Question about Canon Pixma MP800 All-In-One InkJet Printer
I have a Canon MP800 and it refuses to turn on... sometimes it will work. It was on a minute ago but now that i turned it off it wont turn back on.
  • Canon Master
  • 1,381 Answers
Hello tha_little_g
If a printer behaves likes this, then it means it is having a power problem. .
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Best regards
fanaudi .
Posted on Mar 15, 2011
Hi sonu myname is mandeep i have a problum with my canon mp800 printer it has a paper jam alarm can u help me
Yes Sure!!!!
Just Take a Size 10 Envelope Insert it on to the Paper Feeder and Move the Envelope Back and Forth for about 20 Times as Fast as you can!
Once Done with it, Turn the Printer Upside Down and Gently Shake it so that if it has any Obstacles in it Would Come Out.
Once Done with all this Turn on the Printer and Check If you still have the Same Error.
The Printer has a Hardware Problem and needs to be Replaced.
Good Luck!!!!!!!
Oct 22, 2011 | Canon Pixma MP800 All-In-One InkJet...
Canon pixma mp800 manual Pixma MP800 Printing cannot be executed because the lock switch is on. Question where is the lock switch ?? Release the scanner lock? Where is the scanner lock and how can I...
Doesn’t sound like your are making it into service mode, make sure the inner door is all the way up, make sure the top is closed, make sure both feeders have paper in them, make sure to turn off the power but do not unplug it. Start by pressing the stop/reset button first and then power button.
Aug 14, 2010 | Canon Pixma MP800 All-In-One InkJet...
Canon MP800 Error code 6A00 alarm flashing .turned off overnight ,turned on not working ,still same code and alarm . Will not do anything . Thanks ...
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 09, 2010 | Canon Pixma MP800 All-In-One InkJet...
Foutcode 6500 pixma mp800
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement .........
Jan 08, 2010 | Canon Pixma MP800 All-In-One InkJet...
How to reset printer to recognize refilled cartridges
Reset is not needed. Just turn off your printer power supply and turn it on. It will automatically detect the newly installed cartridge, provided the original compactible cartridge is installed.
Aug 03, 2009 | Canon Pixma MP800 All-In-One InkJet...
Canon Pixma MP800 All-In-One InkJet Printer Logo
160 people viewed this question
old marine
old marine
