Question about Compaq Presario 700 Series DVD-Rom Drive (254112-001-) Plug-In Module DVD Drive
My Presario F700 won't recognize it's dvd drive. IIt doesn't show in the boot options, so it would appear that the BIOS is not recognizing it. I have tried the drive in another laptop and the BIOS detects it ok so I assume the drive is ok. Any suggestions would be most welcome. Thanks
  • Compaq Master
  • 3,606 Answers
Find a driver here at compaq:
http://h10025.www1.hp.com/ewfrf/wc/prodTopCategory?product=96120&lc=en&dlc=en&cc=us&lang=en&tool=&query=Presario%20700%20
You can use the auto detect function, as there is several models
of your product.To find the right driver.
Its also very important to select the windows version you are running
The driver you need is for the mainboard
or the cd/dvd drive.
It does no harm to upgrade all the drivers there is outdated.
Try to look in the device manager for outdated drivers.
Hope this was helpfull.
Posted on Mar 15, 2011
  • 961 Answers
Try going into "control panel", find "device manager" and right click on it. In the list, find cd-dvd rom drivesand click on box at right side of line item. It should dop downand show your device. right click on it and you shoud see "enabe" or "disable". If it says enable, click on that.
My HP Presario F700 recently started showing a recource conflict on motherboard while starting up. In addition the DVD-drive is not recognized even it does a self test. Any idea?
there might be 2 problems that come first in mind
1: due to long time pc explotation bios battery died
2: bios reseted and all divices become masters
firs test battery voltage ir its good try to change bios boot up log
Jul 29, 2014 | HP Compaq Presario F500 F700 and G6000...
Compaq Presario F761 Won't recognize DVD RW Drive
First try to load the drivers for the system. Go to dell website provide the service tag and try to install the drivers. If this does not work then take the back up of data and do a simple factory restore.Check out my blog Click here
Kindly click skip ad in the top right hand side to view the article
Nov 27, 2011 | Compaq Presario PCCOM2232US Notebook
Hp presario f700/f750us, cd/dvd player, won't boot from start up but is listed first in boot order, not recognized by windows either, won't read, write or play. tray opens and light blinks. tom...
Check the jumper settings in the back of the drive, by the power cable. Make sure your cd/dvd drive is set to SLAVE, with your primary harddrive as MASTER. Check BIOS settings, specifically your boot order, choose which drive you want to load first (usually HD 0), save and exit.
That's just the basics, though.
Another possibility is that you might just have a paperweight ;)
If so, try another drive.
Hope that helps
Cheers from NZ
May 17, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
EXTERNAL HARDRIVE NOT RECOGNIZED IN WINDOWS XP
Uninstall the driver and then reinstall. make sure the drive is not connected until the driver is installed.
May 30, 2010 | Western Digital Elements powered by WD 320...
Motherboard won't recognize SATA DVD drive.
make the dvd your 1st priority in bios for boot, if it cannot be recognized try taking the floppy cable out of the floppy drive, maybe you have a problem with your power supply
Feb 14, 2010 | MSI K8T Neo-FSR Motherboard
Cannot get BIOS to boot from DVD drive. Pioneer DC/DVD drive is on one of the serial ATA connectors. Bios won't even recognize the drive as one of the bootable devices. Did the CMOS jumper to clear the...
you can try this option to  if you sure that your dvd drive is working properly remove the battery on the motherboard and put it back this operation srestart to bios and try again to boot from dvd drive.
Doesn't recognize SATA hard drives. BIOS option
Need to install latest bios update go to there website also if you are trying to boot up with usb installed take it out. BIOS ID:15
  1. Fixed the issue where SATA HDD boot up will fail if USB storage device is installed.
  2. Fixed the issue where SATA HDD boot up will fail if "USB keyboard/mouse" setting as "BIOS" section.
  3. Enhance the compatibility of SATA device on WIN98SE/ME.
  4. BIOS compile date: 06/07/2004
Nov 28, 2009 | Abit KV7-V Motherboard
Hi, when i boot my Compaq Pressario 700ap i get a DOS screen the bottom line being that there is an "0211: Keyboard Error". I then have the option of using the 'F1' key to continue with the boot or 'F10'...
First, I would go into the BIOS by pressing the F10 or F2 key during boot. Then look on the BIOS screen for 'keyboard' and see if it is recognized in the BIOS.If it says "not present" then you need to ttoggle the TAB key or SPACEBAR to set the BIOS to recognize the keyboard.
There are other causes for your problem,but try this first.
Apr 12, 2009 | HP Compaq Presario 700, 700A, 700AP,...
Want to Boot from dvd ROM
when the pc in post usually on dells bios there is a boot menu option it is usually f12
if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
Jan 28, 2009 | Dell OptiPlex GX280 PC Desktop
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Compaq Presario 700 Series DVD-Rom Drive (254112-001-) Plug-In Module DVD Drive Logo
1,074 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
