Question about HP LaserJet P2015dn Printer
Cannot print. Triangle light blinks, I push the green button and it starts turning but almost sounds like it cannot grab the paper. Tray is not too empty or too full.
    Genius:
  • 1,089 Answers
If the "attention" light is the only light on (in your case blinking) that means that the print cartridge door is open. Pull out the cartridge and make sure that the door closes. Install the cartridge and close the door.
Posted on Mar 16, 2011
What does the button on the the 1320n that has a triangle with an exclamation mark mean? The light next to it is blinking and we don't have a manual.
Attention light is blinking
This state can be reached in the following circumstances:
? Paper tray is empty
? Door open
? Paper jam
? Misfeed from tray
1. Verify that the print cartridge is present and that the print-cartridge door is closed correctly.
2. Verify that media is present in the input tray.
3. Clear any jams and perform paper-path functional checks.
4. Make sure that the interlocks are operating correctly.
To reset the printer after a jam, press the GO button.(Green Button)
Sep 21, 2011 | HP LaserJet 1320n Printer
Triangle with exclamation mark is flashing orange. What's the problem with it?
This usually indicates one of the following issues have occurred. Perform the following in the order provided to troubleshoot and resolve the issue.
1. Insufficient power. Disconnect the power cord from any surge protectors or power strips and plug the unit directly into an electrical wall outlet.
2. There is a paper jam in the printer.
3. The top cover is open. Open the top cover, reseat the print cartridge, and close the top cover, making certain it is shut properly.
4. No paper was loaded in tray 2 or the tray was not loaded properly causing a mispick.
A. Pull the tray out of the printer and remove any paper.
B. Move the blue side width guide outward to match the paper size that is being loaded. Locate the blue guide pointer on the left side of the tray. If using a letter-size (8.5 by 11 inch) paper, match the guide point with the LTR/LGL engraving located on the bottom, left-side of the lift plate.
C. Locate the blue tab on the rear paper-length guide. Locate the triangle-shaped pointer in the middle-right on the bottom of the tray. Press on the blue tab and adjust it so that the triangle-shaped pointer matches the paper size that is being loaded. If using letter-size (8.5 by 11 inch) paper, match the triangle-shaped pointer with the LTR engraving on the bottom of the tray.
D. Place the paper in the tray and make sure that it is flat at all four corners. Keep the paper below the height down arrows on the paper-length guide in the rear of the tray.
E. Slide the tray back in the printer.
5. The tray 2 paper level indicator is stuck.
6. If the printer comes back to a Ready state, print a Self-Test/Configuration page. If the printer is not in a Ready state, proceed to step 7.
A. Verify the printer is in a Ready state. (The green LED next to the U-shaped icon is on steady and no other lights are on.)
B. Press down on the green GO button until the orange Attention light comes on (approximately 5 seconds), and then immediately release the GO button. The green GO button will begin to blink and a Self-Test/Configuration page will print.
7. If the attention light is still on, perform a cold reset. A cold reset, sets most, but not all, default variables stored in NVRAM back to the factory default values. It typically does not reset the page count, paper tray sizes, localization language, or formatter number. Complete the following to perform a cold reset.
A. Turn the printer off.
B. Press and hold down the green GO button.
C. Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
D. Release the GO button.
NOTE: If both the Attention light and the Ready LEDs turn on before the GO button is released, the cold reset procedure must be started over at step 1.
E. The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state.
Feb 07, 2011 | HP LaserJet 1320 Printer
Printer makes noise and doesn't print. The triangle sign is lit up.
The printer displays an orange blinking attention light which will not clear.
1.Insufficient power.
2.There is a paper jam in the printer.
Click here for information about clearing paper jams from the HP Web site at http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00230694.
3.The top cover is open.
4.No paper was loaded in tray 2 or the tray was not loaded properly causing a mispick.
Perform the following steps to load tray 2.
a.Pull the tray out of the printer and remove any paper.
b.Move the blue side width guide outward to match the paper size that is being loaded. Locate the blue guide pointer on the left side of the tray. If using a letter-size (8.5 by 11 inch) paper, match the guide point with the LTR/LGL engraving located on the bottom, left-side of the lift plate.
c.Locate the blue tab on the rear paper-length guide. Locate the triangle-shaped pointer in the middle-right on the bottom of the tray. Press on the blue tab and adjust it so that the triangle-shaped pointer matches the paper size that is being loaded. If using letter-size (8.5 by 11 inch) paper, match the triangle-shaped pointer with the LTR engraving on the bottom of the tray.
d.Place the paper in the tray and make sure that it is flat at all four corners. Keep the paper below the height down arrows on the paper-length guide in the rear of the tray.
e.Slide the tray back in the printer.
