Question about Samsung SCO-2080R 1/3? Super HAD IT CCD, 164ft IR Bullet Camera, 600 TV lines, 2.8 ~ 10mm auto iris, 32 IR LEDs, HLC, DIS, SSNR III (2D+3D), Weather resistant IP66, 24 VAC/12 VDC, Multi-language OSD
How to connect samsung camera model no. sco 2080 r to the internet via dvr
SOURCE: CCTV NETWORKING INTERNET
Best results are to use a Netopia WiFi Business Router for a DVR installation. A Siemans modems will drop the CCTV connection at random and you will have to restart the DVR manually...which defeats the purpose of having constant video being remotely accessed. We are switching to Netopia to solve our problem with AT&T and Siemans.
Posted on Nov 21, 2008
cesar_quant
  • 61 Answers
SOURCE: cant access lorex DVR from the internet
u need a public ip with an open port, and portforward the port with the ip of ur dvr
Posted on Mar 15, 2009
  • 18 Answers
SOURCE: Connect to the internet on pc via cell phone
Easy, From the start menu - select programs - then select internet sharing. You have to connect to the internet from your phone and not from your computer.And make sure it's on active sync. I tried forever to connect using my laptop ... felt real stupid when i realized one has to connect from the phone. And check if your Mobile Device Centre settings are ticked of correctly.
Posted on Aug 06, 2009
walesarumi
  • 6993 Answers
SOURCE: Need to determine wiring connections
you can use a RCA wire connection from your camera to your Samsung SSC DVR. The RCA wire is the Yellow, red and white wire. Its also known as AV cables. The yellow stands for video while the white and red stands for audio. You can visit the below link in other to know what the wire looks like:
http://www.dnr-cables.com/rca_cables.html
Follow the instructions below:
  1. Plug the AV cables into the Output jacks on the camera, using the yellow plug for the video jack and the white or black plug for the audio.
  2. Connect the plugs on the other end to the Input jacks on the back of the DVR, using the same color codes to match the plugs to the jacks.
  3. Insert the AC adapter power plug into the back of the security camera and connect the other end to a power outlet.
  4. Set up the DVR for timed or continuous recording by pressing the "Menu" button on the control panel and using the up and down arrow keys to reach the recording options. The precise procedure differs with different DVR models, although the options are typically instant recording, timed recording and continuous recording, in which new video is recorded over older content as the DVR's internal memory fills up.
Good luck.
Posted on Jun 16, 2010
muntejaya
  • 10421 Answers
SOURCE: i am not able to
Get it here please www.software112.com/products/samsung-pc-studio.html
Posted on Feb 06, 2011
Dvr password reset
see hte following link below. you need to set the DVR back to default in order to reset the password.
http://www.safe-n-secureinc.com/Support/Samsung/Samsung%20SHR-2160-2162-2080-2082-ENG.pdf
Nov 06, 2013 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
I have a sentient cctv dvr from Maplin I can view it on my phone at home which is fine I wanted to know if I can view camera footage when I'm not at home etc. at work
Yes you can definitely view your CCTV footage on your mobile phone at your work via internet. Sentient CCTV DVR basically is a night vision camera. You must know the IP of the camera and IP Video server. Connecting your phone to CCTV camera via the protocol you can view the CCTV footage's in your phone. Night vision cameras are used for surveillance purpose. I would prefer cctv camera with ir illuminator for good image quality in the night time that will clear footage quality in my phone.
Recently many new applications have also being launched by security cameras with a view to solve problem you mentioned.
Jul 05, 2013 | Home Security
I cannot access my internet viewer
More details are required.
The Samsung 'SmartViewer' program starts up on a computer. You can access it whether you have a recorder or not.
The Samsung 4 channel DVR has a menu to set IP address & ports to use and a netjack to connect to internet. You can access the DVR from any computer connected to the same router as the DVR by inserting the same correct info into 'SmartViewer' as in the the DVR.
Once you open the required ports in your router, port forward the router to the DVR, any incoming requests from the internet to view should connect and with the correct password you can view your security cams.
With minor adjustments..that's it.
What didn't you do?
Dec 25, 2012 | Samsung 4 Channel Dvr
Samsung SHR-1041K. Cannot connect to DVR system "Unknown Error"
Samsung 1041k DVR - Camera Web Server Solutions. ' UNKNOWN ERROR' OR 'CANNOT CONNECT TO SERVER'
Holy Smokes! Can't anyone write a simple solution? The manual totally sucks. It tells you everything except the details that will complete the puzzle. The answers here, so far, are written by gearheads who can't write an easy sentence.
