Question about Canon PowerShot SD1300 IS IXUS 105 Digital Camera
Hi there i dropped my camera on saturday and it turns on, but when i'm looking through pictures it says "a camera error was detected, will shut down automatically.. restart camera E32" how do i restart my camera? its a canon powershot SD1300 IS Thanks, samantha
    Brigadier General:
  • 3,006 Answers
Your camera almost certainly has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Canon service department in your country to find out about a free repair (but as your camera has been dropped this will not apply). If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera, or at least are able to use the information to help decide whether to buy another camera. If you do decide that you have to throw your camera away then don't forget to remove the memory card as it can be used in other devices. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome.
Posted on Mar 15, 2011
Im buying broken powershot sd 1300 if interested please contact me at enricbuso@gmail.com
Posted on May 02, 2011
CameraWindow won't open or will suddenly close before loading
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jun 03, 2012 | Canon PowerShot S90 Digital Camera
I own a nikon coolpix s3000 model. When I plug the camera to my computer's USB port and try to copy the pictures, I get the error message "The computer cannot detect the scanner or camera."....
Hi, the error indicates that the USB Cable is loose in connection, please connect it firmly and try copying the Pictures. Also try installing the Software provided by Nikon which may have particular Driver for the Digital Camera. You can also Copy the pictures from your Digital Camera by removing the Memory Card and connecting to the Computer with the help of Memory Card Reader.
Apr 15, 2011 | Cameras
Hi, I have two new Canon ixus 105 cameras which were given free as part of a Michelin Promotion. Both have problems downloading onto my computer. Camera 1: Computer does not recognise that the camera...
Try NOT connecting your cameras to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Mar 16, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Ouch!--I dropped my Nikon CoolpixS10 and the mesaage is "Lens error." What do you recommend I do. Catherine
Unfortunately Catherine if you are getting a lens error after a fall it means that the lens may have been knocked out of alignment on the guides that keep the housing on track so it moves back and forth smoothly, or the motor gears may be damaged or there is a motor issue. I recommend a camera shop take a quick look at it before you commit to having it repaired, that way you can decide the best course of action.
Feb 22, 2011 | Nikon COOLPIX S10 Digital Camera
When I turn the camera on , it says "lens error"
If brand new, take it back immediately to the store for exchange. It's defective.
Dec 30, 2010 | Nikon S8100 Digital Camera
My SD850is was dropped,there is a slight split on the bottom (looks like 2 screws are missing). When you turn the camera on, it says "lens error - restart camera" and then shuts off. It does...
from searching the internet, it sounds like the lens needs to be replaced and the cost of the repair would be about as much as buying a new camera.  thanks for responding.  now i have to go thru "what to buy" again.......
Sep 27, 2008 | Canon Cameras
Dropped my camera on a hard surface and the lens is stuck open.
Buy a new one, that's what I did after I dropped my brand new camera.
Dec 16, 2006 | Nikon COOLPIX L3 Digital Camera
Canon PowerShot SD1300 IS  IXUS 105 Digital Camera Logo
1,321 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