5.The tray 2 paper level indicator is stuck.
Click here for instructions on repositioning the tray paper level indicator (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00276974).
6.If the printer comes back to a Ready state, print a Self-Test/Configuration page.
a.Verify the printer is in a Ready state. (The green LED next to the U-shaped icon is on steady and no other lights are on.)
b.Press down on the green GO button until the orange Attention light comes on (approximately 5 seconds), and then immediately release the GO button. The green GO button will begin to blink and a Self-Test/Configuration page will print.
7.If the attention light is still on, perform a cold reset.
a.Turn the printer off.
b.Press and hold down the green GO button.
c.Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
d.Release the GO button.
e.The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state.
This is generic information for HP laserjet printer,
if you still have problem, please leave the printer model and make as comment and we may hel you
Rnj VINODKUMAR
Oct 17, 2009 | Office Equipment & Supplies
THE ORANGE LIGHT IS ON AND NOT PRINTING
Blinking Attention Light HP LaserJet 1320 Series Printer - The printer displays an orange blinking attention light which will not clear. This usually indicates one of the following issues have occurred. Perform the following in the order provided to troubleshoot and resolve the issue.
4. No paper was loaded in tray 2 or the tray was not loaded properly causing a mispick. Perform the following steps to load tray 2.
Oct 02, 2009 | HP LaserJet 1320n Printer
Keeps giving me E2 not printing a paper will com e through when
If you hear the printer trying to grab the paper (you also may see that the rollers turn) but it does not grab the paper , means the the rubber that grabs the paper are dried, and should be replaced.
If the rollers do not turn (no sound either) then there is a problem with printer's mainboard.
Meanwhile (if you need it urgently) put more pages in tray to add volume (will press the paper to the rubber).
Mar 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I have a HP LaserJet 1320n printer and it will not print. An orange light keeps flashing by the triangle with an exclamation point in it. I printed a test page and it was okay. It will not print...
Possible Solution to your issue!
Feb 23, 2009 | HP LaserJet 1320n Printer
An orange light is on next to the triangle with the ! in it. I thought it was out of ink but have just replaced the cartridge and its still doing nothing!
Perform the following in the order provided to troubleshoot and resolve the issue. 1. Insufficient power. Disconnect the power cord from any surge protectors or power strips and plug the unit directly into an electrical wall outlet.
Jan 09, 2009 | HP LaserJet 1320 Printer
HP laserJet 2100 prints blank from manual tray
I bet you have a bad USB wire.Change the wire and I suggest reinstalling the drivers.
Oct 31, 2008 | HP LaserJet 2100 Printer
Printerndoes not respond
I thought my printer died on me, but it turned out it was a simple paper jam. The whole printer just locked up because of a paper jam! All I had to do was open the top compartment, remove the toner and get rid of the paper jam
Jul 25, 2008 | HP LaserJet 1320n Printer
Yellow light
    1. Pull the tray out of the printer and remove any paper.
    2. Move the blue side width guide outward to match the paper size that is being loaded. Locate the blue guide pointer on the left side of the tray. If using a letter-size (8.5 by 11 inch) paper, match the guide point with the LTR/LGL engraving located on the bottom, left-side of the lift plate.
    3. Locate the blue tab on the rear paper-length guide. Locate the triangle-shaped pointer in the middle-right on the bottom of the tray. Press on the blue tab and adjust it so that the triangle-shaped pointer matches the paper size that is being loaded. If using letter-size (8.5 by 11 inch) paper, match the triangle-shaped pointer with the LTR engraving on the bottom of the tray.
    4. Place the paper in the tray and make sure that it is flat at all four corners. Keep the paper below the height down arrows on the paper-length guide in the rear of the tray.
    5. Slide the tray back in the printer.
  5. The tray 2 paper level indicator is stuck. (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00276974).
    1. Verify the printer is in a Ready state. (The green LED next to the U-shaped icon is on steady and no other lights are on.)
    2. Press down on the green GO button until the orange Attention light comes on (approximately 5 seconds), and then immediately release the GO button. The green GO button will begin to blink and a Self-Test/Configuration page will print.
    1. Turn the printer off.
    2. Press and hold down the green GO button.
    3. Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
    4. Release the GO button.
    5. The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state.
  8. If the issue persists, please contact Hewlett-Packard's Customer Care phone center for further assistance. at http://www.hp.com/support.
Mar 12, 2008 | HP LaserJet 1320n Printer
HP LaserJet P2015dn Printer Logo
357 people viewed this question
Ben Johnson
