Question about Refrigerators
I have a Samsung da99-00494v . The freezer is working okay. The fridge temperature is showing 1c but it does not seem to be cooling. There is no noise either from the fridge. The light and door open buzzer working okay also. Any ideas whats wrong please?
watugot
  • 290 Answers
SOURCE: freezer works but fridge remains warm.
The same fan that circulates air in the freezer also blows air in to the fridge. If you open the freezer door and hold the door switch closed you should hear the fan running. If not you have a failed motor or motor control. Look at the back wall of the freezer section and see if there is a heavy frost build up. If so. you have a defrost system problem. Please post back with what you find and with the complete model number and I will try to walk you through the steps of checking everything.
Thanks/Mike
Posted on Oct 27, 2007
SOURCE: my samsung fridge freezer da99-00494v
just had same problem
you can
1. turn off and defrost
2. remove all panel of fridge ( inside) fan has got bloked with ice and cannot cool fridge.
Posted on Jun 15, 2008
  • 2920 Answers
SOURCE: fridge left open all night and wont cool but the freezer still works.
time for a new fridge
Posted on Aug 27, 2008
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
SOURCE: Hotpoint Mistral Frost Free Fridge freezer - fridge not getting cold
We have just had to call out an engineer to get our 1 1/2 year old Hotpoint Graphite Frost Free Fridge Freezer repaired. The fridge had almost entitely stopped cooling even when on high. I was amazed at how easily the problem was sorted. The engineer removed all the basktes from the freezer to access the screws on the inside backpanel of the freezer. Once this panel was removed it was clear that the so called Frost Free doesn't really mean what it says. The ice need to be melted with a bit of simple care. It is obvious that with a bit of care it is easliy a diy job BUT PLEASE BE CAREFUL AND READ THE NEXT PART BEFORE YOU BEGIN TO REMOVE THE ICE> The ice forms around variouys pipes etc and he usecd a screwdriver to help release the ice quicker than waiting for it to defrost and he also used a simple hairdryer to help speed up the process. He had a ntowel and a basin to take care of the water. Next time I would have no problem doing this myself but I would need to leave it a little while to defrost and NOT USE A SCREWDRIVER as I am sure somehow I would puncture a pipe or the wall of the freezer itself and I am quite used to doing the odd bit of DIY. On a difficulkty scale of 1 to 10 with 10 being difficult I would rate the job as about a 3. Hope this helps anyone who reads this about £70.
Posted on Dec 27, 2008
Cant Get fridge and freezer to cool to correct temp
According to the picture posted the freezer defrost is stuck on. Why it would not get cold enough. Contact a local appliance repairman and get professional help as this should require control board repair/replace.
Jan 02, 2014 | Refrigerators
Fridge side wont cool properly.
Check out this link below for a PDF manual on your item. Great information to have. Just copy and paste into your browser.
http://www.samsung.com/us/function/search/espsearchResult.do?keywords=RS2630SH&input_keyword=RS2630SH
Try this:
Temperature Adjustment
• After 24 hours, adjust the controls as needed. Adjust temperature gradually: push the button in small increments,
allowing the temperature to stabilize.
• Press the button(Freezer Temp or Fridge Temp) repeatedly until the desired set temper.
• For lower temperature, press the button(Freezer Temp or Fridge Temp) towards coldest.
• For higher temperature, press the button(Freezer Temp or Fridge Temp) towards cold.
If this does not work for you let me know or you can contact Samsung support at 1-800-SAMSUNG (1-800-726-7864) Mon - Sun : 9am - 9pm (EST).
Or you can try this Live chat at this link below, just look to the middle left of their page for live chat:
http://www.samsung.com/us/info/contactus.html
Let me know how this works for you or if I can help you with anything else.
JimmyC
Oct 06, 2009 | Samsung RS2630SH Side by Side Refrigerator
Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
May 17, 2009 | Samsung Refrigerators
My fridge freezer made by samsung is on the blink
These fridges have an evaporator fan motor on both sides - the freezer and fridge side. The freezer can maintain it's temperature because that fan is working fine. I had the same problem, and replaced the evaporator fan motor on fridge side, and it solved the problem. Also, if your fan motor is not working well, or stops working, the evaporator is prone to ice build up, and will prevent proper cooling. You may want to open up panel on fridge side and see if that's the case. Taking a blow dryer to the evaporator and surrounding area (while fridge is off), or letting it sit for a few hours might solve the problem. Ultimately though, it appears as if these fan motors are prone to failure, and need to be replaced.
Dec 19, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
My Samsung refrigerator will not cool
Call Samsung. I had the same problem when Best Buy delivered mine. The delivery people left the fridge in demo mode. The people at Samsung will talk you through it, it is very simple. The fridge should work fine then.
Jun 22, 2008 | Samsung RF265AA Bottom Freezer French Door...
Refrigerator will not cool
no there a is nothing you can do, they gonna change a card, and charge for the card and the job,now check for waranties maybe the card is on waranty...good luck
Aug 10, 2006 | Samsung RB2155 Bottom Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
