Question about PNY 4GB USB 2.0 Flash Drive - Grey/Black
Write protected cannot write to and cannot format
  • 3 more comments
  • hvarhvar Mar 15, 2011
    There is not a sliding button on my flash drive
  • hvarhvar Mar 16, 2011
    Followed your advice.... the only tabs (which I have explored) are
    General
    Tools
    Hardware
    Sharing
    and Customise.
    I cannot locate anything relating to `read only`
    regards
    There is nothing to click on. Screen simply indicates used space, free space and capacity
    Have tried a different computer to no avail. If I attempt to format I receive a messge `The disk is write protected`
    cannot write to usb stick. I receive message "cannot find specified file" Make sure you specify correct path and file name. The usb device is shown in my computer removable storage
    Sergeant:
    Champion:
  • 210 Answers
Unlock it... u will have a sliding button kind of stuff on the flash drive itself
Posted on Mar 15, 2011
  • 6 more comments
    There is not a sliding button on my flash drive.
  • Agnel Johnson
    Agnel Johnson Mar 16, 2011
    ok,,,, right click on the drive on my computer.... select properties and uncheck the options read only....
  • Agnel Johnson
    under the general tab... wat all options do u see? do u see any checkbox with the option "read only" ?
  • Agnel Johnson
    hmmm.... ok... have u tried to use this flash drive on a different computer? check whether u are able to... if u are able to access it, then format the drive by right clicking on the drive in my computer and clicking on format...
  • Agnel Johnson
    the following should resolve ur issue... make sure that u
    1.Click on Start -->Run type in "regedit" without quotes and hit Ok
    2.Navigate to the following registry key:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
    3.Right click on control and create new key.
    4.Name it as StorageDevicePolicies . (Copy and paste it from here if possible)
    5.Now click on StorageDevicePolicies and in right side pan right click and select create new dword and name it as WriteProtect.
    6.Double click on it and set its value to 0.
    Now restart your machine and try copying some files to your card.
    do make sure that u export the registry on to ur desktop before u do any changes... u can do it by clicking on file-- export
  • Agnel Johnson
    ok are u getting that error message when u double click on the drive in my computer??
    if so, try opening like this
    click on start -->run then type in the driveletter:\ (eg. h:\) and hit enter... see if thats opening...
  • Agnel Johnson
    also try in a different usb port
  • Agnel Johnson
    if those dont work try this also
    Go to Start -->Run and enter "regedit."
    Go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion
    With CurrentVersion Highlighted, go to the Edit menu and select New--> Key
    Name the key RunOnce, leaving everything else about the key alone.
How can i format write protected micro sd card 32gb....
Slide the write protect tab forward to remove the write protection. You cannot format it while it is write protected. Formatting will erase all data on the card. Install the card into a Windows or MAC and wait for the device to detect and mount the card. Use the appropriate procedure for the machine to format the card. See this procedure for additional step-by-step operations after the write protect tab has been moved.
How to Format an SD Card
Oct 22, 2015 | Electronics - Others
How to format the write protect pendrive in
HP USB Disk Storage Format Utility
Http://downloads.pcworld.com/pub/new...ls/SP27608.exe
it might be helpful to you.
Note: Some "pen drives" have a write protection small switch on the side of them. Please confirm if this switch (if present) is not in the write protected position.
May 15, 2010 | Computers & Internet
Usb not formating due to write protect
Some usb pen drives,  if thats what you mean? They have a little button on the side of them to protect the contents of the usb pen drive. Check that, tyhen go to "My Computer" look for pen drive, Right click and format.
 Best of luck.....
Jul 24, 2009 | Electronics - Others
Write Protected Problem
Hi Sir myself piyush gajera sir i was used my pen drive from winxp to another os version. afterwards it gives me an error that disk is write protected. i tried to remove or format but again it gives me prob that it is write protected and not able to format. i used different solutions but unable to format or remove write protected. please help me. how can i remove this write protection. sir my email id is piyush_gajera147@yahoo.com kindly mail me as soon as possible. my Pen Drive is transced d33193. and it has no any stick to remove write protected. Thanks in advance. i have the same error while deleting or formating my pen drive My transcend 4GB pen drive when deliting data it ask to remove the write protection while formating the disk it shows write protected. when copying data it ask to remove the write protect
Jul 09, 2009 | PNY 2GB microSD Memory Card
Unable to format the cruser pendrive
Far too often these little things have an almost invisible read/write protect button on them. Look carefully, over the entire surface of the USB Flash Drive. You might have this switch turned to Write Protect, which means there is nothing you can do, until you turn it the other way, and allow the device to be written to.
Cheers!
-a.
May 22, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Remove Write Protection
Try this,
1.
Check out if the USB drive has a small swich for write protection. If its there try toggling the switch.
2.
Windows can all write protect flash drives. Check out this registry path,
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
You may find a key here on the right side by the name 'WriteProtect'. If it's not there this would not be the cause of problem. If it's there, make sure that the value is 0.
Please let me know if this does'nt work.
Nov 06, 2008 | Transcend (589307) Media
Removing write protection of USB pen drive
if u format ur pen drive. then use this step
Check out the registry under:
1)click on start button
2)clik on run dialog box
3)type regedit
4) HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
The value 'WriteProtect' should be absent or set to '0' and when you try to format it you have to format it as FAT16
Good Luck!!
Palwinder
Oct 31, 2008 | iLO (2 GB) MP3 Player
Remove Jet Flash Write Protection Insert the mini CD that came with the USB Flash disk. Start JF Utility.exe in the JF Utility directory. If it complains that the disk is write protected, choose "Continue" Choose "Partition" Answer "Yes" to losing all your data (Since this becomes a problem usually after formating the disk in WinXP or Win9x, you will most probably not have any data on there in any case) Choose "Public Area Only (Single Partition)", Then "OK", Then "OK" again. Unplug the device, reinsert device, and voila!- no more dark secret areas or write protection on your disk!
Oct 06, 2008 | Transcend T.sonic 610 MP3 Player
HOW TO FORMAT A WRITE PROTECT USB DRIVE
the drive isnt write protected the usbport or the connection is loose so that the computer is showing the drive as read only drive also you can format it using command and also setting off the read only attribute that may have been put by a virus also softwares like usbcillin makes pen drive writeprotected take care
Aug 26, 2008 | Transcend (TS40GSJ25) 40 GB Hard Drive
PNY 4GB USB 2.0 Flash Drive - Grey/Black Logo
146 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
