Question about Refrigerators
The compressor is working continous - Refrigerators
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 15, 2011
Refilled 97 jetta ac to capacity it cycles compressor on off remove some runs continous never gets cold
check high pressure with a proper machine and see how many bar you have ,think compressor may be on the way out .
Nov 10, 2017 | 1997 Volkswagen Jetta
THE COMPRESSOR IS RUNNING CONTINOUSLY WITH OUT CUTTING, NOT COLD INSIDE
possibility of such damages caused by the leakage of freon, so the results are no cold, and devices such as Thermostat for temperature control does not work because there is no cold. there is no automatic breaker which functions to stop the operation of the compressor. or Timer is also damaged. timer function is to stop the compressor periodically.
You can see in wiring diagram of Refrigerator : 614ced4.gif
Aug 23, 2010 | Refrigerators
The air compressor continously bleeds out air from the area near the on/off switch. Any ideas of what is wrong with it or where to look for the problem?
If the side of the on off switch has a copper tube going to it it could be that the unloader valve is leaking continuously. Spray some wd 40 on it. Or the unloader may need to be adjusted. There should be two small jam nuts holding the unloader to the pressure switch. Loosen these nuts and shift the unloader away from the lever. Re tighten the jam nuts.
May 20, 2010 | Air Tools & Compressors
I want to program the fan to run continously
I don't see this as a 'programable' feature.
The unit is designed for the fan to run anytime the compressor runs and if you just want the fan to run all the time (without the compressor) just switch it to the 'fan/fan only' position.
May 12, 2010 | Amana PTC093B35AE Air Conditioner
So-low freezer try to start, but stops after a second
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Oct 23, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Will not hold pressure. continous high pressure
is it possible to just tighten or add teflon to that fitting, just a suggestion, if tube nit cracked.
Aug 10, 2009 | Plumbing
Compressor noise
I the compressor is bad it will draw high amps. If the amps are ok then i would look at the valve.
Jan 18, 2009 | Goodman CLQ36AR49 Air Conditioner
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
