Question about Microsoft Windows XP Home Edition
I switched my IDE hard drive into another computer that is a little more up to date. computer boots, passes post, shows these options " safe mode, safe mode with networking and command prompt. start windows normally, last known good configuration." i have tried all of the options and when ever i choose one, it'll go light black but wont do anything.. Also the dvd drive i installed wont read my windows disk and isn't recognized in bios. I connected the ide cable and the power cable. HELP?
    Problem Solver:
  • 6 Answers
you have a problem with load sequence of your hard drives. Original hard drive of your new computer should be the first hard drive to boot, but i suspect that newly installed hard drive takes precedence and that also impacts your dvd drive.
To correct this problem you need to enter computer BIOS. For this you need to press F1 or Del (typically but not always) soon after you power on your computer. BIOS setup instructions. First option in BIOS menu will talk about Standard Setup. One of the options under the menu will be boot sequence, but it can be slightly different based on your motherboard model. You need to set your DVD drive as first device, hard drive that was on this PC before you added older drive as 2nd and your IDE hard drive as 3rd.
If above didn't work... Older IDE drives have a small switch on them and if you can't select drive in correct order in BIOS you may have to remove hard drive you added and change position of that switch. There are 3 options: Master, Slave and Cable select. You may want to use Cable Select that is also can be done by removing the switch. After you change position of the switch, reinstall disk and try BIOS settings again.
Posted on Mar 15, 2011
  • 1,179 Answers
As the Windows installation is installed on the first computer hardware configuration and now it is moved to another computer hardware configuration, ie another computer. It will not work as Microsoft prohibits moving/changing hardware configurations to the extent of another computer system.
In your case you will have to return the hard drive to your original computer and then backup your files. Then this hard drive needs to be formatted, all data will be lost. Then the hard drive can be install in the better computer and a fresh installation may be performed. However you will need to read the terms and conditions of your Windows License Agreement to see if this is indeed possible.
With regards to the DVD drive, it needs to be connected on the IDE2 port, right at the end of the IDE bus/ribbon. There are 3 positions a longer length and 2 shorter lengths.
Long side plugs into the mainboard, the middle one is left open and the shorter end one is plugged into your DVD Drive.
Ensure that the jumper located between the power and IDE port of the DVD drive is set to the Master Position. The details can be found on the label on top of the DVD drive.
Thumbs up!
Thanking you
damnor01
I start my computer up put my pass word in and then the sreen goes blank with just the mouse arrow showing could you help
unplug everything... even the USB stuff what about 1min. then just put the power cord only back in and log back in.
Feb 07, 2015 | Dell Computers & Internet
My laptop will not boot
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On until you get the Safe Mode Option.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click 'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
Jan 20, 2012 | Samsung RV510-A02 T3500 2.10G 320GBDVDRW...
Window Xp not booting up
A 'System Restore' window will appear.Here you will have to check "Restore computer to an earlier time' and click Next
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.Now, Click on Next and System Restore will start and windows will take a reboot.
Dec 01, 2011 | Microsoft Windows XP Professional
I have put in a different hard drive but windows wont start. it flashes up then goes back to start up
you will need to load an operating system on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you should go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
if you already have an operating system on it
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
if you need more help with this or if I have misunderstood the problem post a reply
hope this helps you
Oct 17, 2011 | Acer Computers & Internet
How to solve disk error while booting xp, restarts automatically
Note : If you are not able to log in to Safe Mode and the PC still restarts from entry mode of Safe Mode this means the Operating System Files are corrupted and the system should be reformatted with fresh Operating System.
Good Luck
Sep 05, 2011 | Computers & Internet
When i open the laptop which is lg with model number lgc50,a message appear,and it says press f11 to begin lg recovery,and suddenly another message appear that says.....disk read error
Please check if you have any disk in your CD/DVD drive, if not then the issue is likely with the hard disk drive (which has all your data). We have to check if the hard drive has gone bad completely. Please take your computer / hard drive to a local technician and ask them to backup your data if possible. Then you have to replace your hard drive.
Aug 01, 2011 | Computers & Internet
I have a WD2500AAJS-00B4A0 hard drive that will not boot. it goes to black screen with white letters saying windows did not properly open in my last session. it gives the options for opening in safe mode...
Start your system in Safe mode.
and try to restore your system for previous date.
If your are not compatible with how to restore, Go to the link and follow the steps.
http://support.microsoft.com/kb/306084
Hope it will help you.
Thanks for using FixYa.
May 17, 2011 | Western Digital WD2500JS 250GB SATA2...
When i installed hard drive and set the jumper on primary master it dint show up and in bios the txt is showing like that primary master drive 0 (not installed)
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test or replace all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard)) drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is
Feb 06, 2011 | Seagate Barracuda 7200.7 40 GB Hard Drive
At boot up my Hitachi Hard drive clicks once. Not shown in BIOS
I am assuming that this is the hard drive in the computer. Try a safe boot up to see if you can get to the hard drive. use the F8 key at startup for safe mode.
Mar 24, 2010 | Hitachi 80GB IDE Hitechi DeskStar 7K160...
Pc not starting up
Can you at least boot up pass the BIOS POST?
If you can try tapping F8 repeatedly, sometimes it will give you choices of boot devices, so just choose your primary hard drive press enter and tap F8 again until you see the Advance Boot Menu, choose safe mode and see if you can successfully boot into it.
Once in safe mode click on Start>Run then type in restore. Anew window will pop up. double click on on rstrui icon.
This will now launch the System Restore window click on the radio button "Restore my Computer to an earlier time" and press enter. A calendar will show you the available dates that you can restore from. Choose the day you know that your computer was stable.
If your computer still wont boot up do the same procedure and choose another date.
"NEVER GO BACK TO MORE THAN 30 DAYS UNLESS YOU ARE OUT OF OPTIONS"
Hope this solves your problems don't worry this is just the 1st solution there are many more.
Jan 21, 2009 | Acer Aspire E500 PC Desktop
Microsoft Windows XP Home Edition Logo
44 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
