Question about Radio Communications
Hi we just bought a new cb galaxy people can hear us we cant hear anything no squelch no talking
    Problem Solver:
  • 4 Answers
Plug an external speaker in the back of radio & see if you can hear anything. Also,you may want to take bottom speaker panel off & make sure the 2 wires coming off speaker are plugged in to the back rightside of radio. These things I would check first.
Posted on Mar 17, 2011
People can hear me but I can't pick up anything.
Make sure the squelch is down the the RF gain is up. Also try another mic. If the RX wire in the mic is broke or shorted, the radio will not go into receive mode.
Jul 14, 2011 | Galaxy Radios DX-33HML 40-Channels Base CB...
I have a galaxy 33hml and i can not figure out how to set it up with the nobs i mean can you help me....
first of all is it set up to a antenna source? if so then turn the squelch nob counter clockwise all the way, then turn the device on. next start at channel one and slowly turn the squelch clockwise until the pin moves or you hear static. then surf the channels adjusting the squelch to to that static point until you find your active station. from there to cancel static between transmissions turn the squelch so that it is just below the static marker.
Feb 10, 2011 | Galaxy Radios DX-33HML 40-Channels Base CB...
My Squelch on my Cobra C.B isnt working anymore, Does that mean anything or do i need a new C.B?
It means either the knob or something in the squelch circuit has gone bad. Doesn't mean that you cannot use the radio, you will just hear static all the time when no one is talking. If the static bothers you, you can always back the RF gain down a bit. That will quiet the noise, but lower you receive range. meaning you won't hear as far away.
Nov 14, 2010 | Cobra 19 DX IV CB Radio
This is something new to me, what do I set all the buttons and knobs to talk on channel 19,hi-lo band,10khz on or off ,pa-fm-am,e/a-f/b-g/c-h/d, e-tone thanks for any help anyone can give me.
Radio On Volume comfortable Listening level Squelch Open (Hearing Noise) Mic Gain Up unless told by receiving station to reduce it. 10 Khz Off pa-fm-am set to Am e-Tone to off I believe this model has CB on Band C which is switch down on Low and C position you will know when you hear truckers on 19 which band is CB
Aug 06, 2010 | Galaxy Radios DX-44V 40-Channels Base CB...
Radio comes on but cant hear others talking
Is the antenna plugged in?
Is the antenna propperly checked with an SWR meter?
Have you tried turning the squelch back? (squelch on)
Have you check the microphone connections? (is the microphone dodgy?)
Jun 19, 2010 | Cobra 29 LTD CB Radio
Cb radio doesn't give out any sound
You would be surprised how little people actually talk on CB radios these days. I went through similar struggles a few years ago. Unless you are in a major trucker area, the CB radio is basically silence.
Check out the weather channels (anything on the WX setting) to make sure that your radio is receiving frequencies correctly. If that doesn't work, then it is your box, but I bet that will work.
Oct 30, 2009 | Radio Communications
Hi any one know any cb repairs near norwich thanks
Dunno about any shops near where you live. There are a few good places online you can send the radio too.
Does this radio have an RF GAIN? if it does this should be all the way up. Also, bring down the squelch.
The RF GAIN on a cb radio is how sensitive your receive is. the more up it is, the further you can hear.
the squelch is used to cut off noise. The higher the squelch is, the strong a signal needs to be to hear it, so you will only hear people close.
Oct 08, 2009 | Radio Communications
Rushing sound (noise) galaxy 88 HL
RUSHING SOUND ?
1. Get the noise then disconnect the coax and see if noise goes away on receive, if noise goes away then address the ground on your antenna,
if noise still there then address the ground wire from power source
Mar 30, 2009 | Galaxy Radios DX- 88HL Base CB Radio
No rx
so the swr is fine antenna has not been hit by lightning i assume as the swr would be all wacke out check to see if the rf gain is turned all the way down maybe if you have little ones they play with everything as i know all so well. or mabe the squelch was turned allt the way up if either turn squelch down all the way and turn the rf gain all the way up if not the audio chip on the rt side of the board could be shoted out if the radio has pa put switch to pa with external speaker attached key mic and talk if you here yourself talking the chip is good. by the way has the radio been tweaked any time recently it may be also alignment problem??
Mar 09, 2009 | Galaxy Radios DX-2547 40-Channels Base CB...
Midland model 1000
turn squelch all the way off , if you still get nothing you have a bad mic
Nov 21, 2008 | Midland Radio Communications
Radio Communications Logo
62 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