1. The user name is case-sensitive. So if you program the DVR with a user name it will only take capital letters by default ... so when entering the user name (USER ID) in the web setup ... It MUST BE CAPITAL LETTERS otherwise you will get an 'unknown error'. There is no mention of this important little fact anywhere....
2. Use Internet Explorer ONLY (becase of old Active X controls), not FireFox, Chrome, or Safari...etc...etc. IE9 doesn't like it either .. just goes white for the most part or flickers ..so IE8 seems to work best.
3: When programming the DVR Box using the MENU button and the 'NETWORK OPTION ...Use Port 6100 in the NET CLIENT PORT. In the WEB SERVER PORT use port 80. The difference is ... port 6100 is used for the basic connection of the network to the DVR device and camera hardware and software ..... and port 80 is for viewing through Internet Explorer. (Port forwarding in the router must direct those ports right back to the IP address of the DVR (whatever you set it to). TCP and UDP together work just fine... not necessarily one or the other . I tried it both ways .. they all work.
4. If you are lucky enough to finally get Internet Explorer to hit the DVR software via the correct IP address and port of the DVR.... then it will prompt you to install the Active X control software embedded in the DVR. You might hae to refresh the screen a couple of times for it to download and install. If indeed it does then you will get a blank box that will wait for you figure out you need to click on a little wrench to configure the DVR connection. Add the DVR (give it a name). Enter the IP address it was configured with .... and set the port to 6100. Remember to capitalize the User Id and put in the password and save .. Completely IGNORE the confusing little matrix boxes that are used for setting up multiple DVRs and cameras. Save the setup, it wil take you back to the blank Samsung box interface and wait till you figure out to hit the connect button in the center. If you did it all correctly then you should connect to the camera views..
4. If you are going to view the cameras from the home network .... then enter the IP address assigned to the DVR PRECEEDED by http:// . Believe it or not it seems to make a difference. If you are viewing from ..say .. your work.. put in the numerical address of your home IP address and if you have the port forwarding set up correctly you will be forwarded directly to the DVR camera software where you can sign in and see the screens.
I have set up many, many IP cameras and various DVRs and software packages professionally.. I must say that this DVR and software is not very intuitive and was very difficult to get past some of the issues. The included instructions were of little help. I hope this helps somebody else.
Gary
Jun 28, 2010 | Samsung 4 Channel Dvr
Need to determine wiring connections from camera to dvr for Samsung SSC DVR
Hi
Thanks for using FixYa. Please see the link to hook up DVR with camera---
Hookup Camera with DVR
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 16, 2010 | Samsung SSC DVR Digital Video Recorder...
Can't view my cameras
The DVR will be programmed with an IP Address via the DVR main menu function (network settings) and a valid password. The network viewing software (web viewer) you will need to ensure that the IP address is entered correctly for your DVR along with your valid user password.
Trust the above info is of assistance if you require a manual in order to check your settings try this link http://tv.manualsonline.com/manuals/mfg/samsung/samsung_dvr_product_list.html
May 23, 2010 | Samsung 4 Channel Dvr
Cant access lorex DVR from the internet
Mar 15, 2009 | Home Security
I have a samsung home security shr-1040 and i tried to change my password and i must have put a different 4 digit code than i meant, i am now locked out and cannot access my settings.....please help
The manual says:
You cannot enter MENU by forgotten password.
- If you forget the password, you shall reset SHR-2160/2162/2080/2082 DVR to
the values set at the factory. Keep pressing both the "MODE" button and the
"PTZ" button on the left for 5 seconds, Keep pressing both the "MODE" button
and the "PTZ" button on the left for 5 seconds. The password default is "4321".
You can download the user manual here:
http://samsungsecurity.com/product/p_detail.asp?seq=94&sel_seq=64
Dec 25, 2008 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Menu pasword
The manual says:
Jul 23, 2008 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Samsung SCO-2080R 1/3? Super HAD IT CCD, 164ft IR Bullet Camera, 600 TV lines, 2.8 ~ 10mm auto iris, 32 IR LEDs, HLC, DIS, SSNR III (2D+3D), Weather resistant IP66, 24 VAC/12 VDC, Multi-language OSD Logo
89 people viewed this question
Top Samsung Home Security Experts
Heilcode
Level 1 Expert
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
