Question about Acer (91.42R37.001) CD-RW/DVD-ROM (Combo) Burner
A while ago, my laptop's DVD drive stopped reading CDs. A after a few attempts , it displays the CD/DVD as an empty one. The CDs are not empty or too scratched because I tried them on a different computer and they worked perfectly. what can be the problem ? is the CD broken and must be replaced or maybe it's only a divers issue ?
    Guru:
  • 832 Answers
Hello there!
Please note that a CD-ROM drive can read and in some cases write to a CD inserted into it. This is done by means of a fragile laser mechanism that scans the surface of the disc as it spins at high speed inside the drive. Drive failure can occure from a scratched laser eye, mechanical failure, overheating, or simply years of use. You will want to ensure the drive is actually broken before buying a new one as replacement or send it for a repair.
Please follow these easy steps:
1. Open the CD drive tray and insert a CD. If you have a tray that opens by pushing a button, push the button. For slot drives, try to slide the CD in. On slot drives, if the CD will not go in fully, the drive is not getting power.
2. Wait and listen for a "whirring" sound from the drive after the CD is in and the drive tray is pushed in. This may take a few seconds.
3. Look at the status light on the front of the drive if one is present. It should be blinking to indicate that the device is reading the CD.
4. Replace the first CD with another one in case the first CD is damaged or unreadable. Repeat steps 1 through 3 with the second CD.
5. Wait to see if anything comes up on the pc screen indicating the CD is being read or run. A notification may appear asking if you want to play the CD or run the software. This indicates a functioning drive.
6. Click on "Start" followed by "My Computer" and locate the CD-ROM drive usually labeled as "D:/" or "E:/". Double click on it. If the CD drive makes no noise or an error message appears on screen indicating the disc can not be read, the drive may be broken.
If an error message appears indicating that the CD-Rom drivers are missing this may indicate a software issue and not a broken drive.
Regards,
fossildude
Posted on Mar 15, 2011
Laptop Optiarc DVD RW AD 7530 B is not reading CD or DVD media. 1.DVD icon displayed in My Computer. 2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off...
2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off within few seconds.
3.DVD drive in My Computer when clicked shows empty folder
4.Uninstalled DVD drivers in Device Manager and let windows find it on reboot
5.Issue still persists.
6.Right now external DVD RW works perfect.
Please help
Oct 29, 2009 | Sony NEC Optiarc AD-7530B 8x DVD?±RW DL...
DVD Drive cannot see DVDs but CDs can
you dvd player seems to be incompatable with vista
Sep 08, 2009 | Acer (KV.16X04.007) DVD Drive
Dvd ram can not read cd.
I had the same problem, this is what worked for me.... I opened the cd/dvd drive on the side of my laptop and gently cleaned the small laser and hey presto it worked, can now erase,read and play my discs.Give this a try it only takes a few seconds. Good Luck
Apr 20, 2009 | Acer Aspire 4315 Notebook
Dvd
First you can try a different CD/DVD burning problem.
If that doesn't help you might need a need CD/DVD burner as the one you have is all burnt out.
If you need more help just comment.
Aug 14, 2008 | HP Computers & Internet
LG HL-DT-ST DVDRAM T10N ATA DRIVE
Various issues can cause drives to occasionally balk at writing optical discs. These run the gamut of physical, hardware, and software troubles.
Inappropriate or dirty media may be to blame. Make sure to match the type of recordable disc to the drive, and check each disc for fingerprints or other contaminants. If a disc is dirty, wipe it with a clean, soft cloth in a straight line from the center hole outward. Try a quality optical drive cleaning disc if you suspect dust contamination on the drive’s laser lens.
Some discs don’t perform well with certain drives, even within their rated speeds. Try recording at a slower speed and then with a different brand of disc. Also, on PCs, verify that the temporary file storage area on the hard drive used by the burning software has enough free, defragmented space. Allocate at least 5GB for a DVD (9GB for a double-layer [DL] disc) and about 1GB for CD burning.
Feb 28, 2008 | HP Pavilion dv6000z Notebook
HP 530 Laptop - CD/DVD Drive not functioning
you have a faulty drive/connector/motherboard or even cd/dvd laser, if it,s warranted. send it back while it,s covered.
Mike @ compurepair.
Feb 24, 2008 | HP Pavilion dv6000z Notebook
HP dv4000 laptop CD not reading
Hi
Type of media settings might be the issue but making a change for standard CD/DVD recording (it affects reading too) Issue can be resolved. Right click on the CD/DVD drive (Usually D drive ) click on properties and select and choose the recording option. Click the enable CD recording for this drive option
Click on apply and OK. Try again. You may try after reboot the computer. If issue persist please post so we can think about some alternate solutions.
Good Luck
Jan 23, 2008 | HP Pavilion dv4000 Notebook
DVD unit doesn't read CDs but works fine with DVDs
Sir: Did you try another CD or just 1 CD could not read by your DVD RW? Would you please make the DVD poped out and re-set it again. It seems the problem of communication becasue the code rate of DVD and CD is different. Its not related with the lens.
Jul 20, 2007 | Sony VAIO PCG-K35 Notebook
Acer (91.42R37.001) CD-RW/DVD-ROM (Combo) Burner Logo
96 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
