Question about Konica Minolta DiMAGE G500 Digital Camera
DiMAGE G500 I cannot remove "CARD IS PROTECTED" and go back to normal operation.Help
    Problem Solver:
  • 4 Answers
Just Unclick the lock on your card
Posted on Aug 06, 2008
Hi, i am using minolta G500 5.0 megapixels camera... in that i am using 2gb memory card... after clicking the photos it is not getting saved in the memory card.. it is getting saved in the camera.. and...
This is pretty old camera. Try putting your old memory card. It it works probably this much size might not be supported on your device.
Please let me know if your old memory card does not work ( Which was working before)
Nov 08, 2010 | Konica Minolta DiMAGE G500 Digital Camera
I bought a Kingston 4GB Class 6 SDHC Card for this camera, and when I put it in the camera, it doesn't seem to be recognized by the camera.
The G500 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
Nov 05, 2010 | Konica Minolta DiMAGE G500 Digital Camera
What does it mean my memory card is protected cause now I can't seem to take any pictures. How do I fix that?
Hello,Please remove your memory card and check to see if the small lock tab is in the locked position.If so unlock it.This tab will be on the upper lefthand edge as you look at it ,it's very small.
Jan 09, 2010 | Konica Minolta DiMAGE G500 Digital Camera
"CARD IS PROTECTED"
are the images locked? on internal memory? or is it on a sd card?
(SD and MS cards feature a write lock. Unlock the card.)
also
This maybe useful to anyone whose "lock" toggle has fallen off. The plastic toggle is there to activate a switch in the device (like in digital camera) not on the card. To get the device to see the card as unlocked, just glue a small piece of plastic to fill the slot in the side of the SD card casing. You will loose the SD card lock feature but at least you will be able to write data to the card again Also, if you don't feel like glueing just stick a piece of tape on the side that will work too
Aug 01, 2008 | Konica Minolta DiMAGE G500 Digital Camera
Minolta DiMAGE G500
Yeah kind of talking to yourself, but I'm listening. It very well could be the internal battery. The bad thing is it's in a location that you shouldn't attempt yourself. Find somebody in your area that sevices these and take it to them. I'm sorry this wasn't an easy fix.
Jun 22, 2008 | Konica Minolta DiMAGE G500 Digital Camera
DImage G500 Grainy Pics
try resetting the camera once ... remove the batteries and press the power button for few seconds and put ur batteries back !!
May 21, 2008 | Konica Minolta DiMAGE G500 Digital Camera
How to use a minolta dimage g500 camera
Do you mean the memory card in your camera or do you mean another device?
First check that your memory card works in another device. There is a lock button on the SD card that needs to be unlocked.
Second, check that your camera settings have the SD card option selected. You can select the destination of your images.
Nov 03, 2007 | Konica Minolta DiMAGE G500 Digital Camera
Dimage g500 not saving pictures to memory stick
Here is the link to the manual if you need it; http://ca.konicaminolta.com/support/manuals/digital_cameras/dimage-g/dimage_g500/D_G500_E.pdf page 105 describes how to set the memory priority between the stick and the camera. If this doesn't help then try formatting the stick (page 99) If still no joy then I suspect the memory stick is faulty - see if you can borrow one and try it. Hope this helps - please post again if not :)
Mar 28, 2007 | Konica Minolta DiMAGE G500 Digital Camera
I pressed in a pop up lence manually...
your lens mechanism is stuck up! try pulling the lens with slight force, if you are lucky the culprit that is blocking the mechanism will get loose. If you are not lucky theres no way you can remove or fix the problem than sending it to the authorized service center. =-(
Aug 22, 2006 | Konica Minolta DiMAGE G500 Digital Camera
Konica Minolta DiMAGE G500 Digital Camera Logo
64 people viewed this question
Top Konica Minolta Cameras Experts
Willem.
Willem.
ktpierce
Level 1 Expert
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
