I am after a manual for Altech ALTHC014 THERMOSTAT please can you advise me where to get one from thank you
2 Suggested Answers
SOURCE: need a manual for altech althc014. have no idea
Ive been having the same problem! I found these instructions on a forum if it helps-
To Set the Temperature
The reason the stat is coming on during the night/ always being on is setting number 5, there are 5 settings on the Salus
1 is the time you want heating on eg, 07.00 and set the temp (20)
2 is the time you want it to go off eg, 10.00 and set the temp (10 this will turn it off)
3 is the time to come on an evening eg. 17.00 and set the temp (20)
4 is the time you want it to go off eg, 23.00 and set the temp (10 this will turn it off)
5 the problem many people have is that they do not set number 5 correctly, this is a night/ frost stat and if you don't set the time and temperature same as 4 ie, 23.00 and 10*c then the heating will stay on.
How do I set the time and date on my Salus programmer?
· Press the Set and Select buttons simultaneously to enter the clock setting mode.
· By using the "UP" and "DOWN" arrow you can select between 12Hr or 24Hr clock. Once selected press "SELECT".
· The "HOUR" will now be flashing. Adjust with the "UP" and "DOWN" arrow keys to the desired time. Press "SELECT".
· With the "MINUTES" now flashing adjust with the arrow keys to the correct minutes. Press "SELECT".
· Now the "YEAR" will need adjusting. Again use the arrow keys to change and press "SELECT".
· Now adjust the "MONTH" with the arrow keys and press "SELECT"
· Next to change will be the "DAY OF THE MONTH" again with the arrow keys change and press "SELECT"
· "dLS" will now appear. This is the "DAY LIGHT SAVING" mode to turn "ON" or "OFF" use the "UP" and "DOWN" arrow keys. Now press "SELECT"
Posted on Nov 15, 2010
I need User Manual for Altech ALTHC004
Try Googling (Altech)(ALTHC004)(manual) without parens.
Apr 28, 2017 | Computers & Internet
Altech althc014 thermostat
you have 2 possibility
1maybe the batery is dead and the remote doesn-t work
2maybe the contacts of the battery is not perfect(oxidate contacts)
Jan 05, 2014 | Heating & Cooling
Altech thermostat rf
In order to heat whatever medium it heats. Example, if the system is hot water, that hot water will cool below the boiler's internal thermostat set point after it's circulated throughout the house and returns to the boiler. To continue maintaining the preset internal temperature of the water, the boiler has to come on. This is normal operation, nothing to worry about.
Nov 13, 2013 | Heating & Cooling
Where can i get oprating instructions for altech model, alth c004 thermostat control fitted to my boiler
hi sorry this isn't a solution, just moved into a new house & i have the same thermostat, just wondering if you found where to get a manual from please? or if you could tell me how to simply turn the heating on & off instead of faffing about with all the silly buttons & settings lol, thanks alot,
Casey :)
Jan 04, 2012 | Heating & Cooling
I need programming info for an Altech model ALTHC001 central heating and hot water programmer
Can you please tell me how to set clock for central heating the clock is an althc001 had power switch off and when it was turn back on the clock is not working when the boiler is calling for heat and the same with the heating can you help
Oct 07, 2011 | Honeywell Programmable Thermostat Heater
I need user instructions for Altech ALTHC014 digitol thermostat
Here you go, this is pretty much identical to the Altech unit you're describing (Salus RT500RF Manual (SALR503) 531ESALR50310A95), I have the Altech ALTHC014 too, I have checked them against each other. Hope this helps, this is probably why you can't find the Altech manual, as the Salus one is the same and they haven't bothered rebranding this manual to Altech.
Dec 03, 2010 | Heating & Cooling
Need a manual for altech althc014. have no idea how to use it. can't work out how to just turn on without the timer!!
Sep 27, 2010 | Heating & Cooling
We have an ALtech shower booster pump 50Si fitted. It was installed about two years ago. Currently it is not working at a constant speed, you can hear the pump speeding up then slowing down. Any advise...
The pump and the filters need cleaning to put it back to
normal. You are right. Just send in your e-mail for more
assistance. God bless u.
Jul 09, 2009 | Plumbing
Heating & Cooling Logo
115 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
