Question about Vacuums
Vacuum cleaner filter
I have a hoover windtunnel u6473-900 vacuum. Is it possible to change the filter on the side door panel. If so, how do I go about locating one to buy?
  • 77 Answers
Filter should be replaced regularly. any Vacuum repair facility shoud hav filter or can order one with a model #.
jim
Posted on Aug 02, 2008
Why is my hoover windtunnel vacuum cleaner shutting off?
Hi there! Sounds like the thermal protector is being activated. This is usually caused by a clog or a filter that needs to be cleaned or replaced. Follow the steps below to prevent the unit from shutting off.
1. Remove the hose completely.
2. Use a broom stick to gently loosen and clear hose of clogs.
3. Remove the bottom plate and brush-roll.
4. Use a wooden spoon or something similar to break up and remove any clogs from lower hose.
5. Check the primary filter behind the side grille. If it is dirty you may rinse it under running water and allow 24 hours to air dry outside the vacuum.
6. Remove the bag door. Clean the primary filter located on the vacuum under the bag. Rinse with water and allow 24 hours to air dry outside the vacuum. The primary and secondary filters should be replaced at least once a year.
7. Check that the bag is not full. If it is, replace the bag.
The vacuum will turn back on when it cools off. This can take up to an hour. Hope this was helpful!
Jul 08, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
How do you replace the belt on a hoover runabout sweeper.
This link will take you to a site with instructions and illustrations to help you change your belt.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps
Mar 21, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
How to replace the belt
Click this to go to a site that will show you (complete with illustrations) how to change belt.
I hope this helps.
Mar 15, 2010 | Hoover U5753-900 WindTunnel Bagless...
How to replace belt on Hoover U6626-900 Wind Tunnel bagless.
I hope this helps.
Jan 19, 2010 | Hoover U6630-900 WindTunnel Bagless...
Hoover Vacuum Cleaner Bad Smell
change filters. the filter inside the unit and the one on the side needs to be changed once a yr. (these are not to be washed, only the side filter if foam can be washed ). also flat belt change every 6 months and the v-belt once a yr.
Jul 19, 2009 | Hoover U6616-900 WindTunnel Bagless...
Windtunnel hoover is not suctioning but blowing instead
look near your bottom of your vacuum. it might be clogged there have it looked at a soon as possible.
Jul 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Final Filter-Hoover U5399-900 WindTunnel Lite Upright Vacuum
Hi you could try these people who deal with hoover parts their number is 0845 230 6 230
they are called www.espares.co.uk
hope this helps if they dont have your part they should be able to get one or direct you to another supplier.
May 18, 2009 | Hoover U5399-900 WindTunnel Lite Upright...
The Hoover Windtunnel vacum will not pull suction
Either the machine or hose is blocked OR the filters are blocked.
Also possible that the belt is broken.
Please leave feedback
Thanks
Feb 13, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
HOOVER 6430-900
Hoover Fined for Failing to Report Vacuum Cleaner Fire Hazard
(function(){ var e9 =new expo9_ad(); e9.size ="160x600,120x600"; e9.showAd(); })(); _qoptions = { tags:"ADSDAQ.LAWPOLITICS,501500," }; _qacct="p-01-0VIaSjnOLg";setTimeout("quantserve()",3000);
January 16, 2007
Hoover
hoover.jpgHoover Fined for Failing to Report Vacuum Cleaner Fire Hazard
Whirlpool Spins Off Hoover
Hoover Recalls Self-Propelled Vacuum Cleaners
Consumer Complaints
Hoover Company Inc. has agreed to pay a $750,000 civil penalty to settle allegations that it failed to report to the U.S. Consumer Product Safety Commission (CPSC) the sale of vacuum cleaners with defective on-off switches that can overheat and cause the vacuum cleaner to catch fire.
In April 2005, Hoover conducted a recall of 636,000 Hoover Self-Propelled Upright Vacuum Cleaners because of defective on-off switches.
In June 2004, after CPSC received notice of several vacuum cleaner incidents, the Commission staff requested Hoover provide a full report of incident information. In July 2004, when Hoover submitted a full report, it had notice of 260 consumer incidents, of which 141 involved reports of fire. Additionally, there was one report of a minor burn injury.
Hoover first learned of a vacuum cleaner switch on one of these units overheating and melting in April 1999.
Federal law requires firms to report to CPSC immediately (within 24 hours) after obtaining information reasonably supporting the conclusion that a product contains a defect which could create a substantial risk of injury to the public, presents an unreasonable risk of serious injury or death, or violates a federal safety standard.
These Hoover Self-Propelled Upright Vacuum Cleaners are plastic, upright vacuums with the brand name �Hoover� and words "Self Propelled" printed on the front of the product.
Only those Hoover Self-Propelled Upright Vacuum Cleaners manufactured between May 1998 and November 1999 are included in the recall that is the subject of this penalty.
Jun 11, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
63 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
