push the start button like you are making a copy. Machine should reboot and code should not return. if it does, you may have a dirty themistor, or blown lamp.
Jan 01, 2008 | Sharp AR-207 Copier
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
