Question about Xerox Office Equipment & Supplies
Ink stiks jamed - Xerox Office Equipment & Supplies
    President:
  • 2,072 Answers
The best way to remove those sticks it to take a screw, like a dry wall screw and screw it into the block and slide it back out of the entrance. If you break it, just be careful with some needle nose pilers or some hemostats to remove the remaining pieces.
Posted on Aug 02, 2008
How do you check the oil level in a 2002 yamaha yz250
check view port or pull dip stik?? if u cannot see view port, and the dip stik is not a true level dip stik; gita long tie wrap and dip it in the oil fill hole until it bottoms out . then with draw and see if there is ani oil in the crankcase. its how i do my 1975,900,z1,kawa
Apr 21, 2013 | Motorcycles
Maintenance cartridge is Missing on a hp design jet z6100
in the cartrige there is a white stik about 10x30mm .If there is an ink on it the Plotter can't detect the cartridge..So just wipe out the ink on it an everything should be fine.
Jul 06, 2011 | HP Designjet Z6100 InkJet Printer
Am tryin to download my daughters homework on to her memory stik but i dont know how to do it
If you are downloading something, you usually have two options; Open (Run) or Save. You will want to select Save, and then browse to the memory stik to select it as the location to save the data. Make sure your memory stik is plugged into your computer. When you are browsing for your memory stik, it should be located under the directory Computer. Click Computer and browse for the name of your memory stik. Click on your memory stik and you can save the data here, or you can create a new folder on the memory stik to save the data in.
Jun 28, 2010 | Computers & Internet
HP 8750 Ink cartridge cradle keeps jaming
Yes! it is possible to repair this fault economically. Usually you could have it replaced with a fairly used one if you don't want replace with a new one.
Mar 24, 2010 | Office Equipment & Supplies
Memory stik problem in k530i
I hope if you did master reset this will resolve your problem.
Nov 21, 2008 | Sony Ericsson K530i Cellular Phone
Pictures are green
some ink delivery vesseles could be jamed
try to clean the cartige holder with a glass cleaning solution pour so the liquid makes its way and open the jamed tiny tubes which delivers the ink then dry it with a piece of cloth
Jun 01, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Ink System Failure
I just had this problem with a HP C5150 and I found this bit of conversation on the web and it worked for me.
My error code was 0xc18a0501 and the following steps did resolve my issue, hope it helps you as well.
  • OK I had the hp error code 0xc18a0001 problem and here is the conversation I had with the tech.....
    james cowan: hp error code 0xc18a0001
    Earnest: I will assist you in this regard
    james cowan: great
    Earnest: I understand that a error code with 0xc18a0001 with "Ink System failure" is displayed on the front panel of the All-In-One printer. Am I correct?
    james cowan: correct
    Earnest: Thank you for confirmation
    Earnest: May I have the model number of All-In-One you are using?
    james cowan: c6250
    Earnest: Thank you for information.
    Earnest: James, please let me know the room temperature in which printer is replaced
    james cowan: 67 degrees f
    Earnest: Okay
    Earnest: Please perform the below steps on the front panel of the printer to resolve the issue
    james cowan: ok
    Earnest: Press and hold the "left arrow" key.
    Press the "Setup" key and release both keys, Display should say "Enter Special Key Combo"
    Press and release the "OK" button.
    Earnest: Please ignore the above steps, James
    james cowan: ok yes nothing seemed to do anything
    Earnest: Press and Hold the "Print Photos" &"Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo"
    Press and release in sequence"Red Eye Removal","Print Photos","Red Eye Removal"
    Earnest: Display should say “Support” and display the FW rev (something like R0616R)
    james cowan: COxxFN0723BR j
    Earnest: Okay
    Earnest: 2. Press and release the right arrow button until the display says “System Configuration Menu
    james cowan: ok
    Earnest: 3. Press and release the "OK" button.
    james cowan: ok and it says hardware failure status
    Earnest: Display should say "Hardware failure status: Clear. Press OK to clear".
    Earnest: Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
    Earnest: Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
    james cowan: ok
    Earnest: Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
    Earnest: Let me know once you are done with the above steps
    james cowan: ok its unplugged
    Earnest: Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
    Earnest: Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE".
    james cowan: ok
    Earnest: Let me know the message displaying on the front panel of the printer
    james cowan: printer preparation occuring - do not interrupt
    Earnest: Okay
    james cowan: ok its done
    Earnest: Let us print a self test page from the printer now
    james cowan: ok deal
    Earnest: 1) Load letter, A4, or legal unused plain, white paper into the input tray.
    2) Make sure that the printer is on and loaded with unused plain, white paper.
    3) Press Setup . The Setup menu appears.
    4) Press the down arrow button to select Tools , and then press OK .
    5) Press the down arrow button to select Self-test Report , and press OK .
    james cowan: ok printing
    Earnest: Okay, please check whether all the colors pritned perfectly on the test page
    james cowan: perfect
    Earnest: Great..Cheers!!!
    james cowan: thank you very much
    Earnest: James, now you can continue using the printer
    Earnest: I appreciate your efforts and patience in trying to resolve the issue."
May 26, 2008 | HP Photosmart 3210 Printer
Deleting photos
your memory stik must be glitching. ok delete the photo, turn the phone off. take the memory stik out. turn phone on. then put memory stik back in. that might work
Dec 02, 2007 | Sony Ericsson W850i Cellular Phone
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
