Vtech CS6219 Cordless Phone Logo
Posted on Mar 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to change the number of rings - Vtech CS6219 Cordless Phone
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Vtech Master 102,366 Answers
  • Posted on Sep 02, 2011
Vtech Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443393
Points
622693
The 6219 is not an answering machine. You've apparently subscribed to an answering service offered by your phone company. Please contact them for instructions and help using the service.
How to change the number of rings to 30 seconds on my alcatel smart flip
Standard Android procedure
On your phone's keypad, dial (or tap):
  • * * 61 * 13065206245 * * number of seconds #
  • The number of seconds must one of these numbers: 5, 10, 15, 20, 25, or 30
  • For example: To set the ring time to 10 seconds, dial: **61*13065206245**10#
https://www.google.com/search?q=change+the+number+of+rings+to+30+seconds+on+my+alcatel+smart+flip
I have 2000 ram 1500 4WD v8 5.9l auto. Need to change refer ring and pinion. Dose the teeth of ring and pinion should be same ront and refer?
NO--- Check Gear Ratio On Tag Or Tube--Front and Rear Are Not The Same. Or Count Teeth On Pinion And Ring Gear--Divide Pinion Number Into Ring Gear Number For Ratio.
1helpful
2answers
I need to change the number of rings before phone goes to voicemail
First, call your voice mail. After the messages you will be given a menu to follow. On the Sony Ericsson W350 I went to Personal Options (4) then to Administrative Options (2) and finally Prompt Level (3). After reaching Prompt Level you have the option to shorten or extend the number of rings. At this point I chose to shorten the prompt and then I exitted the system.
Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
Need to program extension to ring on incoming calls
Professional Level 1 programming to make a phone ring on incoming calls:  1. On the phone you want to change ringing, press <FNC> - 4 and the screen will show the port number and the station number. If it doesnt have a display, borrow one and plug it into the cord that is attached to the wall, then do this. The port number is needed since all station programming is port based.
2. From ext. 10 or 11 (or whatever the extension numbers are for ports 01 and 02 are), with the phone idle press ,<FNC>, <HOLD>, #,0,*. The screen should show "PROGRAM MODE".
3. Press Line Key 4, which is the 4th button across the top. Dial "15", screen should show "01 / 15: 12345678" if you're in the right place. In this mode, the * key moves the cursor right, and the # key moves the cursor left. The first two digits are the port you're programming, the next field is the program code, "15"in our case, which is Daytime Ringing, and the last field is the data setting for this port.
4. Move the cursor to the left so you can change the port field to the port number you found in step 1. After changing the port number, move the cursor back to the right to the data field, and press the digits corresponding the the line number you want to ring, e.g. for line 1 press "1", for line 4 press "4". Each digit pressed in this field is a toggle, so if you press "1" when the digit "1" is already displayed, you will turn off ringing.
5. Verify that the display settings are correct. For example, if you want port 04 to ring in day mode on lines 3, 4 and 5, the display should show "04 / 15:   345    ". If all is correct press <TRF>, and note that the screen advances to the next port automatically.
6. You can change Night Mode ringing by setting the program code field to "16" instead of "15", then the same procedures apply.
7. When all changes are completed, press <SPKR> to exit program mode (or lift handset and hang up).
Need to know how to change the number of rings on the fax.
Press
Funcion
7
monitor key slowly 4 times
set
clear 2 times
use number pad to set number or rings 0-15
set
Unplug power cord, plug back in.
2answers
Change te number of rings
I need to change how many rings it takes my system to answer . It is set for attendant , I need it to answer after 5 rings . I need this changed because I now have a answering service that is set up though my phone provider verizon to call forward after 4 rings Lucent partner 18d
2answers
How can I change the number of rings?
Not sure what you are asking. Are you saying your phone only rings twice before going to voicemail?
13helpful
2answers
Number of rings
press *94, then press the number of rings you want 1-9. The tone will change and thats it.
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
