Tv khind locking,no functioncn remote and tv - Televison & Video
Megapower. how do I remove the child lock without a remote?
How to reset "Child lock" on TV without remote ' Electronics Forum ...
www.electro-tech-online.com > ... > Repairing Electronics
Apr 8, 2010 - 21 posts - ‎11 authors
I opened the TV, but no "switch" on the PCB to do a "reset to factory". ... You almost certainly need the remote, and also the service manual that .... and I was able to get into the menu by remote and to disable the Child lock.
How to disable child lock on Magnavox 27MS343S without remote - TV ...
www.tv-forums.com/.../How_to_disable_child_lock_on_Magnavox_27...
Sep 23, 2012 - 7 posts - ‎3 authors
Hello, I have accidentally turned on the child lock (not parental lock) on my Magnavox 27MS343S for which I do not have a remote. Since the ... panasonic television child lock
Apr 21, 2012
Apr 8, 2010
More results from www.tv-forums.com
Jan 01, 2016 | Televison & Video
Child locked on my tv
Possibly, you will need an original remote to disable or turn off this feature. And some child lock can be accessible through neither MENU of your tv or remote. Check CHILD LOCK option to remove it. If it is a screen lock type of CHILD LOCK feature of tv (a Blue Background display a LOCK icon) and your original remote is lost, try a universal remote for you to possibly unlock it. Thanks for using Fixya.
Apr 21, 2014 | Televison & Video
CHUNGHOP RM-88E Universal TV Remote i want fine code for my TV HITEC & my DVD KHiND KDU 801 pls help me
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Gopakumar Gopalan Google
Feb 16, 2014 | Televison & Video
If my TV acts like it is locked but is not then what is wrong with it?
When an Insignia TV is locked, it keeps you from watching all of your channels by only displaying a black screen. Insignia TVs are locked from a single button command on the remote control, so it is easy for you to lock the TV by accident. Since Insignia TVs can be locked so easily, it's important to know how to undo this command and unlock the TV yourself. So, unlock your Insignia TV with the push of a button and once again enjoy watching your favorite programs.
• Find the lock button on the Insignia remote control. The lock button is located on the third column from the left on the second row from the top of the remote.
•Stand within operating range of the Insignia TV, then aim the remote at the TV's receiver and press the "Lock" button on the remote control.
• Aim the remote at the TV and press the channel buttons to make sure the TV is unlocked. When the TV is locked, it shows a black screen and does not allow you to view anything else. If the screen remains black, press the "Lock" button again. If this doesn't work, change the batteries in the remote and start over at step .
Jan 08, 2013 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
CHUNGHOP RM-309ES TV. UNIVERSAL REMOTE CONTROL
Hello I nedd a code for my tv, The brand is Matrix.. My Remote Control is CHUNGHOP RM-309ES
Aug 07, 2012 | Universal Remote Control Remote Control
Goodmans 42" LD4 255 HD.\r\nlost remote and using
Yes,ur tv does require a tv orginal remote will help u to used,but the child lock mode must have a secret codes to enter it.Can't turn tv on,must have the tv original remote to enter child lock secret codes though.Tries Goodmans website look for there 1-800.. call ask their customer service they can help to erase the child lock secrect password,if u don't know it.Try website Remotes.com to buy the tv original remote.
Jul 18, 2011 | Televison & Video
Locked TV have no remote, tv won't turn on
You're going to need the remote to fix this one. If you have any other GE or RCA tv's you can try it. Most of the remotes that are produced within a few years of your television will probably work. When you get one the instructions are: Front Panel Lock This feature allows you to lock the buttons on the front of the TV. Even when the front panel lock feature is on, the TV operates with the remote control. To lock the buttons on the front of the TV: 1. Make sure the TV is on. 2. Press and hold the POWER button on the remote for approximately 5 seconds. To turn off the front panel lock: 1. Make sure the TV is off. 2. Press and hold the POWER button on the remote for approximately 5 seconds
Jun 09, 2010 | RCA TruFlat 27F520T 27" TV
FPA lock on; have no remote control
FPA Lock On and have no remote for the TV on a RCA TV
May 20, 2009 | RCA 24V511T 24" TV
I have the child lock on and the remote control is broken. How can I turn the tv on without the remote control
The power button on the TV doesn't work because of the child lock?
I went over the copy of your manual for your TV. It must be the child lock timer problem.
I would try leaving the TV unplugged for 30 mins and see if that reset the TV and releases the lock.
If it doesn't work, the remote needs to be replaced. A universal remotes aren't really universal when you need to use special buttons. The remote made for the TV is the best.
If your TV is the model 47PFL7403D, here's the cheapest place to buy a replacement.
http://www.philips.newremotecontrol.com/catalog_item.php?catnum=313922852812
May 12, 2009 | Philips 47PFL7403D 47 in. LCD TV
Magnavox child lock tv
my remote control doesn't work, and i can turn the tv on because i lock to just use with the remote control. How can turn the tv on if i do not have a remote control?
Jan 20, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
