Question about Seagate Computers & Internet
I have two Seagate external drives but I dont' know how to set them up to do what I bought them for. 1. I want that plugged into my hub for my lap top all the time so it backs up automatically at least once per week. 2. My small external (palm size) I want to store photos, family tree data and paper packages from CM on and just get them from there as needed. Not working like this at all.
    Problem Solver:
  • 6 Answers
You have number of options to implement this backup setup. If you are not interested in archived backup that you can't access without Restore option, then easiest solution is to use free Microsoft program SyncToy. SyncToy allows to copy, sync or echo files between folders. Setup is very easy and you need create pairs of folders for example pictures folder(s) on your laptop can be paired with pictures folder(s) on your new external drives. After you setup all needed folder pairs you can run backup manually.
To implement scheduled backup you will need to use another Microsoft Task Scheduler. you can find all the details in this blog
Posted on Mar 15, 2011
I have a Seagate Free Agent Desktop External Hard Drive. I cannot get any of my computers to access the drive. I fear the drive has crashed.
get linux puppy and boot the cd while your hard drive is plugged in, if you can mount under puppy linux and see your info choose the info you need and offload onto an external usb, copy the files over, dont move them as if disk is corrupt you could lose info, then reformatt the drive, just to let you know there seems to be alot of hard drive issues with seagate lately
Feb 14, 2011 | Seagate Computers & Internet
Seagate Portable 250 GB External Hard detected for only 2 secs
u can try some hit and trial...
1 - keep ur USB HD off and switch on the PC then switch on the power on USB HD
2 - try another USB port
3 - try another USB cable connector
4 - check ur Device manager/usb root hub settings/power setting, uncheck the box that says" alow computer to switch off power....in Power Mgt tab
Feb 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My Seagate FreeAgent Pro 500GB drives becomes undetectable
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
Nov 05, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate xtreme hd not recognized by HP Vista notebook
1. ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
4. Use ONLY the power supply that came with it if it has an external power supply (Dont use any other unless you know it has both the same voltage and current rating eg. 12V 500mA anything rated below that would not work properly)
If you checked and fixed anything there you should be good but there may be other issues.
Go to your control panel and then administrative tools, select computer management.
Now select Disk Management and expand the window.
Your drive should be listed here (if not then you need to check your computer hardware has not got any issues before proceeding)
If your drive is listed and says healthy then right click on it an select Properties, click tools and then error checking, Check now, tick the two boxes and then start.
This will attempt to fix any errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed but did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. when it is done restart your computer and you should be good to go.
Aug 21, 2009 | Computers & Internet
Seagate 1 TB not detectable on win 2003, xp detects it
As you know,the Seagate sometimes has the firmware problems,so it seems that this firmware designed only valid in XP or Vista system,you may find the firmware update from the seagate official website
Jun 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
External Harddrive Ignorance...
I've seen this happen with hubs being connected to external hard drives before.
Do you have a free usb port on the back of your computer you can plug it into?
That should fix the problem.
Jun 11, 2008 | Belkin (F5U233-APL) 4-Port USB Hub
Seagate 80GB external drive - drive lost. Lite on front of drive continuously blinking
If you plug it in to a hub try plugging it in to a USB port directly instead, one on the front or rear of the PC.
Mar 31, 2008 | Seagate FreeAgent Go 80 GB USB 2.0 Hard...
Computers & Internet Logo
52 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
