Question about Car Audio & Video
I have an Autowatch 573 transponder immobiliser system, and neither of the transponder keys work, and they did previously. Is there any way I can bypass the immobiliser system or deactivate it, as I cannot start my car?
    Sniper:
  • 50 Answers
Hello... sorry to hear you are having problems. You did not mention what type of vehicle this is installed on. Under the steering column, generally, is where these connections are made. If you can access this area, there will be a wire that will be cut in half. That will be your starter wire. You will need to reconnect those 2 wires together. Without a vehicle make, model, year, I really can't give you anything more to work with. This will be the only way to bypass the immobilizer. Hope this helped! Good luck with your venture!
20 year car audio/video installer
Bay manager
Posted on Mar 15, 2011
Testimonial: "thankyou so much for your help! Thanks to you I was able to get it to where I bought it to have it repaired properly! THANKS AGAIN! "
  • juandresamp May 31, 2012
    Hey
    "nsanedrummer" I have a golf 1,I don't really know what autowatch system I have,I'm also having the same problem,I am able to get to the main box aswel as the steering column,could you please give me a heads up bro
How to hot wire a nissan frontier 2006
Basically you can't.
The engine management system will not switch on unless it receives the correct electronic code from the immobiliser.
The immobiliser will not send the correct electronic code unless it recognises the transponder code from the key or the remote.
Only decoding the system will effectively disable the system.
Jul 13, 2016 | Nissan Cars & Trucks
Does a 2001 mercury cougar have a chip in the key
Yes, it does........
The Passive Anti-Theft System (PATS) is fully passive in operation and requires no special procedures by the driver to arm or disarm the system. It is invisible to normal scrutiny and is operated by a miniature transponder within the key body. The transponder communicates with the powertrain control module through a transceiver mounted around the ignition switch lock barrel. The PATS functionality is incorporated within the powertrain control module.
PATS may be identified by a larger than normal sized ignition key. A larger sized ignition key indicates the presence of the transponder that controls the system.
The transponder code reading is carried out when the key. having been inserted into the ignition lock barrel is turned from position "0" to position "II" to crank the engine. If the Powertrain Control Module (PCM) receives the correct code the engine will start. If the PCM receives either no code or an incorrect code the engine will not crank and PATS remains armed and the engine immobilised.
Anti-Theft Indicator
Whenever the ignition is switched on the anti-theft indicator will remain on for three seconds while the system reads the ignition key code.
The anti-theft indicator will flash rapidly or glow continuously after the initial three seconds to indicate the PATS has immobilised the vehicle.
Sep 06, 2014 | 2001 Mercury Cougar
How can I disengage the engine immobiliser?
What year is your car? The immobiliser communicates with your keyfob which has a transponder in it. If you recently gotten new keys, you would have had to swap out the old transponder or have your new one reprogrammed.
May 12, 2014 | Mercedes-Benz Vehicle Parts & Accessories
Got a new ignition but it wont start. how do i program the ignition to the car?
You will have to program you keys to the immobiliser in the car. The keys transmit a code to the immobiliser in the car and if you have fitted anew ignition switch you will have new keys with the wrong transponder. You may be able to fix it by replacing the new transponder in the new key with the old transponder out of the old key
May 17, 2013 | 2000 Saturn SL
I know the ducati 999 comes with an emergency red key. What is it use for? and where do I insert it?
Here is some info I downloaded from another site for a friend - it might help you!
The immobilise keys are not all
identical; specifically there is one red
key and two black keys.
Red key:
- the red key contains the secret
code for programming the
immobilise and allowing the engine
to be started;
- this key is also used for
programming, deleting and
reprogramming the BLACK keys;
- the key head (including the
electronic circuit for transmission
of the stored secret code) can be
removed and fitted to a different
key body if motorcycle locks and
ignition switch are changed;
- it is recommended the red key be
used only for programming the
immobilise system. Use the black
keys to start the engine. Keep the
red key in a safe place.
Black keys:
- the black keys are normally used to
start the engine.
electronic circuit transmitting
stored secret code) CANNOT be
removed.
The transponder is fitted inside the
key head and consists of a power
supply circuit, a ROM (Read-Only
Memory) and a transmission circuit.
The transponder is supplied with
power by the magnetic field
generated by the antenna which is
enabled as soon as the instrument
panel is switched on. Since the
transponder is very compact and
needs no external battery power
supply, it is moulded permanently
into the key head.
Jul 01, 2010 | Motorcycles
I have a skoda favorit petrol and the dashboard immobiliser key has worn thin and now the computer will not recognise it i have been informed by a skoda dealer keys are no longer available is it easy to...
Ok, I am pretty sure it is an intergrated transponder system which means removal is not possible.
Where abouts are you? UK, USA etc
The immobiliser you have, is it part of the ignition key or a seperate key type?
Dec 05, 2009 | Vehicle Parts & Accessories
Immobiliser transponder not working
hi the transponder is the chip in the key my car is the same its the red bit on the key.... and there is a reciver around the ignition barrel where the key go's to start the car its a black circle with 3 or 4 wire's runing to it you can't by pass this but i have been told that some are made with an external P.A.T.S system (Immobiliser system ) but same are built in tio the e.c.u if its external it might be poss to bypass im also so sure you can buy a key coder off the net try googleing it i hope this is a help to you ......
Jan 04, 2009 | 1996 Ford Escort 4 Door
FTO Toad immobiliser
If you require a transponder in order to start the vehicle, it could be a few problems, could be the immobilizer transponder fob, or the immobilizer antenna, or even the immobilizer brain or relay. Few steps to tell, if the LED light doesn't go out for the immobilizer its the transponder fob. If the light does go out then it could be the antenna, brain or relay. These are the problem areas that can be diagnosed.
Oct 04, 2008 | Car Audio & Video
Car Audio & Video Logo
541 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
