What is the speaker input for on TEAC sub tsw 100cb, Tried putting speaker in don't work
5 Suggested Answers
  • 4234 Answers
SOURCE: tsw 910 speaker
If you don't have a local speaker "recone" service in your area, check on-line for raw speakers. A web search using the keywords "speaker" and "parts" should turn up a number of suppliers.
Dan
Posted on Mar 17, 2008
  • 417 Answers
SOURCE: I got a teac ag-v8060 audio/video surround
On the back of the receiver, there could be "pre out-subwoofer". If your subwoofer has the same type cable input, that would indicate it is a powered(amplified) sub. Connect those two. If subwoofer only has red/black speaker inputs, it is a passive sub, which means spkr signal runs thru it and then to your main left and right spkrs.. Run your receiver main or front spkr left (red/black) and right (red/black) to those corresponding sub inputs, and then sub spkr outputs to each of your main left/right spkrs..
For surround, on the back of the receiver, there should be spkr outputs (red/black) noted as "rear".
Just make sure red to red, and black to black.
Hope this is helpful.
Posted on Apr 28, 2010
SOURCE: Teac AG-V8520
same problem exactly
Posted on May 31, 2010
dunnbiker
  • 8546 Answers
SOURCE: RIght speaker not working in
Let's name the product and use FM for troubleshooting. Are you saying you have the Right Front and both rear amp channels/speakers not working? What DOES work?
Posted on Jan 17, 2011
I have no sound coming from surround speakers and sub.
Some surround modes switch speakers on or off as required. It's possible that the inputs you are using have settings that remember your previous settings, ie: no sub and surround speakers. Check the inputs and also make certain that whatever is connected to them is putting out Dolby signals.
May 04, 2017 | Pioneer VSX1020K Receiver
Subs are smoking
You have officiqlly burned them out by creating a short insid of them
Feb 26, 2013 | Pioneer Premier TSW-3002D4 12 Inch...
Philips sw3440/37 audio inputs D-sub 15 connector pinout
this is what i have on mine i used a 3.5 mm jack as an INPUT and i also have a set of female RCAs next i will be replaceing the plugs for speakers and putting standard speaker terminals
Jul 20, 2012 | Philips Audio Players & Recorders
Problems with JBL PSW D110
The speaker level input option is designed for receivers that don't have digital output for the sub, used this way when you set to digital the speaker outputs only get the higher range outputs so won't reproduce much bass. To get the sub to work in digital mode you need to use the digital output (single RCA) from the amp to the sub
Mar 06, 2012 | Audio Players & Recorders
Hook up lower level input to the audio source 230 subwoofer but can't get any sound for the speaker that is hook up through the speaker level input or output.
The speaker level connectors on the sub are for use when you DON'T have an AV receiver-style subwoofer output. They only pass-through from YOUR amp to other speakers. You should NOT use both Line level and Speaker Level input to the sub.
What is your electronics? Have you looked at the manuals?
May 02, 2011 | AudioSource System 230 / 235 System
I got a teac ag-v8060 audio/video surround receiver and I'm tryin to hook up some surrounsound speakers along with a jbl g cinema sub can you describe where the wires go in the back of receiver? The sub...
Apr 28, 2010 | Teac AG-V8060 Receiver
I have a teac AG D8900 Digital Home Theater. My subwoofer seems to be dead. No lights come on the front of Sub Woofer even though it's plugged in. I tried changing outlets. The wire from speaker to...
I have the same-just talked to TEAC last week, if fuses(two 5 amp glass ones inside housing-just remove screws on back after un-plugging 120v power) on the LSR-1008 subwoofer are blown, it may be failed relays. I replaced my fuses, both blew w/in 5 seconds. Called TEAC today, relays are NOT available alone and are solder connected; however, complete new circuit board is plug in, part #APE000515-0001 at $47.69 plus shipping. Verify #s and price with TEAC, but now I must decide if it's important to keep this sub, or if another at around 60$ on Ebay is a better bet. Good luck!
Dec 26, 2008 | Teac AG-D8900 Receiver
Teac AG-V8520
Oct 13, 2008 | Teac AG-V8060 Receiver
Hi, I bought a teac dvd and 5 speaker surround sound system yesterday. I am having trouble setting it up. I want to run the TV sound through it as well, but at the moment it is only going through the sub...
Whoa,ok.Sounds like things aren't connected properly.The first step is to disconnect the TV and concentrate on getting sound from a dvd or cd.Read the owners manual and double check that the speakers are hooked up correctly and that the unit is in the correct surround mode.Next, connect the TV.Use an RCA cable to go from an "Audio out" jack on the TV to an input jack on the Teac -e.g. "Aux, TV, etc.If your TV doesn't have the proper jack, I'm afraid you're out of luck.
Jul 21, 2008 | Teac Audio Players & Recorders
Tsw 910 speaker
Dan
Mar 17, 2008 | Audio Players & Recorders
125 people viewed this question
 Grubhead
Grubhead
