Question about Bose Companion 3 Computer Speakers
Companion 3 were plugged to 220v instead of 110v. What can i do??
Hello people, I have a problem and was hoping you could help me with it.
I have bose companion 3 speakers and not thinking i plugged them into 220 input instead of 110. They don't seem to work anymore. I am trying to open them up to see if there is something i can do.
But it seems impossible to open them up. The screws on the back dont do anything... and there is one big golden cover underneath which i cannot open.
Does anyone knows how I can open or fix them up?
Thank you
  • msingh36 Aug 10, 2008
    Hi Dear
    I am also facing the same problem as stated by you..I bought companion 3 from US some 10 days back and mistakenly plugged them in 220 V.Then I also bought step down voltage converter but to no help..
    Let me know how u resolved it
  • 167 Answers
Alot of speakers have some kind of glue or epoxy, so if the screws vibrate out the glue will hold it together. you may have to pry the panel off. hope this helps! good-luck, glen.
Posted on Aug 02, 2008
3 Suggested Answers
cjackHD
  • 71 Answers
SOURCE: Does the Bose companion 3 have an internal fuse?
Yes. The companion 3 system can be repaired for $75. Call Bose at 800-367-4008. They will also give you a new 1 year warranty.
Posted on Jun 21, 2009
harit1988
  • 149 Answers
SOURCE: The transformer on my Bose Companion 3 may be dead
you need to change the adapter . there is no way you can repair
Posted on Jul 07, 2010
I just bought a computer speaker but it's 110v and my computer is 220v. can i plug the speaker to the computer without damaging the speakers?
Hi ,
If it says it needs a AC 110V connection , you will fry at least the sub . Don't do it ! Connect the device to an AC 220 / 110 V transformer you can find on the net or in all specialized retail shops .
Best regards
Feb 03, 2011 | Bose Companion 5 Multimedia Speaker System...
I plugged my companion 3 system into a 220v system in south america. i had the transformer to reduce it down to 110v but i was excited to set it up and forgot to use the transformer reducer... now...
myhairsonfir i did the exact saem thing today im gutted! im also in south america (chile) so found your post to be remarkably similar, though if im honest i only just went out and bought the transformer after it did not work.
Have you managed to resolve your problem? did you get a new fuse?
I hope to hear from you.
Tom
Aug 12, 2010 | Bose Companion 3 Computer Speakers
I wanted to purchase a Bose companion 3 set from the US through ebay. i wanted to know whether they work on 220V and if not how can I make them work at 220V.
Since this unit dose not come with power adaptor. It has direct plug in in to the port behind the sub-woofer unit and other end to the wall outlet. Is there any way to convert the power supply from UK to US (220v to 110v). For example Desktop PCs have a switch behind every desktop unit to change power from 110v to 220v or vise versa.
Anyone has any idea how to make this happen in Bose Companion 3 system.
I bought it from UK and now moved to US and I want it to work in US.
othervise use waltage adapter to use it
Aug 08, 2010 | Bose Companion 3 Computer Speakers
Jul 07, 2010 | Bose Companion 3 Computer Speakers
Bose Companion 5 110v/220v short circuit
The fact that everything but the power amp is still working, it could be only a fuse protecting the output that needs replacement although this fuse is probably circuit-wise after the main fuse you have already replaced and could be soldered on the board. Worst case, the output modules are blown and require replacement and depending on the power level it may be worth repairing instead of replacing.
Most modern electronic devices can be set or adapted to line voltages from 100-240 Volts and a good percentage of the devices, using the common switched mode power supply don't need any changes made by the user since they can be inherently 'auto-ranging.'
Apr 04, 2010 | Bose Companion 5 Multimedia Speaker System...
Jun 19, 2009 | Bose Companion 5 Multimedia Speaker System...
Bose Companion 5 Problems
email support@bose.com or contact a Bose Support Specialist in Germany; or call US support at 1-800-367-4008. Something very odd is happening here. You are using the same laptop, correct? If not, let me know, as there are some things to try. If Bose has a solution, I'd love to hear it.
Mar 19, 2008 | Bose Companion 3 Computer Speakers
Bose Companion 3 Computer Speakers Logo
768 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
