Question about Nikon WT4A Wireless Transmitter for D3 and D300 Digital (25365) 80211agb
I have Nokon D300 camera and trying to connect through woreless. i checked that conectivity is establish through ping command and not dected camera control pro2 in windows7.please tell me how to reolve problem
    Champion:
  • 254 Answers
So you have a Nikon D300 with Nikon Camera Control 2 running on Window 7.
Do this first:1. Remove Nikon WT-4A from camera.2. Make sure to set menu to PTP.3. Hook USB cable from camera to computer (tethered).4. Turn on D3005. Something will display on lower right screen ei found Nikon D300.6. Click on Nikon Camera Control Pro 2 (what version do you have)?7. Wait about 2 to 3 minutes for Nikon Camera Control Pro 2 to come on.8. Adjust modes & settings from pc and fire from pc, not from camera.9. One or two of your cells is defective or weak. Battery goods for up to 3 years. You can check with DVM.10. Many are having problems using & setting up Nikon WT as well as Canon WFT.
All are now selling them and using my ATG AK1 Un-Tethered Systems.
Posted on Oct 08, 2012
Unable to connect to some websites
Check to see you have no missing or damaged files. From a command prompt with Admin rights run " SFC / scannow"
See https://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/system_file_checker.mspx?mfr=true for full details of this utility.
Aug 31, 2014 | Microsoft Windows XP Home Edition
My Kodak printer ESP5250 is not printing The Wi Fi light flashes every 15 seconds.It has 100%conectivity. any ideas please?
make sure the WIFI printer is connected to the same network were your laptop or another device connected too.. try pinging the WIFI IP address by using the laptop under command prompt if you get a reply means the Printer is connected to your Home network and maybe re-=install the software of the printer to your laptop.. and follow the steps by steps... hope this help
Oct 15, 2013 | Kodak Cameras
Have router belkin 5f99 no conections internet
Check your all physical connection and cable..or you can reset the router.follow the given may be it will help you to identify your problems..
First,restart your computer
->Open web browser and enter the IP address and enter the login details on the login screen and proceed.Click Router Status under Maintenance and check if you see your IP address.
->If you see 0.0.0.0, the router is not obtaining the IP address. It can happen due to various reasons. Contact your ISP and ask for the details including username, password for PPPoE etc. and try to connect to the Internet again afterwards.
->After configure you router ,open Command Prompt, type 'ipconfig/all' and hit Enter. Check Default Gateway
->If you are still unable to browse the Internet, ping your router's connection to the PC. Open Command Prompt, type 'ping IPaddress(ex:192.168.1.0)', hit Enter.
->If you get the Request timed out message then check your router connection again and correct the Ethernet connection between your PC and the router.
If you need any technical help on wireless router then you can reach at http://www.vtechsquad.com/
Feb 24, 2013 | Computers & Internet
The Internet conects only first page after reseting.
Hi
This is offline page dear, you can not get the internet please check the following option in you router.
1) Please make sure you put the correct User Name and Password.
2) Check your PC or Laptop IP address configuration.
3) Restart you router and go to command line.
4) And type Ping to yahoo.com exp (ping yahoo.com)
5) If you get the reply its mean your proble solve you get the Internet.
Cheer
Aug 02, 2011 | NetGear DG834G Router
REAR FLASH PRB ON NIKON D300
If your doing what I think you are then, It sounds like the flash is set too act as a commander for the off-camera CLS flash setup. Check setting e3 and put it in TTL mode. It's called rear or 2nd curtain flash sync.
Oct 21, 2009 | Nikon D300 Digital Camera
How to configure D-Link Wireless Router 615 on LAN ?
you need a cat 5 or better to work fine, and if you have turned mac filter on, please check/add if needed your laptop to the network, best is to use dlink given cd, with has auto-detect devices function inside, then adjust security setting manually
Sep 22, 2009 | D-Link DIR-625 (790069292637) Wireless...
Cannot connect although plugged in
Check the ipaddress. Type ipconfig in command prompt. Then ping a website in command prompt if u get proper ip address e.g 10.132.147.121. Try to ping www.google.com in command prompt. If u are unable to connect. Tried to release renew Ip address.
Type ipconfig /release then ipconfig /renew in command prompt. If you are able to ping google and still unable to connect to website using internet explorer, then issue with browser or with OS.
Aug 17, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Cant get the wireless connection through the AP router
first check ur computer IP address (if not getting from DHCP then try static IP address) & default gateway.
Mar 20, 2009 | CTG 54Mbps WIRELESS ACCESS...
My laptop has stopped connecting to the internet it comes up cannot find ip address, and area connection is unplugged but all cables are ok
Try check your IP address, sometimes it automaticaly goes to default IP but it should come back nomal for sometime. try ping google.com if it indicates time out, then its something to do with your Internet service providers.How to ping to check conection, go to MS DOS command prompt and type- ping www.google.com.
Nov 26, 2008 | Computers & Internet
I have lost my wireless from my belkin how do i set it back up?
if the woreless connection has itself gone down, check your router, reset if nned be, then try and conect your PC manually, if it doesnt see a network or fails to connect, check encapsulation methods are correct and 802.11x security is not enabled, or check your wireles card in your PC
Jul 17, 2008 | Belkin Computers & Internet
Nikon WT4A Wireless Transmitter for  D3 and D300 Digital (25365) 80211agb Logo
80 people viewed this question
Top Nikon Computers & Internet Experts
David Payne
David Payne
Are you a Nikon Computer and Internet Expert? Answer questions, earn points and help others
